Error when retrieving segmentation masks with custom Mask R-CNN, on jetson Xavier AGX
We encounter some difficulties integrating a custom mask r-cnn model into DeepStream 6.0
• Hardware Platform (Jetson / GPU) Jetson Xavier AGX 16Gb
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1.6
• NVIDIA GPU Driver Version (valid for GPU only) L4T 32.6.1
I built a custom pipeline which takes a h264 video file as input, performs the inference and then records each mask corresponding to the different frames. It works with a custom FCN model, but I want to replace it by a custom Mask R-CNN one. This one has been trained with TAO-Toolkit and then exported to engine format from the custom DeepStream Pipeline. It was trained from a resnet50 backbone. When exporting we observe this :
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT Input           3x832x1344
1   OUTPUT kFLOAT generate_detections 10x6
2   OUTPUT kFLOAT mask_fcn_logits/BiasAdd 10x4x28x28
I followed this tutorial : MaskRCNN — TAO Toolkit 3.22.05 documentation , having downloaded TensorRT OSS, built the necessary libraries…
With the custom pipeline, I am able to retrieve bbox corresponding to detected objects during inference from GST buffer with a probe function, but don’t succeed to retrieve the corresponding masks using mask_params from NvDsObjectMeta, and obtained this error:
TypeError: Unable to convert function return value to Python type! The signature was
      (self: pyds.NvDsObjectMeta) -> _NvOSD_MaskParams
I also tried with pyds.NvDsInferSegmentationMeta.cast and obtained this error:
segmeta = pyds.NvDsInferSegmentationMeta.cast(user_data.user_meta_data)
AttributeError: type object 'pyds.NvDsInferSegmentationMeta' has no attribute 'cast'
To narrow down, I follow this : GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications and tried to run the deepstream-segmentation.py. But I get the same error as the last one
Here is the custom python pipeline with use of NvDsObjectMeta mask_params : custom_pipeline.py (5.4 KB)
Here is the nvinfer config file config_v1.txt (1.1 KB)
Can you help us to solve this issue ? Do you have any idea of the source of the problem ?
Looking forward to your feedback
please refer to Accessing Mask Parameters from NvOSD_MaskParams in Python (not using Triton) - #6 by avnguyen213
Thanks for your reply
I have already downloaded and installed deepstream_python_apps. As mentioned in Accessing Mask Parameters from NvOSD_MaskParams in Python (not using Triton), I modified the line
.def_readwrite("mask_params", &NvDsObjectMeta::mask_params)
in bindnvdsmeta.cpp file into :
.def_property_readonly("mask_params", [](NvDsObjectMeta &self) -> py::array {
                   auto dtype = py::dtype(
                          py::format_descriptor<float>::format());
                   auto base = py::array(dtype,
                                        {self.mask_params.size},
                                        {sizeof(float)});
                   return py::array(dtype, {self.mask_params.size},
                                   {sizeof(float)},
                                   self.mask_params.data, base);
But I always get the same error:
I also tried to add in bindnvosd.cpp :
        py::class_<NvOSD_MaskParams>(m, "NvOSD_MaskParams",
                                     pydsdoc::NvOSD::MaskParamsDoc::descr)
                .def(py::init<>())
                .def_readwrite("data", &NvOSD_MaskParams::data)
                .def_readwrite("size", &NvOSD_MaskParams::size)
                .def_readwrite("threshold", &NvOSD_MaskParams::threshold)
                .def_readwrite("width", &NvOSD_MaskParams::width)
                .def_readwrite("height", &NvOSD_MaskParams::height)
                .def("cast",
                     [](void *data) {
                         return (NvOSD_MaskParams *) data;
                     py::return_value_policy::reference,
                     pydsdoc::NvOSD::RectParamsDoc::cast)
                .def("cast",
                     [](size_t data) {
                     pydsdoc::NvOSD::MaskParamsDoc::cast);
But this error occurs when running make:
error: 'MaskParamsDoc' is not a member of 'pydsdoc::NvOSD'
Please could you provide us more information on the files to be modified ?
I also modified the pydocumentation.h, adding to the following of “namespace RectParamsDoc {}” :
        namespace MaskParamsDoc
            constexpr const char* descr = R"pyds(
                Holds the mask parameters for the object.
                :ivar data: *float*, Holds mask data for the object.
                :ivar size: *int*, Holds mask size.
                :ivar threshold: *float*, Holds threshold for binarisation.
                :ivar width: *int*, Holds mask width.
                :ivar height: *int*, Holds mask height.)pyds";
            constexpr const char* cast=R"pyds(cast given object/data to :class:`NvOSD_MaskParams`, call pyds.NvOSD_MaskParams.cast(data))pyds";
So the last mentioned error disappear and the first one comes back :
TypeError: Unable to convert function return value to a Python type! The signature was
I enclose the 3 modified files :
pydocumentation.h (126.3 KB)
bindnvosd.cpp (19.9 KB)
bindnvdsmeta.cpp (28.1 KB)
Do you have any idea to solve this issue ?
We look forward to hearing from you
please refer to deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub, after changed need to rebuild bindings.
Yes, I did.
Do I have to copy the generated pyds.so library to another directory?
I have the same problem as @sco .To add my experience here:
Modifying the files pydocumentation.h and bindnvosd.cpp I am able to acces to the obj_meta.mask_params. If I print some of its attributes I get:
mask_params:
            type: <class 'pyds.NvOSD_MaskParams'>
            data: -9.71875
            threshold: 0.0
            width: 28
            height: 28
Probably this values make no sense, since only the ‘data’ value changes in all the masks. I have also tried to get the mask data in the following way:
seg_meta=pyds.NvDsInferSegmentationMeta.cast(obj_meta.mask_params) # object of class pyds.NvDsInferSegmentationMeta
seg=pyds.get_segmentation_masks(NvDsInferSegmentationMeta)
which leads to Segmentation Fault.
Note that, acording to: gst_element_send_nvevent_new_stream_reset — Deepstream Deepstream Version: 6.1.1 documentation, the method get_segmentation_masks expects an object of class pyds.NvDsInferSegmentationMeta (like seg_meta) and returns a numpy array.
What’s wrong here?
BTW, If I print some attributes of seg_meta I get:
seg_meta:
            type: <class 'pyds.NvDsInferSegmentationMeta'>
            classes: 470023936
            width: 127
            height: 3136
about bindings, this link helps, Get unique_component_id for segmentation meta - #17 by sandeep.yadav.07780
