I can't find explanations of nsight compute metrices
Hello, I was profiling some kernels and encountered some metrics I can’t understand. The metrics are below
  1. derived_tempMetric0
  2. gcc__cache_requests_type_constant.sum
  3. dram__bytes_op_write.sum.pct_of_peak_sustained_elapsed
  4. gpu__compute_memory_access_throughput.avg.pct_of_peak_sustained_elapsed
  5. gcc__xbar2gcc_sectors.sum
  6. gpu__compute_memory_access_throughput.max.pct_of_peak_sustained_elapsed
  7. derived__memory_l2_theoretical_sectors_global_excessive
  8. derived__smsp__inst_executed_op_branch_pct
  9. gcc__xbar2gcc_sectors.sum
  10. gcc__average_cache_request_hit_rate.pct
  11. derived__smsp__sass_thread_inst_executed_op_ffma_pred_on_x2
  12. derived__memory_l1_conflicts_shared_nway
  13. derived__avg_thread_executed_true
I would appreciate if someone explains what the metrics above mean or notify me how to get access to the explanation of metrics above. I googled metrics above but couldn’t find any explanation.
Thank you in advance!
You can query metric descriptions using ncu --query-metrics or its sibling commands, or using the Metric Details tool window. You can also hover the metrics in the UI to see their description. derived__tempMetric0 is only used in calculating other metrics and doesn’t have a description.
Descriptions are also provided here.
