full log:
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/numba/cuda/envvars.py:17: NumbaWarning:
Environment variables with the 'NUMBAPRO' prefix are deprecated and consequently ignored, found use of NUMBAPRO_NVVM=/usr/local/cuda/nvvm/lib64/libnvvm.so.
For more information about alternatives visit: ('http://numba.pydata.org/numba-doc/latest/cuda/overview.html', '#cudatoolkit-lookup')
warnings.warn(errors.NumbaWarning(msg))
Environment variables with the 'NUMBAPRO' prefix are deprecated and consequently ignored, found use of NUMBAPRO_LIBDEVICE=/usr/local/cuda/nvvm/libdevice/.
2022-09-07 16:36:39,685 [INFO] iva.mask_rcnn.utils.spec_loader: Loading specification from /app/results/mm/unpruned_model/final_spec.txt
2022-09-07 16:36:39,688 [INFO] root: Loading weights from /app/results/mm/unpruned_model/model.step-245.tlt
INFO:tensorflow:Using config: {'_model_dir': '/tmp/tmpeft_f09q', '_tf_random_seed': 123, '_save_summary_steps': None, '_save_checkpoints_steps': None, '_save_checkpoints_secs': None, '_session_config': gpu_options {
allow_growth: true
force_gpu_compatible: true
allow_soft_placement: true
graph_options {
rewrite_options {
meta_optimizer_iterations: TWO
, '_keep_checkpoint_max': 20, '_keep_checkpoint_every_n_hours': None, '_log_step_count_steps': None, '_train_distribute': None, '_device_fn': None, '_protocol': None, '_eval_distribute': None, '_experimental_distribute': None, '_experimental_max_worker_delay_secs': None, '_session_creation_timeout_secs': 7200, '_service': None, '_cluster_spec': <tensorflow.python.training.server_lib.ClusterSpec object at 0x7f740f2dc5f8>, '_task_type': 'worker', '_task_id': 0, '_global_id_in_cluster': 0,'_master': '', '_evaluation_master': '', '_is_chief': True, '_num_ps_replicas': 0, '_num_worker_replicas': 1}
2022-09-07 16:36:41,372 [INFO] tensorflow: Using config: {'_model_dir': '/tmp/tmpeft_f09q', '_tf_random_seed': 123, '_save_summary_steps': None, '_save_checkpoints_steps': None, '_save_checkpoints_secs': None, '_session_config': gpu_options {
allow_growth: true
graph_options {
rewrite_options {
INFO:tensorflow:Create CheckpointSaverHook.
2022-09-07 16:36:41,373 [INFO] tensorflow: Create CheckpointSaverHook.
WARNING:tensorflow:Entity <function InputReader.__call__.<locals>._prefetch_dataset at 0x7f740f2dfd08> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <function InputReader.__call__.<locals>._prefetch_dataset at 0x7f740f2dfd08>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:41,390 [WARNING] tensorflow: Entity <function InputReader.__call__.<locals>._prefetch_dataset at 0x7f740f2dfd08> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug,set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <function InputReader.__call__.<locals>._prefetch_dataset at 0x7f740f2dfd08>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you shouldto define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
[MaskRCNN] INFO : [*] Limiting the amount of sample to: 20
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:349: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-09-07 16:36:41,403 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:349: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-09-07 16:36:41,417 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <function dataset_parser at 0x7f72d2900840> could not be transformed and will be executed as-is.Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <function dataset_parser at 0x7f72d2900840>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:41,447 [WARNING] tensorflow: Entity <function dataset_parser at 0x7f72d2900840> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <function dataset_parser at 0x7f72d2900840>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:The operation `tf.image.convert_image_dtype` will be skipped since the input and output dtypes are identical.
2022-09-07 16:36:41,460 [WARNING] tensorflow: The operation `tf.image.convert_image_dtype` will be skipped since the inputand output dtypes are identical.
2022-09-07 16:36:41,463 [WARNING] tensorflow: The operation `tf.image.convert_image_dtype` will be skipped since the inputand output dtypes are identical.
2022-09-07 16:36:41,467 [WARNING] tensorflow: The operation `tf.image.convert_image_dtype` will be skipped since the inputand output dtypes are identical.
2022-09-07 16:36:41,471 [WARNING] tensorflow: The operation `tf.image.convert_image_dtype` will be skipped since the inputand output dtypes are identical.
INFO:tensorflow:Calling model_fn.
2022-09-07 16:36:41,577 [INFO] tensorflow: Calling model_fn.
[MaskRCNN] INFO : ***********************
[MaskRCNN] INFO : Loading model graph...
WARNING:tensorflow:Entity <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f740efef550>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f740efef550>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,002 [WARNING] tensorflow: Entity <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f740efef550>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f740efef550>>. Note that functions defined in certain environments, like the interactive Python shell donot expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f740efef748>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f740efef748>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,020 [WARNING] tensorflow: Entity <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f740efef748>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f740efef748>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_2/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_3/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_4/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_5/
[MaskRCNN] INFO : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_6/
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740efef940>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740efef940>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a.py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,140 [WARNING] tensorflow: Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740efef940>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740efef940>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, youshould to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740efefdd8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740efefdd8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,228 [WARNING] tensorflow: Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740efefdd8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740efefdd8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effab38>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effab38>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,257 [WARNING] tensorflow: Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effab38>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effab38>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effac50>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effac50>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,260 [WARNING] tensorflow: Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effac50>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740effac50>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method GPUDetections.call of <iva.mask_rcnn.layers.gpu_detection_layer.GPUDetections object at 0x7f740effad68>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method GPUDetections.call of <iva.mask_rcnn.layers.gpu_detection_layer.GPUDetectionsobject at 0x7f740effad68>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,263 [WARNING] tensorflow: Entity <bound method GPUDetections.call of <iva.mask_rcnn.layers.gpu_detection_layer.GPUDetections object at 0x7f740effad68>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method GPUDetections.call of <iva.mask_rcnn.layers.gpu_detection_layer.GPUDetections object at 0x7f740effad68>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could notget source code
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740f0040b8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740f0040b8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a.py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,292 [WARNING] tensorflow: Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740f0040b8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f740f0040b8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, youshould to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740f0041d0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740f0041d0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:42,419 [WARNING] tensorflow: Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740f0041d0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f740f0041d0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f740f00ae80>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f740f00ae80>>. Note that functions defined in certain environments, like the interactive Pythonshell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-09-07 16:36:43,185 [WARNING] tensorflow: Entity <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f740f00ae80>> could not be transformed and will be executed as-is. Please reportthis to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f740f00ae80>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
Model: "model"
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
image_input (ImageInput) [(2, 3, 640, 640)] 0
conv1 (Conv2D) (2, 64, 320, 320) 9408 image_input[0][0]
bn_conv1 (BatchNormalization) (2, 64, 320, 320) 256 conv1[0][0]
activation (Activation) (2, 64, 320, 320) 0 bn_conv1[0][0]
max_pooling2d (MaxPooling2D) (2, 64, 160, 160) 0 activation[0][0]
block_1a_conv_1 (Conv2D) (2, 64, 160, 160) 36864 max_pooling2d[0][0]
block_1a_bn_1 (BatchNormalizati (2, 64, 160, 160) 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (2, 64, 160, 160) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (2, 64, 160, 160) 36864 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (2, 64, 160, 160) 4096 max_pooling2d[0][0]
block_1a_bn_2 (BatchNormalizati (2, 64, 160, 160) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (2, 64, 160, 160) 256 block_1a_conv_shortcut[0][0]
add (Add) (2, 64, 160, 160) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (2, 64, 160, 160) 0 add[0][0]
block_1b_conv_1 (Conv2D) (2, 64, 160, 160) 36864 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (2, 64, 160, 160) 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (2, 64, 160, 160) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (2, 64, 160, 160) 36864 block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (2, 64, 160, 160) 256 block_1b_conv_2[0][0]
add_1 (Add) (2, 64, 160, 160) 0 block_1b_bn_2[0][0]
block_1a_relu[0][0]
block_1b_relu (Activation) (2, 64, 160, 160) 0 add_1[0][0]
block_2a_conv_1 (Conv2D) (2, 128, 80, 80) 73728 block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (2, 128, 80, 80) 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (2, 128, 80, 80) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (2, 128, 80, 80) 147456 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (2, 128, 80, 80) 8192 block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (2, 128, 80, 80) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (2, 128, 80, 80) 512 block_2a_conv_shortcut[0][0]
add_2 (Add) (2, 128, 80, 80) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (2, 128, 80, 80) 0 add_2[0][0]
block_2b_conv_1 (Conv2D) (2, 128, 80, 80) 147456 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (2, 128, 80, 80) 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (2, 128, 80, 80) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (2, 128, 80, 80) 147456 block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (2, 128, 80, 80) 512 block_2b_conv_2[0][0]
add_3 (Add) (2, 128, 80, 80) 0 block_2b_bn_2[0][0]
block_2a_relu[0][0]
block_2b_relu (Activation) (2, 128, 80, 80) 0 add_3[0][0]
block_3a_conv_1 (Conv2D) (2, 256, 40, 40) 294912 block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (2, 256, 40, 40) 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (2, 256, 40, 40) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (2, 256, 40, 40) 589824 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (2, 256, 40, 40) 32768 block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (2, 256, 40, 40) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (2, 256, 40, 40) 1024 block_3a_conv_shortcut[0][0]
add_4 (Add) (2, 256, 40, 40) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (2, 256, 40, 40) 0 add_4[0][0]
block_3b_conv_1 (Conv2D) (2, 256, 40, 40) 589824 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (2, 256, 40, 40) 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (2, 256, 40, 40) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (2, 256, 40, 40) 589824 block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (2, 256, 40, 40) 1024 block_3b_conv_2[0][0]
add_5 (Add) (2, 256, 40, 40) 0 block_3b_bn_2[0][0]
block_3a_relu[0][0]
block_3b_relu (Activation) (2, 256, 40, 40) 0 add_5[0][0]
block_4a_conv_1 (Conv2D) (2, 512, 20, 20) 1179648 block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (2, 512, 20, 20) 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (2, 512, 20, 20) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (2, 512, 20, 20) 2359296 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (2, 512, 20, 20) 131072 block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (2, 512, 20, 20) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (2, 512, 20, 20) 2048 block_4a_conv_shortcut[0][0]
add_6 (Add) (2, 512, 20, 20) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (2, 512, 20, 20) 0 add_6[0][0]
block_4b_conv_1 (Conv2D) (2, 512, 20, 20) 2359296 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (2, 512, 20, 20) 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (2, 512, 20, 20) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (2, 512, 20, 20) 2359296 block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (2, 512, 20, 20) 2048 block_4b_conv_2[0][0]
add_7 (Add) (2, 512, 20, 20) 0 block_4b_bn_2[0][0]
block_4a_relu[0][0]
block_4b_relu (Activation) (2, 512, 20, 20) 0 add_7[0][0]
l5 (Conv2D) (2, 256, 20, 20) 131328 block_4b_relu[0][0]
l4 (Conv2D) (2, 256, 40, 40) 65792 block_3b_relu[0][0]
FPN_up_4 (UpSampling2D) (2, 256, 40, 40) 0 l5[0][0]
FPN_add_4 (Add) (2, 256, 40, 40) 0 l4[0][0]
FPN_up_4[0][0]
l3 (Conv2D) (2, 256, 80, 80) 33024 block_2b_relu[0][0]
FPN_up_3 (UpSampling2D) (2, 256, 80, 80) 0 FPN_add_4[0][0]
FPN_add_3 (Add) (2, 256, 80, 80) 0 l3[0][0]
FPN_up_3[0][0]
l2 (Conv2D) (2, 256, 160, 160) 16640 block_1b_relu[0][0]
FPN_up_2 (UpSampling2D) (2, 256, 160, 160) 0 FPN_add_3[0][0]
FPN_add_2 (Add) (2, 256, 160, 160) 0 l2[0][0]
FPN_up_2[0][0]
post_hoc_d5 (Conv2D) (2, 256, 20, 20) 590080 l5[0][0]
post_hoc_d2 (Conv2D) (2, 256, 160, 160) 590080 FPN_add_2[0][0]
post_hoc_d3 (Conv2D) (2, 256, 80, 80) 590080 FPN_add_3[0][0]
post_hoc_d4 (Conv2D) (2, 256, 40, 40) 590080 FPN_add_4[0][0]
p6 (MaxPooling2D) (2, 256, 10, 10) 0 post_hoc_d5[0][0]
rpn (Conv2D) multiple 590080 post_hoc_d2[0][0]
post_hoc_d3[0][0]
post_hoc_d4[0][0]
post_hoc_d5[0][0]
p6[0][0]
rpn-class (Conv2D) multiple 771 rpn[0][0]
rpn[1][0]
rpn[2][0]
rpn[3][0]
rpn[4][0]
rpn-box (Conv2D) multiple 3084 rpn[0][0]
rpn[1][0]
rpn[2][0]
rpn[3][0]
rpn[4][0]
permute (Permute) (2, 160, 160, 3) 0 rpn-class[0][0]
permute_2 (Permute) (2, 80, 80, 3) 0 rpn-class[1][0]
permute_4 (Permute) (2, 40, 40, 3) 0 rpn-class[2][0]
permute_6 (Permute) (2, 20, 20, 3) 0 rpn-class[3][0]
permute_8 (Permute) (2, 10, 10, 3) 0 rpn-class[4][0]
permute_1 (Permute) (2, 160, 160, 12) 0 rpn-box[0][0]
permute_3 (Permute) (2, 80, 80, 12) 0 rpn-box[1][0]
permute_5 (Permute) (2, 40, 40, 12) 0 rpn-box[2][0]
permute_7 (Permute) (2, 20, 20, 12) 0 rpn-box[3][0]
permute_9 (Permute) (2, 10, 10, 12) 0 rpn-box[4][0]
anchor_layer (AnchorLayer) OrderedDict([(2, (16 0 image_input[0][0]
info_input (InfoInput) [(2, 5)] 0
MLP (MultilevelProposal) ((2, 1000), (2, 1000 0 permute[0][0]
permute_2[0][0]
permute_4[0][0]
permute_6[0][0]
permute_8[0][0]
permute_1[0][0]
permute_3[0][0]
permute_5[0][0]
permute_7[0][0]
permute_9[0][0]
anchor_layer[0][0]
anchor_layer[0][1]
anchor_layer[0][2]
anchor_layer[0][3]
anchor_layer[0][4]
info_input[0][0]
multilevel_crop_resize (Multile (2, 1000, 256, 7, 7) 0 post_hoc_d2[0][0]
post_hoc_d3[0][0]
post_hoc_d4[0][0]
post_hoc_d5[0][0]
p6[0][0]
MLP[0][1]
box_head_reshape1 (ReshapeLayer (2000, 12544) 0 multilevel_crop_resize[0][0] INFO:tensorflow:Done calling model_fn.
2022-09-07 16:36:43,231 [INFO] tensorflow: Done calling model_fn.
INFO:tensorflow:Graph was finalized.
2022-09-07 16:36:43,727 [INFO] tensorflow: Graph was finalized.
INFO:tensorflow:Restoring parameters from /tmp/tmpeft_f09q/model.ckpt-245
2022-09-07 16:36:43,729 [INFO] tensorflow: Restoring parameters from /tmp/tmpeft_f09q/model.ckpt-245
INFO:tensorflow:Running local_init_op.
2022-09-07 16:36:44,089 [INFO] tensorflow: Running local_init_op.
INFO:tensorflow:Done running local_init_op.
2022-09-07 16:36:44,122 [INFO] tensorflow: Done running local_init_op.
INFO:tensorflow:Saving checkpoints for 245 into /tmp/tmpaoeugian/model.ckpt.
2022-09-07 16:36:45,588 [INFO] tensorflow: Saving checkpoints for 245 into /tmp/tmpaoeugian/model.ckpt.
fc6 (Dense) (2000, 1024) 12846080 box_head_reshape1[0][0]
fc7 (Dense) (2000, 1024) 1049600 fc6[0][0]
class-predict (Dense) (2000, 2) 2050 fc7[0][0]
box-predict (Dense) (2000, 8) 8200 fc7[0][0]
box_head_reshape2 (ReshapeLayer (2, 1000, 2) 0 class-predict[0][0]
box_head_reshape3 (ReshapeLayer (2, 1000, 8) 0 box-predict[0][0]
gpu_detections (GPUDetections) ((2,), (2, 100, 4), 0 box_head_reshape2[0][0]
box_head_reshape3[0][0]
MLP[0][1]
info_input[0][0]
multilevel_crop_resize_1 (Multi (2, 100, 256, 14, 14 0 post_hoc_d2[0][0]
post_hoc_d3[0][0]
post_hoc_d4[0][0]
post_hoc_d5[0][0]
p6[0][0]
gpu_detections[0][1]
mask_head_reshape_1 (ReshapeLay (200, 256, 14, 14) 0 multilevel_crop_resize_1[0][0]
mask-conv-l0 (Conv2D) (200, 256, 14, 14) 590080 mask_head_reshape_1[0][0]
mask-conv-l1 (Conv2D) (200, 256, 14, 14) 590080 mask-conv-l0[0][0]
mask-conv-l2 (Conv2D) (200, 256, 14, 14) 590080 mask-conv-l1[0][0]
mask-conv-l3 (Conv2D) (200, 256, 14, 14) 590080 mask-conv-l2[0][0]
conv5-mask (Conv2DTranspose) (200, 256, 28, 28) 262400 mask-conv-l3[0][0]
mask_fcn_logits (Conv2D) (200, 2, 28, 28) 514 conv5-mask[0][0]
mask_postprocess (MaskPostproce (2, 100, 28, 28) 0 mask_fcn_logits[0][0]
gpu_detections[0][2]
mask_sigmoid (Activation) (2, 100, 28, 28) 0 mask_postprocess[0][0]
Total params: 30,920,667
Trainable params: 11,180,736
Non-trainable params: 19,739,931
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/export.py", line 12, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py", line 268, in launch_export
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py", line 250, in run_export
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/export/exporter.py", line 595, in export
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/export/exporter.py", line 286, in save_etlt_file
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/export/exporter.py", line 239, in _train_ckpt_to_eval_ckpt
StopIteration
