I was trying to get the unified memory throughput while executing Gemm-ops based on PyTorch.
Following the manual, I executing following instruction:
ncu --query-metrics-collection pmsampling
and then I got a list of options available on Orin.
I chosn some related to the unified memory by key words ‘soc’:
mcc__dram_throughput_op_read Throughput % soc_mcc MCC read throughput
mcc__dram_throughput_op_read_internal_activity Throughput % soc_mcc MCC read throughput, internal activity
mcc__dram_throughput_op_write Throughput % soc_mcc MCC write throughput
mcc__dram_throughput_op_write_internal_activity Throughput % soc_mcc MCC write throughput, internal activity
mcc__dram_throughput_srcnode_cpu_op_read Throughput % soc_mcc MCC read throughput from CPU
mcc__dram_throughput_srcnode_cpu_op_read_internal_activity Throughput % soc_mcc MCC read throughput from CPU, internal activity
mcc__dram_throughput_srcnode_cpu_op_write Throughput % soc_mcc MCC write throughput from CPU
mcc__dram_throughput_srcnode_cpu_op_write_internal_activity Throughput % soc_mcc MCC write throughput from CPU, internal activity
mcc__dram_throughput_srcnode_dbb_op_read Throughput % soc_mcc MCC read throughput from DBB
mcc__dram_throughput_srcnode_dbb_op_read_internal_activity Throughput % soc_mcc MCC read throughput from DBB, internal activity
mcc__dram_throughput_srcnode_dbb_op_write Throughput % soc_mcc MCC write throughput from DBB
mcc__dram_throughput_srcnode_dbb_op_write_internal_activity Throughput % soc_mcc MCC write throughput from DBB, internal activity
mcc__dram_throughput_srcnode_gpu_op_read Throughput % soc_mcc MCC read throughput from GPU
mcc__dram_throughput_srcnode_gpu_op_read_internal_activity Throughput % soc_mcc MCC read throughput from GPU, internal activity
mcc__dram_throughput_srcnode_gpu_op_write Throughput % soc_mcc MCC write throughput from GPU
mcc__dram_throughput_srcnode_gpu_op_write_internal_activity Throughput % soc_mcc MCC write throughput from GPU, internal activity
I executed some of them, just as following instructions:
sudo /usr/local/cuda-12.6/bin/ncu \
--nvtx \
--set full\
--metrics pmsampling:mcc__dram_throughput_op_read.avg.pct_of_peak_sustained_elapsed \
--force-overwrite \
-o "$ncu_report_file" \
$CONDA_PYTHON_PATH $script_name
as well as options:
then I got some ‘*.ncu-rep’ files. I downloaded these files and open it with Nsight Compute GUI on windows11.
But when I tried to check, there was no metrics, just like following figure:
I tried to rename options, like:
but didn’t work.
I tried other options, for example:
pmsampling:l1tex__data_pipe_lsu_wavefronts.avg
then I got the metrics:
So how can I solve this problem?
Platform:
Jetson orin nx
cuda 12.6
ncu 2024.3.1.0
