Hi NVIDIA team,
I’m profiling a workload on Jetson Orin using Nsight Compute CLI and I’m currently collecting metrics using the built-in metric set:
--set MemoryWorkloadAnalysis
After profiling, I want to export only the collected metrics using a command like:
ncu -i report.ncu-rep --csv --page raw --metrics launch__registers_per_thread,gpc__cycles_elapsed.max,sm__throughput.avg.pct_of_peak_sustained_elapsed,gpu__compute_memory_throughput.avg.pct_of_peak_sustained_elapsed,gpu__time_duration.sum
However, I don’t know exactly which metrics were actually collected by MemoryWorkloadAnalysis
ncu --query-metrics only shows all available metrics, not the subset actually used in the set
