I got many N/A when I used Nsight Compute on Ubuntu
My GPU is 1660TI, CUDA version is 10.1, Driver Version is 455.45.01, OS is Ubuntu 18.04
I input the code in my terminal
sudo /usr/local/cuda-10.1/NsightCompute-2019.1/nv-nsight-cu-cli --f ./test
the result is just like this:
==PROF== Connected to process 4835
==PROF== Profiling "matrix_add_2D" - 1: 0%....50%....100% - 3 passes
Success!
==PROF== Disconnected from process 4835
[4835] test@127.0.0.1
matrix_add_2D, 2020-Dec-08 22:44:46, Context 1, Stream 7
Section: GPU Speed Of Light
Memory Frequency        (!) n/a
SOL FB        (!) n/a
Elapsed Cycles        (!) n/a
SM Frequency        (!) n/a
Memory [%]        (!) n/a
Duration        (!) n/a
SOL L2        (!) n/a
SOL TEX        (!) n/a
SM Active Cycles        (!) n/a
SM [%]        (!) n/a
Section: Compute Workload Analysis
Executed Ipc Active        (!) n/a
Executed Ipc Elapsed        (!) n/a
Issue Slots Max        (!) n/a
Issued Ipc Active        (!) n/a
Issue Slots Busy        (!) n/a
SM Busy        (!) n/a
Section: Memory Workload Analysis
Memory Throughput        (!) n/a
Mem Busy        (!) n/a
Max Bandwidth        (!) n/a
L2 Hit Rate        (!) n/a
Mem Pipes Busy        (!) n/a
L1 Hit Rate        (!) n/a
Section: Scheduler Statistics
Active Warps Per Scheduler        (!) n/a
Eligible Warps Per Scheduler        (!) n/a
No Eligible        (!) n/a
Instructions Per Active Issue Slot        (!) n/a
Issued Warp Per Scheduler        (!) n/a
One or More Eligible        (!) n/a
Section: Warp State Statistics
Avg. Not Predicated Off Threads Per Warp        (!) n/a
Avg. Active Threads Per Warp        (!) n/a
Warp Cycles Per Executed Instruction        (!) n/a
Warp Cycles Per Issued Instruction        (!) n/a
Warp Cycles Per Issue Active        (!) n/a
Section: Instruction Statistics
Avg. Executed Instructions Per Scheduler        (!) n/a
Executed Instructions        (!) n/a
Avg. Issued Instructions Per Scheduler        (!) n/a
Issued Instructions        (!) n/a
Section: Launch Statistics
Block Size        1,024
Grid Size        1,024
Registers Per Thread                                                   register/thread                             16
Shared Memory Configuration Size                                                 Kbyte                          49.15
Dynamic Shared Memory Per Block                                             byte/block                              0
Static Shared Memory Per Block                                              byte/block                              0
Threads        thread                      1,048,576
Waves Per SM        42.67
Section: Occupancy
Block Limit SM        block                             16
Block Limit Registers                                                         register                              4
Block Limit Shared Mem                                                            byte                            nan
Block Limit Warps        warp                              1
Achieved Active Warps Per SM        (!) n/a
Achieved Occupancy        (!) n/a
Theoretical Active Warps per SM                                             warp/cycle                             32
Theoretical Occupancy        %                            100
There are so many (!)n/a, would you please help me to solve it? Thank you.
I have solved my problem! I change my CUDA from v10.1 to v10.1 update2, and it works.
The nsight-compute version changes from 2019.1.0 to 2019.4.0
