Using the ncu CLI, I am trying to get a few metrics. But the name of the function is demangled in the output. Is there a way to get the output with the mangled names instead (e.g. _Z4HistPiiPfi)? After reading the documentation, I tried the below command, but of not use:
ncu -f --csv --log-file metrics_list --print-units base --kernel-name-base mangled --metrics smsp__warp_issue_stalled_barrier_per_warp_active.pct ./histogram
I want to profile for all the kernels and not give any particular kernel name as input.
