Mask_param data interpret
Continuing the discussion from Interpret mask_params data from PeopleSegNetV2:
• DeepStream Version
• TensorRT Version
about the pic,I have 2 questions:
1)for the deepstream pipline like streammux!nvinfer(seg model)!nvtracker!nvosd!,if I add a pad in the osd src,the channel params in the pic should set to 3? or 1?
2)when i use the function nvds_mask_utils_resize_to_binary_argb32, the params argb_32,interpolation,stream should set to what?any suggestions?
thank you so much,the answer is important for me !looking forward!
What do you mean add a pad in the osd src?
Please refer to our source code sources\includes\nvds_mask_utils.h.
 * @param  argb_32 [IN] The pixel value in dst when src pixel > threshold
 * @param  interpolation [IN] The NPP interpolation method to use
 *         Enumeration copied below:
 *         NPPI_INTER_NN =1, Nearest neighbor filtering.
 *         NPPI_INTER_LINEAR Linear interpolation.
 *         NPPI_INTER_CUBIC Cubic interpolation.
 *         NPPI_INTER_CUBIC2P_BSPLINE Two-parameter cubic filter (B=1, C=0)
 *         NPPI_INTER_CUBIC2P_CATMULLROM Two-parameter cubic filter (B=0, C=1/2)
 *         NPPI_INTER_CUBIC2P_B05C03 Two-parameter cubic filter (B=1/2, C=3/10)
 *         NPPI_INTER_SUPER Super sampling.
 *         NPPI_INTER_LANCZOS Lanczos filtering.
 *         NPPI_INTER_LANCZOS3_ADVANCED Generic Lanczos filtering with order 3.
 *         NPPI_SMOOTH_EDGE Smooth edge filtering.
 * @param  stream [IN] The cuda-stream to use for scaling operation on GPU
so glad to receive your reply,thanks!
What do you mean add a pad in the osd src ?
sorry,it’s add a probe in osd src pad.
Please refer to our source code sources\includes\nvds_mask_utils.h .
In fact, I have carefully read these parameter definitions, but I am not very familiar with them, especially the stream parameter. I really don’t know how to get it. I tried to set it to NULL, but there was an segmentation error when the program runing.
About the channel, you can get the num_planes from the nvbufsurface.
The stream means cudaStream_t.
We recommend that you learn some cuda and NvbufSurface basics before customizing your own code, otherwise there will be some exceptions in your own code.
hi,listen to youradvice,I learn some easy function about cuda,now i have two questions:
Please check if this process is correct,
  1. Memory request
    cudaMalloc(&src_data, mask_width * mask_height * sizeof(float));
    cudaMalloc(&dst_data, stream_width * stream_height * sizeof(uint32_t));
    Perform memory requests for both the original and target mask data separately;
  2. Create stream variables
    cudaStream_t stream;
    cudaStreamCreate(&stream);
  3. Wait for stream processing
    cudaStreamSynchronize(stream);
  4. Release memory
    cudaFree(src_data);
    cudaStreamDestroy(stream);
Two questions:
What are the loopholes in the above process?
2. Is the size of the memory request for src mask data calculated using the size in mask_params or through mask_weight * mask_height * sizeof (float)?
You can get that from the float *data; and unsigned int size; form the NvOSD_MaskParams.
anotherquestion please:What are the loopholes in the above process?
Your basic process is correct. You need to pay attention to whether the memory is on the host or on the device.
thanks to you professional reply , i use the above step and acquire the data like this
about the introduction of the nvds_mask_utils_resize_to_binary_argb32 function said “ARGB32 For resized pixels > threshold, transparency is set to 50% and other pixels are set to 100% transparent; RGB = 0 for all pixels”
two questions:
  1. Why is the transparency of the data I receive equal to others (not 50% and 100%)? What does this mean?
  2. I set the nvds_mask_utils_resize_to_binary_argb32 param argb32_px equal to 0xFFFFFFFF,why the r,g,b isn’t equal to 255?
  3. How can I use the parsed data to convert them into binary masks?
by the way the threshold that i set is equal to 0.5.
argb32_px is the pixel value in dst when src pixel > threshold.
You can check the data from the dst.
thank you very much for your reply!
  1. its uint32_t argb32_px = 0xFFFFFFFF is right?
  2. cudaMalloc(&dst_data, stream_width * stream_height * sizeof(uint32_t));its the sizes stream_width * stream_height * sizeof(uint32_t) is right? Is it means a pic have 3 channels and the pixel of each channel can get in uint32_t?
This means that the pixel is opaque white colour.
It means a pic have 4 channels: argb.
everything work well but only one question: the dst uint32_t data is not equal to my setting value, 1. I set the nvds_mask_utils_resize_to_binary_argb32 param argb32_px equal to 0xFFFFFFFF,why the r,g,b isn’t equal to 255?
You need to make sure if it meets the above condition.
If the pixel I set is 0xFFFFFFFF, what happens when src pixel>threshold is not met?
Let’s not debug this non-open source code for a while.
Could you describe in more detail the problems you encountered in our demo and the final results you want?
I just want to get the right segmentation result and covert it to the binary value
Our latest nvsegvisual version supports this scenario. You can set the alpha and original-background parameter to meet your needs. Please refer to our demo tao_segmentation.
I tried your method to add the nvsegvisual element , but it not work , my model is yolo-seg, it don’t have the NvDsInferSegmentationMeta data,it’s seg results contained in the obj_meta->mask_params,any method can i decrease the running time of the nvds_mask_utils_resize_to_binary_argb32 ?
OK, now I understand. The yolo-seg is an instance segmetation model, so we cannot use nvsegvisual plugin to draw the mask. Can you attach a picture to illustrate the result you want? We can support the instance segvisual model too. You can refer to our demo mask2former.
