I have run the following command on a 2080Ti device
sudo /usr/local/cuda-10.1/NsightCompute-2019.3/nv-nsight-cu-cli \
--quiet --metrics sm__warps_active.avg.pct_of_peak_sustained_active,smsp__inst_executed.avg.per_cycle_active \
-f -o perf.nvvp ../../../build/bin/bfs market belgium_osm.mtx
in order to profile an application. The output file size is 86M file, but when I open it via /usr/local/cuda/NsightCompute-2019.3/nv-nsight-cu->FILE->OPEN FILE, I see the picture below which shows both metrics are n/a.
https://pasteboard.co/IxaRuVo.png
That is weird because, the same program with nvprof on older devices works fine and I can see the information for kernels used in the program.
