Mask R-CNN stops abruptly while training using custom coco dataset
I’m trying to train Mask R-CNN using a custom dataset that I have made and converted to coco format. My custom dataset only has one class. The training just stops suddenly after saving model.step-0.tlt without any error or warning. It is important to note that the training worked when I used the defualt coco dataset with 91 classes. But this problem occured when I used my custom dataset. I tried my custom dataset on multiple models including Mask RCNN from matterport (https://github.com/matterport/Mask_RCNN) and it works.
Command:
!tao mask_rcnn train -e $SPECS_DIR/maskrcnn_train_resnet50.txt
-d $USER_EXPERIMENT_DIR/experiment_dir_unpruned
-k $KEY
–gpus 2
Log:
For multi-GPU, change --gpus based on your machine.
2022-01-27 09:02:37,789 [INFO] root: Registry: [‘nvcr.io’]
2022-01-27 09:02:37,860 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.5-py3
2022-01-27 09:02:37,894 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/abdulmajeed/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
[INFO] Loading specification from /workspace/tao-experiments/mask_rcnn/specs/maskrcnn_train_resnet50.txt
[MaskRCNN] INFO : Horovod successfully initialized …
INFO:tensorflow:Using config: {‘_model_dir’: ‘/tmp/tmpj4v4y22o’, ‘_tf_random_seed’: 123, ‘_save_summary_steps’: None, ‘_save_checkpoints_steps’: None, ‘_save_checkpoints_secs’: None, ‘_session_config’: intra_op_parallelism_threads: 1
inter_op_parallelism_threads: 8
gpu_options {
allow_growth: true
force_gpu_compatible: true
allow_soft_placement: true
graph_options {
rewrite_options {
meta_optimizer_iterations: TWO
, ‘_keep_checkpoint_max’: 20, ‘_keep_checkpoint_every_n_hours’: None, ‘_log_step_count_steps’: None, ‘_train_distribute’: None, ‘_device_fn’: None, ‘_protocol’: None, ‘_eval_distribute’: None, ‘_experimental_distribute’: None, ‘_experimental_max_worker_delay_secs’: None, ‘_session_creation_timeout_secs’: 7200, ‘_service’: None, ‘_cluster_spec’: <tensorflow.python.training.server_lib.ClusterSpec object at 0x7f246dd7c668>, ‘_task_type’: ‘worker’, ‘_task_id’: 0, ‘_global_id_in_cluster’: 0, ‘_master’: ‘’, ‘_evaluation_master’: ‘’, ‘_is_chief’: True, ‘_num_ps_replicas’: 0, ‘_num_worker_replicas’: 1}
INFO:tensorflow:Using config: {‘_model_dir’: ‘/tmp/tmpu5l3beqy’, ‘_tf_random_seed’: 124, ‘_save_summary_steps’: None, ‘_save_checkpoints_steps’: None, ‘_save_checkpoints_secs’: None, ‘_session_config’: intra_op_parallelism_threads: 1
gpu_options {
allow_growth: true
graph_options {
rewrite_options {
, ‘_keep_checkpoint_max’: 20, ‘_keep_checkpoint_every_n_hours’: None, ‘_log_step_count_steps’: None, ‘_train_distribute’: None, ‘_device_fn’: None, ‘_protocol’: None, ‘_eval_distribute’: None, ‘_experimental_distribute’: None, ‘_experimental_max_worker_delay_secs’: None, ‘_session_creation_timeout_secs’: 7200, ‘_service’: None, ‘_cluster_spec’: <tensorflow.python.training.server_lib.ClusterSpec object at 0x7f81b1b3a390>, ‘_task_type’: ‘worker’, ‘_task_id’: 0, ‘_global_id_in_cluster’: 0, ‘_master’: ‘’, ‘_evaluation_master’: ‘’, ‘_is_chief’: True, ‘_num_ps_replicas’: 0, ‘_num_worker_replicas’: 1}
[MaskRCNN] INFO : Loading pretrained model…
INFO:tensorflow:Done calling model_fn.
[MaskRCNN] WARNING : Checkpoint is missing variable [l2/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l2/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [l3/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l3/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [l4/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l4/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [l5/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l5/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d2/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d2/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d3/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d3/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d4/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d4/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d5/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d5/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-class/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-class/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-box/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-box/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc6/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc6/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc7/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc7/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [class-predict/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [class-predict/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [box-predict/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [box-predict/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l0/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l0/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l1/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l1/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l2/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l2/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l3/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l3/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [conv5-mask/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [conv5-mask/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask_fcn_logits/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask_fcn_logits/bias]
INFO:tensorflow:Graph was finalized.
INFO:tensorflow:Running local_init_op.
INFO:tensorflow:Done running local_init_op.
fatal: not a git repository (or any of the parent directories): .git
[MaskRCNN] INFO : ============================ GIT REPOSITORY ============================
[MaskRCNN] INFO : BRANCH NAME:
[MaskRCNN] INFO : %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
[MaskRCNN] INFO : ============================ MODEL STATISTICS ===========================
[MaskRCNN] INFO : # Model Weights: 28,558,811
[MaskRCNN] INFO : # Trainable Weights: 43,975,515
[MaskRCNN] INFO : ============================ TRAINABLE VARIABLES ========================
[MaskRCNN] INFO : [#0001] conv1/kernel:0 => (7, 7, 3, 64)
[MaskRCNN] INFO : [#0002] bn_conv1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0003] bn_conv1/beta:0 => (64,)
[MaskRCNN] INFO : [#0004] block_1a_conv_1/kernel:0 => (1, 1, 64, 64)
[MaskRCNN] INFO : [#0005] block_1a_bn_1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0006] block_1a_bn_1/beta:0 => (64,)
[MaskRCNN] INFO : [#0007] block_1a_conv_2/kernel:0 => (3, 3, 64, 64)
[MaskRCNN] INFO : [#0008] block_1a_bn_2/gamma:0 => (64,)
[MaskRCNN] INFO : [#0009] block_1a_bn_2/beta:0 => (64,)
[MaskRCNN] INFO : [#0010] block_1a_conv_3/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0011] block_1a_bn_3/gamma:0 => (256,)
[MaskRCNN] INFO : [#0012] block_1a_bn_3/beta:0 => (256,)
[MaskRCNN] INFO : [#0013] block_1a_conv_shortcut/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0014] block_1a_bn_shortcut/gamma:0 => (256,)
[MaskRCNN] INFO : [#0015] block_1a_bn_shortcut/beta:0 => (256,)
[MaskRCNN] INFO : [#0016] block_1b_conv_1/kernel:0 => (1, 1, 256, 64)
[MaskRCNN] INFO : [#0017] block_1b_bn_1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0018] block_1b_bn_1/beta:0 => (64,)
[MaskRCNN] INFO : [#0019] block_1b_conv_2/kernel:0 => (3, 3, 64, 64)
[MaskRCNN] INFO : [#0020] block_1b_bn_2/gamma:0 => (64,)
[MaskRCNN] INFO : [#0021] block_1b_bn_2/beta:0 => (64,)
[MaskRCNN] INFO : [#0022] block_1b_conv_3/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0023] block_1b_bn_3/gamma:0 => (256,)
[MaskRCNN] INFO : [#0024] block_1b_bn_3/beta:0 => (256,)
[MaskRCNN] INFO : [#0025] block_1c_conv_1/kernel:0 => (1, 1, 256, 64)
[MaskRCNN] INFO : [#0026] block_1c_bn_1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0027] block_1c_bn_1/beta:0 => (64,)
[MaskRCNN] INFO : [#0028] block_1c_conv_2/kernel:0 => (3, 3, 64, 64)
[MaskRCNN] INFO : [#0029] block_1c_bn_2/gamma:0 => (64,)
[MaskRCNN] INFO : [#0030] block_1c_bn_2/beta:0 => (64,)
[MaskRCNN] INFO : [#0031] block_1c_conv_3/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0032] block_1c_bn_3/gamma:0 => (256,)
[MaskRCNN] INFO : [#0033] block_1c_bn_3/beta:0 => (256,)
[MaskRCNN] INFO : [#0034] block_2a_conv_1/kernel:0 => (1, 1, 256, 128)
[MaskRCNN] INFO : [#0035] block_2a_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0036] block_2a_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0037] block_2a_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0038] block_2a_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0039] block_2a_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0040] block_2a_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0041] block_2a_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0042] block_2a_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0043] block_2a_conv_shortcut/kernel:0 => (1, 1, 256, 512)
[MaskRCNN] INFO : [#0044] block_2a_bn_shortcut/gamma:0 => (512,)
[MaskRCNN] INFO : [#0045] block_2a_bn_shortcut/beta:0 => (512,)
[MaskRCNN] INFO : [#0046] block_2b_conv_1/kernel:0 => (1, 1, 512, 128)
[MaskRCNN] INFO : [#0047] block_2b_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0048] block_2b_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0049] block_2b_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0050] block_2b_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0051] block_2b_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0052] block_2b_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0053] block_2b_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0054] block_2b_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0055] block_2c_conv_1/kernel:0 => (1, 1, 512, 128)
[MaskRCNN] INFO : [#0056] block_2c_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0057] block_2c_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0058] block_2c_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0059] block_2c_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0060] block_2c_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0061] block_2c_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0062] block_2c_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0063] block_2c_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0064] block_2d_conv_1/kernel:0 => (1, 1, 512, 128)
[MaskRCNN] INFO : [#0065] block_2d_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0066] block_2d_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0067] block_2d_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0068] block_2d_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0069] block_2d_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0070] block_2d_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0071] block_2d_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0072] block_2d_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0073] block_3a_conv_1/kernel:0 => (1, 1, 512, 256)
[MaskRCNN] INFO : [#0074] block_3a_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0075] block_3a_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0076] block_3a_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0077] block_3a_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0078] block_3a_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0079] block_3a_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0080] block_3a_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0081] block_3a_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0082] block_3a_conv_shortcut/kernel:0 => (1, 1, 512, 1024)
[MaskRCNN] INFO : [#0083] block_3a_bn_shortcut/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0084] block_3a_bn_shortcut/beta:0 => (1024,)
[MaskRCNN] INFO : [#0085] block_3b_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0086] block_3b_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0087] block_3b_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0088] block_3b_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0089] block_3b_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0090] block_3b_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0091] block_3b_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0092] block_3b_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0093] block_3b_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0094] block_3c_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0095] block_3c_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0096] block_3c_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0097] block_3c_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0098] block_3c_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0099] block_3c_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0100] block_3c_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0101] block_3c_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0102] block_3c_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0103] block_3d_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0104] block_3d_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0105] block_3d_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0106] block_3d_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0107] block_3d_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0108] block_3d_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0109] block_3d_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0110] block_3d_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0111] block_3d_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0112] block_3e_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0113] block_3e_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0114] block_3e_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0115] block_3e_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0116] block_3e_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0117] block_3e_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0118] block_3e_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0119] block_3e_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0120] block_3e_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0121] block_3f_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0122] block_3f_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0123] block_3f_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0124] block_3f_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0125] block_3f_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0126] block_3f_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0127] block_3f_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0128] block_3f_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0129] block_3f_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0130] block_4a_conv_1/kernel:0 => (1, 1, 1024, 512)
[MaskRCNN] INFO : [#0131] block_4a_bn_1/gamma:0 => (512,)
[MaskRCNN] INFO : [#0132] block_4a_bn_1/beta:0 => (512,)
[MaskRCNN] INFO : [#0133] block_4a_conv_2/kernel:0 => (3, 3, 512, 512)
[MaskRCNN] INFO : [#0134] block_4a_bn_2/gamma:0 => (512,)
[MaskRCNN] INFO : [#0135] block_4a_bn_2/beta:0 => (512,)
[MaskRCNN] INFO : [#0136] block_4a_conv_3/kernel:0 => (1, 1, 512, 2048)
[MaskRCNN] INFO : [#0137] block_4a_bn_3/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0138] block_4a_bn_3/beta:0 => (2048,)
[MaskRCNN] INFO : [#0139] block_4a_conv_shortcut/kernel:0 => (1, 1, 1024, 2048)
[MaskRCNN] INFO : [#0140] block_4a_bn_shortcut/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0141] block_4a_bn_shortcut/beta:0 => (2048,)
[MaskRCNN] INFO : [#0142] block_4b_conv_1/kernel:0 => (1, 1, 2048, 512)
[MaskRCNN] INFO : [#0143] block_4b_bn_1/gamma:0 => (512,)
[MaskRCNN] INFO : [#0144] block_4b_bn_1/beta:0 => (512,)
[MaskRCNN] INFO : [#0145] block_4b_conv_2/kernel:0 => (3, 3, 512, 512)
[MaskRCNN] INFO : [#0146] block_4b_bn_2/gamma:0 => (512,)
[MaskRCNN] INFO : [#0147] block_4b_bn_2/beta:0 => (512,)
[MaskRCNN] INFO : [#0148] block_4b_conv_3/kernel:0 => (1, 1, 512, 2048)
[MaskRCNN] INFO : [#0149] block_4b_bn_3/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0150] block_4b_bn_3/beta:0 => (2048,)
[MaskRCNN] INFO : [#0151] block_4c_conv_1/kernel:0 => (1, 1, 2048, 512)
[MaskRCNN] INFO : [#0152] block_4c_bn_1/gamma:0 => (512,)
[MaskRCNN] INFO : [#0153] block_4c_bn_1/beta:0 => (512,)
[MaskRCNN] INFO : [#0154] block_4c_conv_2/kernel:0 => (3, 3, 512, 512)
[MaskRCNN] INFO : [#0155] block_4c_bn_2/gamma:0 => (512,)
[MaskRCNN] INFO : [#0156] block_4c_bn_2/beta:0 => (512,)
[MaskRCNN] INFO : [#0157] block_4c_conv_3/kernel:0 => (1, 1, 512, 2048)
[MaskRCNN] INFO : [#0158] block_4c_bn_3/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0159] block_4c_bn_3/beta:0 => (2048,)
[MaskRCNN] INFO : [#0160] l2/kernel:0 => (1, 1, 256, 256)
[MaskRCNN] INFO : [#0161] l2/bias:0 => (256,)
[MaskRCNN] INFO : [#0162] l3/kernel:0 => (1, 1, 512, 256)
[MaskRCNN] INFO : [#0163] l3/bias:0 => (256,)
[MaskRCNN] INFO : [#0164] l4/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0165] l4/bias:0 => (256,)
[MaskRCNN] INFO : [#0166] l5/kernel:0 => (1, 1, 2048, 256)
[MaskRCNN] INFO : [#0167] l5/bias:0 => (256,)
[MaskRCNN] INFO : [#0168] post_hoc_d2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0169] post_hoc_d2/bias:0 => (256,)
[MaskRCNN] INFO : [#0170] post_hoc_d3/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0171] post_hoc_d3/bias:0 => (256,)
[MaskRCNN] INFO : [#0172] post_hoc_d4/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0173] post_hoc_d4/bias:0 => (256,)
[MaskRCNN] INFO : [#0174] post_hoc_d5/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0175] post_hoc_d5/bias:0 => (256,)
[MaskRCNN] INFO : [#0176] rpn/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0177] rpn/bias:0 => (256,)
[MaskRCNN] INFO : [#0178] rpn-class/kernel:0 => (1, 1, 256, 3)
[MaskRCNN] INFO : [#0179] rpn-class/bias:0 => (3,)
[MaskRCNN] INFO : [#0180] rpn-box/kernel:0 => (1, 1, 256, 12)
[MaskRCNN] INFO : [#0181] rpn-box/bias:0 => (12,)
[MaskRCNN] INFO : [#0182] fc6/kernel:0 => (12544, 1024)
[MaskRCNN] INFO : [#0183] fc6/bias:0 => (1024,)
[MaskRCNN] INFO : [#0184] fc7/kernel:0 => (1024, 1024)
[MaskRCNN] INFO : [#0185] fc7/bias:0 => (1024,)
[MaskRCNN] INFO : [#0186] class-predict/kernel:0 => (1024, 2)
[MaskRCNN] INFO : [#0187] class-predict/bias:0 => (2,)
[MaskRCNN] INFO : [#0188] box-predict/kernel:0 => (1024, 8)
[MaskRCNN] INFO : [#0189] box-predict/bias:0 => (8,)
[MaskRCNN] INFO : [#0190] mask-conv-l0/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0191] mask-conv-l0/bias:0 => (256,)
[MaskRCNN] INFO : [#0192] mask-conv-l1/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0193] mask-conv-l1/bias:0 => (256,)
[MaskRCNN] INFO : [#0194] mask-conv-l2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0195] mask-conv-l2/bias:0 => (256,)
[MaskRCNN] INFO : [#0196] mask-conv-l3/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0197] mask-conv-l3/bias:0 => (256,)
[MaskRCNN] INFO : [#0198] conv5-mask/kernel:0 => (2, 2, 256, 256)
[MaskRCNN] INFO : [#0199] conv5-mask/bias:0 => (256,)
[MaskRCNN] INFO : [#0200] mask_fcn_logits/kernel:0 => (1, 1, 256, 2)
[MaskRCNN] INFO : [#0201] mask_fcn_logits/bias:0 => (2,)
[MaskRCNN] INFO : # ============================================= #
[MaskRCNN] INFO : Start Training
[MaskRCNN] INFO : # %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% #
[GPU 00] Restoring pretrained weights (265 Tensors)
[MaskRCNN] INFO : Pretrained weights loaded with success…
[MaskRCNN] INFO : Saving checkpoints for 0 into /workspace/tao-experiments/mask_rcnn/experiment_dir_unpruned/model.step-0.tlt.
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun.real noticed that process rank 1 with PID 0 on node 41afb24bd50e exited on signal 9 (Killed).
2022-01-27 09:04:07,841 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Can you use a new result folder and retry?
Hi, yah I deleted the result folder $USER_EXPERIMENT_DIR/experiment_dir_unpruned and recreating the folder using !mkdir -p $LOCAL_EXPERIMENT_DIR/experiment_dir_unpruned
but the issue still persists. It creates model.step-0.tlt and saves it then the job gets terminated without any warning or error
Can you share the training spec?
This is maskrcnn_train_resnet50.txt:
seed: 123
use_amp: False
warmup_steps: 1000
checkpoint: “/workspace/tao-experiments/mask_rcnn/pretrained_resnet50/pretrained_instance_segmentation_vresnet50/resnet50.hdf5”
learning_rate_steps: “[120000, 160000]”
learning_rate_decay_levels: “[0.1, 0.01]”
total_steps: 280000
train_batch_size: 2
eval_batch_size: 4
num_steps_per_eval: 5000
momentum: 0.9
l2_weight_decay: 0.0001
warmup_learning_rate: 0.0001
init_learning_rate: 0.01
data_config{
image_size: “(832, 1344)”
augment_input_data: True
eval_samples: 500
training_file_pattern: “/workspace/tao-experiments/data/coco_train*.tfrecord”
validation_file_pattern: “/workspace/tao-experiments/data/coco_val*.tfrecord”
val_json_file: “/workspace/tao-experiments/data/annotations/val.json”
# dataset specific parameters
num_classes: 2
skip_crowd_during_training: True
maskrcnn_config {
nlayers: 50
arch: “resnet”
freeze_bn: True
freeze_blocks: “[0,1]”
gt_mask_size: 112
# Region Proposal Network
rpn_positive_overlap: 0.7
rpn_negative_overlap: 0.3
rpn_batch_size_per_im: 256
rpn_fg_fraction: 0.5
rpn_min_size: 0.
# Proposal layer.
batch_size_per_im: 512
fg_fraction: 0.25
fg_thresh: 0.5
bg_thresh_hi: 0.5
bg_thresh_lo: 0.
# Faster-RCNN heads.
fast_rcnn_mlp_head_dim: 1024
bbox_reg_weights: "(10., 10., 5., 5.)"
# Mask-RCNN heads.
include_mask: True
mrcnn_resolution: 28
# training
train_rpn_pre_nms_topn: 2000
train_rpn_post_nms_topn: 1000
train_rpn_nms_threshold: 0.7
# evaluation
test_detections_per_image: 100
test_nms: 0.5
test_rpn_pre_nms_topn: 1000
test_rpn_post_nms_topn: 1000
test_rpn_nms_thresh: 0.7
# model architecture
min_level: 2
max_level: 6
num_scales: 1
aspect_ratios: "[(1.0, 1.0), (1.4, 0.7), (0.7, 1.4)]"
anchor_scale: 8
# localization loss
rpn_box_loss_weight: 1.0
fast_rcnn_box_loss_weight: 1.0
mrcnn_weight_loss_mask: 1.0
Can you use only one of the tfrecord files and retry?
From what I understood you want me to train on only one tfrecord and see what happens right? I’ll try that
Yes, please try to train with less dataset.
Hi sorry I took a long time. So let me give some context, I created tfrecords before using the create_coco_tf_record.py that comes with the notebook, but the problem was that it needed captions, so I created dummy captions and it worked but then I could not complete training like you see above. I created new tfrecord using (https://github.com/tensorflow/models/blob/master/research/object_detection/dataset_tools/create_coco_tf_record.py) but now I get this error bellow. This was run using only one tfrecord just like you asked. (This would not have happened before using the old tfrecords, before it would just stop)
[MaskRCNN] INFO : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
[MaskRCNN] INFO : Training Performance Summary
DLL 2022-01-27 08:44:52.519272 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2022-01-27 08:44:52.519369 - : Training Performance Summary
DLL 2022-01-27 08:44:52.519401 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1365, in _do_call
return fn(*args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1350, in _run_fn
target_list, run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
(0) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_15647}} Requested more than 0 entries, but params is empty. Params shape: [0,1]
[[{{node parser/process_boxes_classes_indices_for_training/GatherNd}}]]
[[IteratorGetNext]]
[[MLP/multilevel_propose_rois/level_4/combined_non_max_suppression/CombinedNonMaxSuppression/_5741]]
(1) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_15647}} Requested more than 0 entries, but params is empty. Params shape: [0,1]
[[IteratorGetNext]]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py”, line 222, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py”, line 218, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py”, line 85, in run_executer
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py”, line 399, in train_and_eval
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 370, in train
loss = self._train_model(input_fn, hooks, saving_listeners)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 1161, in _train_model
return self._train_model_default(input_fn, hooks, saving_listeners)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 1195, in _train_model_default
saving_listeners)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 1494, in _train_with_estimator_spec
_, loss = mon_sess.run([estimator_spec.train_op, estimator_spec.loss])
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 754, in run
run_metadata=run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1259, in run
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1360, in run
raise six.reraise(*original_exc_info)
File “/usr/local/lib/python3.6/dist-packages/six.py”, line 696, in reraise
raise value
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1345, in run
return self._sess.run(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1418, in run
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1176, in run
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 956, in run
run_metadata_ptr)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1180, in _run
feed_dict_tensor, options, run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1359, in _do_run
run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1384, in _do_call
raise type(e)(node_def, op, message)
(0) Invalid argument: Requested more than 0 entries, but params is empty. Params shape: [0,1]
[[IteratorGetNext]]
(1) Invalid argument: Requested more than 0 entries, but params is empty. Params shape: [0,1]
[[IteratorGetNext]]
[MaskRCNN] ERROR : Job finished with an uncaught exception: FAILURE
DLL 2022-01-27 08:44:52.519438 - Average_throughput : -1.0 samples/sec
DLL 2022-01-27 08:44:52.519463 - Total processed steps : 1
DLL 2022-01-27 08:44:52.519489 - Total_processing_time : 0h 00m 00s
[MaskRCNN] INFO : Average throughput: -1.0 samples/sec
[MaskRCNN] INFO : Total processed steps: 1
[MaskRCNN] INFO : Total processing time: 0h 00m 00s
DLL 2022-01-27 08:44:52.519710 - : ==================== Metrics ====================
[MaskRCNN] INFO : ==================== Metrics ====================
mpirun.real detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[9996,1],0]
Exit code: 1
2022-01-27 11:44:59,697 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
@Morganh I’ll recreate the old tfrecords to recreate the original problem and try it with one tfrecord. give me 10 mins. I’m not sure why though the tfrecords I created with models/create_coco_tf_record.py at master · tensorflow/models · GitHub dont’t work.
@Morganh So I tried it with the old tfrecords, the training starts but then the training loss gets bigger and bigger over time until it diverges and becomes NAN.
So to summarize the issues I got trying different things:
1- when I try generating the tfrecords with models/create_coco_tf_record.py at master · tensorflow/models · GitHub I get " Requested more than 0 entries, but params is empty. Params shape: [0,1]" (The traceback above)
2- when I try with the tfrecords that require captions so I use dummy captions, the training starts and then as time goes on it gets bigger and bigger until it divereges and becomes NAN. (I tried reducing the learning rate)
Any Ideas why this is happening?
Firstly, please use the create_coco_tf_record.py inside the spec folder of cv_samples_v1.3.0 files. Download them from TAO Toolkit Quick Start Guide - NVIDIA Docs
As mentioned in the jupyter notebook, iIf your data doesn’t have caption groundtruth or test set, you can modify download_and_preprocess_coco.sh and create_coco_tf_record.py by commenting out corresponding variables.
More, seems that you are running with 2gpus, please run with at least two tfrecord files.
And could you refer to Train mask-rcnn failure - #5 by gao-yan ?
That user solved the issue since
Some objects in the images only have bbox without segmentation, so I remove these objects and generate the dataset again.
