I am running the CLI (‘Version 2019.5.0 (Build 27346997)’) on Ubuntu 18.04 to profile a simple CUDA application. I recently changed my drivers to 440.64, and am running CUDA 10.2.
No matter what application I try to profile, the nv-nsight-cu-cli just hangs indefinitely. It seems to be doing some kind of busy waiting (100% CPU) but there is no memory usage etc and it just idles forever (let it run for 12+ hours).
Actually, just changed the driver to 440.33.01, and lo and behold, nv-nsight-cu-cli works correctly now. Does the Nsight Compute tool not work with the latest device drivers? Or is 440.33.01 in an entirely different branch of drivers than 440.64.
Any updates on this? Did some more digging and it seems pretty reliable - I cannot use nv-nsight-cu-cli on literally any binary with the latest device drivers. The tool is completely broken on the official newest drivers (at least for me).
I’m having the same problem, I am using an rtx 2060 and I’m on driver version 450.80.02 and CUDA 2020.1.0. every cuda application that I’ve tried has made my ubuntu desktop hang.
Sanjiv, I am having the same problem. But when I use your suggestion to try collecting just a single metric, it works, even though it hangs when I don’t specify any argument. This is V100, cc70. Do you think it’s actually not hanging but just taking a long time (I let it go 15 mins).
Additional info: the issue appears to be when running for any of the metrics that include the string “pct_of_peak_sustained”.
Please provide the version of Nsight Compute and NVIDIA driver you are using? Also what is the OS version?
Yes this could be the case. Note that when you do not specify any argument the default set of metrics are collected for each kernel launch. So to reduce the metric collection time you can select a smaller subset of metrics and/or select a fewer number of kernels. Refer the overhead section in the https://docs.nvidia.com/nsight-tools/nsight-compute/ProfilingGuide/index.html#overhead
Can you please confirm this by running nsight compute with just any of these metrics?
