I trying to investigate that effective device memory access for performance tuning on Jetson-TX1.
Is there a way to measure DRAM throughput and transactions?
I used nvprof, but could not get “dram_write_throughput”, “dram_read_throughput”, “dram_read_transctions” and “dram_write_transactions”.
There is a problem in how to use? Is there any other way?
ubuntu@tegra-ubuntu$ nvprof --analysis-metrics -o x.dat ./simpleCUBLAS
======== Warning: Metric "dram_write_throughput" cannot be found on device 0.
======== Warning: Metric "dram_read_throughput" cannot be found on device 0.
======== Warning: Metric "l1_shared_utilization" cannot be found on device 0.
======== Warning: Metric "sysmem_utilization" cannot be found on device 0.
======== Warning: Metric "dram_write_transactions" cannot be found on device 0.
======== Warning: Metric "dram_read_transactions" cannot be found on device 0.
======== Warning: Metric "alu_fu_utilization" cannot be found on device 0.
======== Warning: Metric "ecc_throughput" cannot be found on device 0.
======== Warning: Metric "ecc_transactions" cannot be found on device 0.
======== Warning: Metric "l2_l1_read_transactions" cannot be found on device 0.
======== Warning: Metric "l2_l1_write_transactions" cannot be found on device 0.
======== Warning: Metric "nc_l2_read_transactions" cannot be found on device 0.
======== Warning: Metric "l2_l1_read_throughput" cannot be found on device 0.
======== Warning: Metric "l2_l1_write_throughput" cannot be found on device 0.
======== Warning: Metric "nc_l2_read_throughput" cannot be found on device 0.
======== Warning: Metric "atomic_throughput" cannot be found on device 0.
==25677== NVPROF is profiling process 25677, command: ./simpleCUBLAS
GPU Device 0: "GM20B" with compute capability 5.3
simpleCUBLAS test running..
==25677== Warning: Some kernel(s) will be replayed on device 0 in order to collect all events/metrics.
simpleCUBLAS test passed.
==25677== Generated result file: /home/ubuntu/x.dat
