what is the means of gpu__compute_memory_access_throughput
and how to get memory load/store efficiency using nv-nsight-cu-cli for sm_75
thanks in advance
In the section file you pasted, there is no metric gpu__compute_memory_access_throughput, did you put the wrong name by any chance? In general, you should be able to get descriptions for almost all metrics using the command line query functionality, e.g. for SM 75, RTX2080Ti
nv-nsight-cu-cli --query-metrics --chip tu102
This will print a (long) list of all metric base names with their descriptions. You can check Nsight Compute CLI :: Nsight Compute Documentation for more details on how to use that option, and how to query the valid suffixes for those metric names on Volta or newer architectures.
If you already know the metric (base) name to query, e.g. gpu__compute_memory_access_throughput, you can also use directly
gpu__compute_memory_access_throughput: the average Compute Memory Pipeline : throughput of internal activity within caches and DRAM, as a % of peak burst rate over active cycles
gpu__compute_memory_request_throughput: the average Compute Memory Pipeline : throughput of interconnects between SM<->Caches<->DRAM, as a % of peak burst rate over active cycles
thanks for your detailed answer.
by the way, how can i get the descriptions of other metrics? and, can i get *_efficiency by the combination of some metrics?
