Interpret mask_params data from PeopleSegNetV2
GPU
• DeepStream Version
6.1.1
• TensorRT Version
questions
How should the mask output data from PeopleSegNet (v2.0.2) be interpreted?
Mask output layer is ’ mask_head/mask_fcn_logits/BiasAdd’ as described in NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream (github.com).
Each detected object has ‘mask_params’ metadata attached as below:
Could you please elaborate on the format of the output and how to convert it to a pixel mask to overlay on an image?
I’ve attached the float[3136] array from above as a .txt - How can I convert and scale the mask to fit the image?
The detection box is:
left: 251.45857
top: 270.86142
width: 171.64272
height: 243.53386
sample.txt (31.0 KB)
video resolution: 2688x1520
config: peoplesegnet_config.txt (891 Bytes)
Thanks in advance!
/M
You can refer the link below first:
https://catalog.ngc.nvidia.com/orgs/nvidia/teams/tao/models/peoplesegnet
The NGC provides no real information on how to interpret the outputs except for “Category label (person), bounding-box coordinates and segmentation mask for each detected person in the input image.”
Could you elaborate on how to convert the float[3126] vector from mask_params->data into a pixel mask I can overlay on the output video?
The data para is a pointer, not a float number. It points to a surfaceList of NvBufSurface. So you can draw the data of the NvBufsurface to the video.
Is it a Glib List of NvBufSurface?
The below breaks (Is C# code, but you get the point):
It is not a list of NvBufSurface pointers either (this breaks too):
If I read the memory (as float) I get the data attached in sample.txt in my first post.
If I take the first 28x28 elements with values above 0, I do in fact get a mask - however this seems like an incorrect way of doing it?
Is the memory layout wrong or am I interpreting it incorrectly?
Sorry, my fault. I misread the structure of your remarks. These datas you marked are float numbers output from the inference. You can convert it to a argb32 pixel format. This part of the code is not open source, so I suggest you refer to the API of the conversion:nvds_mask_utils_resize_to_binary_argb32 from nvds_mask_utils.h
Perfect!
I’ll use the nvds_mask_utils_resize_to_binary_argb32() of libnvds_osd.so with the parameters as described in the header file.
Will the method expect the memory of src* and dst* to be already allocated on the Cuda device or does it allocate internally?
Much appreciated for the help!
EDIT: Nevermind it seems to allocate Cuda internally so need to manually allocate - it is working!
Can you explain the channel parameter?
/M
It means the channel of your inferred data, basically you can set 1.
Much appreciated - everything is working,
Thanks for the help and have a great weekend!
/M
