I run like:
/usr/local/NVIDIA-Nsight-Compute/nv-nsight-cu-cli --metrics "gpu__time_active,gpu__time_duration,launch__grid_size" ./process
The result is:
default_function_kernel0_969, 2020-Jun-03 09:34:13, Context 1, Stream 7
Section: Command line profiler metrics
gpu__time_active (!) n/a
gpu__time_duration (!) n/a
launch__grid_size 1280
But When I run like:
/usr/local/NVIDIA-Nsight-Compute/nv-nsight-cu-cli ./process
The result is all right.
So I wonder why commond with --metrics will lead the result into n/a, like those metrics sm__shmem_ld_bank_conflict_sum,sm__shmem_st_bank_conflict_sum,smsp__inst_executed_shared_loads_sum,smsp__inst_executed_shared_stores_sum,smsp__inst_executed_shared_loads_avg
The Nsight Compute Verison: 2019.5
GPU Driver: 440.82
GPU: RTX 2080 Ti
CUDA Version: 10.2
And I test above commond in GTX 1080, it seems all right.
The config is:
GPU Driver: 410.48
GPU: GTX 1080
CUDA Version: 10.0
