• Hardware V100
• Network Type Mask_rcnn
• TLT Version TAO toolkit_version: 3.21.08
• Training spec file(If have, please share here)
• How to reproduce the issue ?
tao mask_rcnn train \
-e /workspace/tao-experiments/mask_rcnn/specs/maskrcnn_train_resnet50.txt \
-d /workspace/tao-experiments/mask_rcnn/exp_unpruned \
-k nvidia_tlt \
--gpus 1 \
--gpu_index 6
logs as following:
2021-11-01 20:40:27,309 [INFO] root: Registry: [‘nvcr.io’]
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
[MaskRCNN] INFO : Loading pretrained model…
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py:220: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py:223: The name tf.train.Saver is deprecated. Please use tf.compat.v1.train.Saver instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py:224: The name tf.keras.backend.get_session is deprecated. Please use tf.compat.v1.keras.backend.get_session instead.
[MaskRCNN] INFO : Create EncryptCheckpointSaverHook.
[MaskRCNN] INFO : =================================
[MaskRCNN] INFO : Start training cycle 01
[MaskRCNN] INFO : =================================WARNING:tensorflow:Entity <function InputReader.call.._prefetch_dataset at 0x7f6c8d197e18> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,
export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <function InputReader.call.._prefetch_dataset at 0x7f6c8d197e18>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.WARNING:tensorflow:Entity <function dataset_parser at 0x7f6cb0bead90> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,
) and attach the full output. Cause: Unable to locate the source code of <function dataset_parser at 0x7f6cb0bead90>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:The operationtf.image.convert_image_dtype
will be skipped since the input and output dtypes are identical.
[MaskRCNN] INFO : ***********************
[MaskRCNN] INFO : Building model graph…
WARNING:tensorflow:Entity <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f6c8c873f60>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f6c8c873f60>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f6c87b45eb8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f6c87b45eb8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS… Scope: MLP/multilevel_propose_rois/level_2/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS… Scope: MLP/multilevel_propose_rois/level_3/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS… Scope: MLP/multilevel_propose_rois/level_4/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS… Scope: MLP/multilevel_propose_rois/level_5/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS… Scope: MLP/multilevel_propose_rois/level_6/
WARNING:tensorflow:Entity <bound method ProposalAssignment.call of <iva.mask_rcnn.layers.proposal_assignment_layer.ProposalAssignment object at 0x7f6c87b484a8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method ProposalAssignment.call of <iva.mask_rcnn.layers.proposal_assignment_layer.ProposalAssignment object at 0x7f6c87b484a8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f6c879ecdd8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f6c879ecdd8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c87586438>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c87586438>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c87a208d0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c87a208d0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c87586518>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c87586518>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method BoxTargetEncoder.call of <iva.mask_rcnn.layers.box_target_encoder.BoxTargetEncoder object at 0x7f6c875bc748>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method BoxTargetEncoder.call of <iva.mask_rcnn.layers.box_target_encoder.BoxTargetEncoder object at 0x7f6c875bc748>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ForegroundSelectorForMask.call of <iva.mask_rcnn.layers.foreground_selector_for_mask.ForegroundSelectorForMask object at 0x7f6c87586278>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method ForegroundSelectorForMask.call of <iva.mask_rcnn.layers.foreground_selector_for_mask.ForegroundSelectorForMask object at 0x7f6c87586278>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f6c875476d8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f6c875476d8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c873f6048>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f6c873f6048>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f6c873f6128>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f6c873f6128>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
4 ops no flops stats due to incomplete shapes.
Parsing Inputs…
[MaskRCNN] INFO : [Training Compute Statistics] 542.3 GFLOPS/image
WARNING:tensorflow:Entity <bound method MaskTargetsLayer.call of <iva.mask_rcnn.layers.mask_targets_layer.MaskTargetsLayer object at 0x7f6c867b30f0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux,export AUTOGRAPH_VERBOSITY=10
) and attach the full output. Cause: Unable to locate the source code of <bound method MaskTargetsLayer.call of <iva.mask_rcnn.layers.mask_targets_layer.MaskTargetsLayer object at 0x7f6c867b30f0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:
The TensorFlow contrib module will not be included in TensorFlow 2.0.
For more information, please see:
- community/20180907-contrib-sunset.md at master · tensorflow/community · GitHub
- GitHub - tensorflow/addons: Useful extra functionality for TensorFlow 2.x maintained by SIG-addons
- GitHub - tensorflow/io: Dataset, streaming, and file system extensions maintained by TensorFlow SIG-IO (for I/O related ops)
If you depend on functionality not listed there, please file an issue.[MaskRCNN] WARNING : Checkpoint is missing variable [l2/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l2/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [l3/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l3/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [l4/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l4/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [l5/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [l5/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d2/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d2/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d3/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d3/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d4/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d4/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d5/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [post_hoc_d5/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-class/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-class/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-box/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [rpn-box/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc6/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc6/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc7/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [fc7/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [class-predict/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [class-predict/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [box-predict/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [box-predict/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l0/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l0/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l1/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l1/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l2/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l2/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l3/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask-conv-l3/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [conv5-mask/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [conv5-mask/bias]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask_fcn_logits/kernel]
[MaskRCNN] WARNING : Checkpoint is missing variable [mask_fcn_logits/bias]
fatal: not a git repository (or any of the parent directories): .git
[MaskRCNN] INFO : ============================ GIT REPOSITORY ============================
[MaskRCNN] INFO : BRANCH NAME:
[MaskRCNN] INFO : %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%[MaskRCNN] INFO : ============================ MODEL STATISTICS ===========================
[MaskRCNN] INFO : # Model Weights: 28,580,339
[MaskRCNN] INFO : # Trainable Weights: 43,997,043
[MaskRCNN] INFO : %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%[MaskRCNN] INFO : ============================ TRAINABLE VARIABLES ========================
[MaskRCNN] INFO : [#0001] conv1/kernel:0 => (7, 7, 3, 64)
[MaskRCNN] INFO : [#0002] bn_conv1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0003] bn_conv1/beta:0 => (64,)
[MaskRCNN] INFO : [#0004] block_1a_conv_1/kernel:0 => (1, 1, 64, 64)
[MaskRCNN] INFO : [#0005] block_1a_bn_1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0006] block_1a_bn_1/beta:0 => (64,)
[MaskRCNN] INFO : [#0007] block_1a_conv_2/kernel:0 => (3, 3, 64, 64)
[MaskRCNN] INFO : [#0008] block_1a_bn_2/gamma:0 => (64,)
[MaskRCNN] INFO : [#0009] block_1a_bn_2/beta:0 => (64,)
[MaskRCNN] INFO : [#0010] block_1a_conv_3/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0011] block_1a_bn_3/gamma:0 => (256,)
[MaskRCNN] INFO : [#0012] block_1a_bn_3/beta:0 => (256,)
[MaskRCNN] INFO : [#0013] block_1a_conv_shortcut/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0014] block_1a_bn_shortcut/gamma:0 => (256,)
[MaskRCNN] INFO : [#0015] block_1a_bn_shortcut/beta:0 => (256,)
[MaskRCNN] INFO : [#0016] block_1b_conv_1/kernel:0 => (1, 1, 256, 64)
[MaskRCNN] INFO : [#0017] block_1b_bn_1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0018] block_1b_bn_1/beta:0 => (64,)
[MaskRCNN] INFO : [#0019] block_1b_conv_2/kernel:0 => (3, 3, 64, 64)
[MaskRCNN] INFO : [#0020] block_1b_bn_2/gamma:0 => (64,)
[MaskRCNN] INFO : [#0021] block_1b_bn_2/beta:0 => (64,)
[MaskRCNN] INFO : [#0022] block_1b_conv_3/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0023] block_1b_bn_3/gamma:0 => (256,)
[MaskRCNN] INFO : [#0024] block_1b_bn_3/beta:0 => (256,)
[MaskRCNN] INFO : [#0025] block_1c_conv_1/kernel:0 => (1, 1, 256, 64)
[MaskRCNN] INFO : [#0026] block_1c_bn_1/gamma:0 => (64,)
[MaskRCNN] INFO : [#0027] block_1c_bn_1/beta:0 => (64,)
[MaskRCNN] INFO : [#0028] block_1c_conv_2/kernel:0 => (3, 3, 64, 64)
[MaskRCNN] INFO : [#0029] block_1c_bn_2/gamma:0 => (64,)
[MaskRCNN] INFO : [#0030] block_1c_bn_2/beta:0 => (64,)
[MaskRCNN] INFO : [#0031] block_1c_conv_3/kernel:0 => (1, 1, 64, 256)
[MaskRCNN] INFO : [#0032] block_1c_bn_3/gamma:0 => (256,)
[MaskRCNN] INFO : [#0033] block_1c_bn_3/beta:0 => (256,)
[MaskRCNN] INFO : [#0034] block_2a_conv_1/kernel:0 => (1, 1, 256, 128)
[MaskRCNN] INFO : [#0035] block_2a_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0036] block_2a_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0037] block_2a_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0038] block_2a_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0039] block_2a_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0040] block_2a_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0041] block_2a_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0042] block_2a_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0043] block_2a_conv_shortcut/kernel:0 => (1, 1, 256, 512)
[MaskRCNN] INFO : [#0044] block_2a_bn_shortcut/gamma:0 => (512,)
[MaskRCNN] INFO : [#0045] block_2a_bn_shortcut/beta:0 => (512,)
[MaskRCNN] INFO : [#0046] block_2b_conv_1/kernel:0 => (1, 1, 512, 128)
[MaskRCNN] INFO : [#0047] block_2b_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0048] block_2b_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0049] block_2b_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0050] block_2b_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0051] block_2b_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0052] block_2b_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0053] block_2b_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0054] block_2b_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0055] block_2c_conv_1/kernel:0 => (1, 1, 512, 128)
[MaskRCNN] INFO : [#0056] block_2c_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0057] block_2c_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0058] block_2c_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0059] block_2c_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0060] block_2c_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0061] block_2c_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0062] block_2c_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0063] block_2c_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0064] block_2d_conv_1/kernel:0 => (1, 1, 512, 128)
[MaskRCNN] INFO : [#0065] block_2d_bn_1/gamma:0 => (128,)
[MaskRCNN] INFO : [#0066] block_2d_bn_1/beta:0 => (128,)
[MaskRCNN] INFO : [#0067] block_2d_conv_2/kernel:0 => (3, 3, 128, 128)
[MaskRCNN] INFO : [#0068] block_2d_bn_2/gamma:0 => (128,)
[MaskRCNN] INFO : [#0069] block_2d_bn_2/beta:0 => (128,)
[MaskRCNN] INFO : [#0070] block_2d_conv_3/kernel:0 => (1, 1, 128, 512)
[MaskRCNN] INFO : [#0071] block_2d_bn_3/gamma:0 => (512,)
[MaskRCNN] INFO : [#0072] block_2d_bn_3/beta:0 => (512,)
[MaskRCNN] INFO : [#0073] block_3a_conv_1/kernel:0 => (1, 1, 512, 256)
[MaskRCNN] INFO : [#0074] block_3a_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0075] block_3a_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0076] block_3a_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0077] block_3a_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0078] block_3a_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0079] block_3a_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0080] block_3a_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0081] block_3a_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0082] block_3a_conv_shortcut/kernel:0 => (1, 1, 512, 1024)
[MaskRCNN] INFO : [#0083] block_3a_bn_shortcut/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0084] block_3a_bn_shortcut/beta:0 => (1024,)
[MaskRCNN] INFO : [#0085] block_3b_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0086] block_3b_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0087] block_3b_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0088] block_3b_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0089] block_3b_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0090] block_3b_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0091] block_3b_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0092] block_3b_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0093] block_3b_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0094] block_3c_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0095] block_3c_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0096] block_3c_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0097] block_3c_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0098] block_3c_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0099] block_3c_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0100] block_3c_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0101] block_3c_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0102] block_3c_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0103] block_3d_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0104] block_3d_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0105] block_3d_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0106] block_3d_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0107] block_3d_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0108] block_3d_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0109] block_3d_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0110] block_3d_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0111] block_3d_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0112] block_3e_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0113] block_3e_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0114] block_3e_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0115] block_3e_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0116] block_3e_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0117] block_3e_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0118] block_3e_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0119] block_3e_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0120] block_3e_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0121] block_3f_conv_1/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0122] block_3f_bn_1/gamma:0 => (256,)
[MaskRCNN] INFO : [#0123] block_3f_bn_1/beta:0 => (256,)
[MaskRCNN] INFO : [#0124] block_3f_conv_2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0125] block_3f_bn_2/gamma:0 => (256,)
[MaskRCNN] INFO : [#0126] block_3f_bn_2/beta:0 => (256,)
[MaskRCNN] INFO : [#0127] block_3f_conv_3/kernel:0 => (1, 1, 256, 1024)
[MaskRCNN] INFO : [#0128] block_3f_bn_3/gamma:0 => (1024,)
[MaskRCNN] INFO : [#0129] block_3f_bn_3/beta:0 => (1024,)
[MaskRCNN] INFO : [#0130] block_4a_conv_1/kernel:0 => (1, 1, 1024, 512)
[MaskRCNN] INFO : [#0131] block_4a_bn_1/gamma:0 => (512,)
[MaskRCNN] INFO : [#0132] block_4a_bn_1/beta:0 => (512,)
[MaskRCNN] INFO : [#0133] block_4a_conv_2/kernel:0 => (3, 3, 512, 512)
[MaskRCNN] INFO : [#0134] block_4a_bn_2/gamma:0 => (512,)
[MaskRCNN] INFO : [#0135] block_4a_bn_2/beta:0 => (512,)
[MaskRCNN] INFO : [#0136] block_4a_conv_3/kernel:0 => (1, 1, 512, 2048)
[MaskRCNN] INFO : [#0137] block_4a_bn_3/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0138] block_4a_bn_3/beta:0 => (2048,)
[MaskRCNN] INFO : [#0139] block_4a_conv_shortcut/kernel:0 => (1, 1, 1024, 2048)
[MaskRCNN] INFO : [#0140] block_4a_bn_shortcut/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0141] block_4a_bn_shortcut/beta:0 => (2048,)
[MaskRCNN] INFO : [#0142] block_4b_conv_1/kernel:0 => (1, 1, 2048, 512)
[MaskRCNN] INFO : [#0143] block_4b_bn_1/gamma:0 => (512,)
[MaskRCNN] INFO : [#0144] block_4b_bn_1/beta:0 => (512,)
[MaskRCNN] INFO : [#0145] block_4b_conv_2/kernel:0 => (3, 3, 512, 512)
[MaskRCNN] INFO : [#0146] block_4b_bn_2/gamma:0 => (512,)
[MaskRCNN] INFO : [#0147] block_4b_bn_2/beta:0 => (512,)
[MaskRCNN] INFO : [#0148] block_4b_conv_3/kernel:0 => (1, 1, 512, 2048)
[MaskRCNN] INFO : [#0149] block_4b_bn_3/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0150] block_4b_bn_3/beta:0 => (2048,)
[MaskRCNN] INFO : [#0151] block_4c_conv_1/kernel:0 => (1, 1, 2048, 512)
[MaskRCNN] INFO : [#0152] block_4c_bn_1/gamma:0 => (512,)
[MaskRCNN] INFO : [#0153] block_4c_bn_1/beta:0 => (512,)
[MaskRCNN] INFO : [#0154] block_4c_conv_2/kernel:0 => (3, 3, 512, 512)
[MaskRCNN] INFO : [#0155] block_4c_bn_2/gamma:0 => (512,)
[MaskRCNN] INFO : [#0156] block_4c_bn_2/beta:0 => (512,)
[MaskRCNN] INFO : [#0157] block_4c_conv_3/kernel:0 => (1, 1, 512, 2048)
[MaskRCNN] INFO : [#0158] block_4c_bn_3/gamma:0 => (2048,)
[MaskRCNN] INFO : [#0159] block_4c_bn_3/beta:0 => (2048,)
[MaskRCNN] INFO : [#0160] l2/kernel:0 => (1, 1, 256, 256)
[MaskRCNN] INFO : [#0161] l2/bias:0 => (256,)
[MaskRCNN] INFO : [#0162] l3/kernel:0 => (1, 1, 512, 256)
[MaskRCNN] INFO : [#0163] l3/bias:0 => (256,)
[MaskRCNN] INFO : [#0164] l4/kernel:0 => (1, 1, 1024, 256)
[MaskRCNN] INFO : [#0165] l4/bias:0 => (256,)
[MaskRCNN] INFO : [#0166] l5/kernel:0 => (1, 1, 2048, 256)
[MaskRCNN] INFO : [#0167] l5/bias:0 => (256,)
[MaskRCNN] INFO : [#0168] post_hoc_d2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0169] post_hoc_d2/bias:0 => (256,)
[MaskRCNN] INFO : [#0170] post_hoc_d3/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0171] post_hoc_d3/bias:0 => (256,)
[MaskRCNN] INFO : [#0172] post_hoc_d4/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0173] post_hoc_d4/bias:0 => (256,)
[MaskRCNN] INFO : [#0174] post_hoc_d5/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0175] post_hoc_d5/bias:0 => (256,)
[MaskRCNN] INFO : [#0176] rpn/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0177] rpn/bias:0 => (256,)
[MaskRCNN] INFO : [#0178] rpn-class/kernel:0 => (1, 1, 256, 3)
[MaskRCNN] INFO : [#0179] rpn-class/bias:0 => (3,)
[MaskRCNN] INFO : [#0180] rpn-box/kernel:0 => (1, 1, 256, 12)
[MaskRCNN] INFO : [#0181] rpn-box/bias:0 => (12,)
[MaskRCNN] INFO : [#0182] fc6/kernel:0 => (12544, 1024)
[MaskRCNN] INFO : [#0183] fc6/bias:0 => (1024,)
[MaskRCNN] INFO : [#0184] fc7/kernel:0 => (1024, 1024)
[MaskRCNN] INFO : [#0185] fc7/bias:0 => (1024,)
[MaskRCNN] INFO : [#0186] class-predict/kernel:0 => (1024, 6)
[MaskRCNN] INFO : [#0187] class-predict/bias:0 => (6,)
[MaskRCNN] INFO : [#0188] box-predict/kernel:0 => (1024, 24)
[MaskRCNN] INFO : [#0189] box-predict/bias:0 => (24,)
[MaskRCNN] INFO : [#0190] mask-conv-l0/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0191] mask-conv-l0/bias:0 => (256,)
[MaskRCNN] INFO : [#0192] mask-conv-l1/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0193] mask-conv-l1/bias:0 => (256,)
[MaskRCNN] INFO : [#0194] mask-conv-l2/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0195] mask-conv-l2/bias:0 => (256,)
[MaskRCNN] INFO : [#0196] mask-conv-l3/kernel:0 => (3, 3, 256, 256)
[MaskRCNN] INFO : [#0197] mask-conv-l3/bias:0 => (256,)
[MaskRCNN] INFO : [#0198] conv5-mask/kernel:0 => (2, 2, 256, 256)
[MaskRCNN] INFO : [#0199] conv5-mask/bias:0 => (256,)
[MaskRCNN] INFO : [#0200] mask_fcn_logits/kernel:0 => (1, 1, 256, 6)
[MaskRCNN] INFO : [#0201] mask_fcn_logits/bias:0 => (6,)
[MaskRCNN] INFO : %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%[MaskRCNN] INFO : # ============================================= #
[MaskRCNN] INFO : Start Training
[MaskRCNN] INFO : # %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% #[GPU 00] Restoring pretrained weights (265 Tensors)
[MaskRCNN] INFO : Pretrained weights loaded with success…[MaskRCNN] INFO : Saving checkpoints for 0 into /workspace/tao-experiments/mask_rcnn/exp_unpruned/model.step-0.tlt.
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1365, in _do_call
return fn(*args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1350, in _run_fn
target_list, run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: 2 root error(s) found.
(0) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_15633}} indices[8] = [8] does not index into param shape [2,3072,4096]
[[{{node parser/process_boxes_classes_indices_for_training/GatherNd_2}}]]
[[IteratorGetNext]]
[[IteratorGetNext/_3629]]
(1) Invalid argument: {{function_node __inference_Dataset_map__map_func_set_random_wrapper_15633}} indices[8] = [8] does not index into param shape [2,3072,4096]
[[IteratorGetNext]]
0 successful operations.
0 derived errors ignored.During handling of the above exception, another exception occurred:
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py”, line 222, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py”, line 218, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py”, line 85, in run_executer
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py”, line 399, in train_and_eval
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 370, in train
loss = self._train_model(input_fn, hooks, saving_listeners)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 1161, in _train_model
return self._train_model_default(input_fn, hooks, saving_listeners)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 1195, in _train_model_default
saving_listeners)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py”, line 1494, in _train_with_estimator_spec
_, loss = mon_sess.run([estimator_spec.train_op, estimator_spec.loss])
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 754, in run
run_metadata=run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1259, in run
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1360, in run
raise six.reraise(*original_exc_info)
File “/usr/local/lib/python3.6/dist-packages/six.py”, line 696, in reraise
raise value
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1345, in run
return self._sess.run(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1418, in run
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py”, line 1176, in run
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 956, in run
run_metadata_ptr)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1180, in _run
feed_dict_tensor, options, run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1359, in _do_run
run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1384, in _do_call
raise type(e)(node_def, op, message)
(0) Invalid argument: indices[8] = [8] does not index into param shape [2,3072,4096]
[[IteratorGetNext]]
(1) Invalid argument: indices[8] = [8] does not index into param shape [2,3072,4096]
[[IteratorGetNext]]
0 derived errors ignored.[MaskRCNN] INFO : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
[MaskRCNN] INFO : Training Performance Summary
DLL 2021-11-01 12:41:50.709029 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #
DLL 2021-11-01 12:41:50.709336 - : Training Performance Summary
DLL 2021-11-01 12:41:50.709381 - : # @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ #DLL 2021-11-01 12:41:50.709432 - Average_throughput : -1.0 samples/sec
DLL 2021-11-01 12:41:50.709481 - Total processed steps : 1
DLL 2021-11-01 12:41:50.709547 - Total_processing_time : 0h 00m 00s
[MaskRCNN] INFO : Average throughput: -1.0 samples/sec
[MaskRCNN] INFO : Total processed steps: 1
[MaskRCNN] INFO : Total processing time: 0h 00m 00s
DLL 2021-11-01 12:41:50.709826 - : ==================== Metrics ====================
[MaskRCNN] INFO : ==================== Metrics ====================[MaskRCNN] ERROR : Job finished with an uncaught exception:
FAILURE
2021-11-01 20:41:55,784 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
