Your tfrecords file does not contain any ‘image/object/mask’.
More, your create_coco_record.py
is different from the create_coco_tf_record.py
inside the TLT 2.0 docker. Please refer to it and modify
flags.DEFINE_boolean(‘include_masks’, False,
to
flags.DEFINE_boolean(‘include_masks’, True,
Then, generate tfrecord files via following command. Note, below command just a reference. It only generate training tfrecords files.
PYTHONPATH=“tf-models:tf-models/research” python create_coco_tf_record.py --train_image_dir=./your_images_folder --train_object_annotations_file=./IRUV_train_v1.json --output_dir=./result --train_caption_annotations_file=dummy_file.json
