Mask_rcnn pruned model inference error
Hi.
I get this error when inferencing the mask_rcnn pruned model:
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 351, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 343, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 305, in infer
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py", line 490, in infer
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/utils/evaluation.py", line 242, in infer
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 638, in predict
hooks=all_hooks) as mon_sess:
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1014, in __init__
stop_grace_period_secs=stop_grace_period_secs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 725, in __init__
self._sess = _RecoverableSession(self._coordinated_creator)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1207, in __init__
_WrappedSession.__init__(self, self._create_session())
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1212, in _create_session
return self._sess_creator.create_session()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 878, in create_session
self.tf_sess = self._session_creator.create_session()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 647, in create_session
init_fn=self._scaffold.init_fn)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/session_manager.py", line 290, in prepare_session
config=config)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/session_manager.py", line 204, in _restore_checkpoint
saver.restore(sess, checkpoint_filename_with_path)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1282, in restore
checkpoint_prefix)
ValueError: The passed save_path is not a valid checkpoint: /tmp/tmp70qmt1vn/model.ckpt-90000
Using TensorFlow backend.
Can you share the full command and full log?
How about run inference against the unpruned model?
BTW, you can refer to the official released jupyter notebook.
Full command:
!mask_rcnn inference -i /workspace/tlt/results/not_corrosion \
                             -o /workspace/tlt/results/tlt_mask_rcnn_corrosion1000_resnet50/annotated_images \
                             -e /workspace/tlt/results/tlt_mask_rcnn_corrosion1000_resnet50/pruned_model/model.step-90000.tlt/final_spec.txt \
                             -m /workspace/tlt/results/tlt_mask_rcnn_corrosion1000_resnet50/pruned_model/model.step-90000.tlt/model.tlt \
                             -t 0.6 \
                             -k $KEY \
                             --gpu_index 0 \
                             --include_mask
Full log:
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
Label file does not exist. Skipping...
[MaskRCNN] INFO    : Running inference...
[MaskRCNN] INFO    : Loading weights from /workspace/tlt/results/tlt_mask_rcnn_corrosion1000_resnet50/pruned_model2/model.step-90000.tlt/model.tlt
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <function infer.<locals>.infer_input_fn.<locals>.process_path at 0x7f850de6fb70> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <function infer.<locals>.infer_input_fn.<locals>.process_path at 0x7f850de6fb70>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
[MaskRCNN] INFO    : ***********************
[MaskRCNN] INFO    : Loading model graph...
WARNING:tensorflow:Entity <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f83df32a400>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method AnchorLayer.call of <iva.mask_rcnn.layers.anchor_layer.AnchorLayer object at 0x7f83df32a400>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f83df32a5f8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelProposal.call of <iva.mask_rcnn.layers.multilevel_proposal_layer.MultilevelProposal object at 0x7f83df32a5f8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
[MaskRCNN] INFO    : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_2/
[MaskRCNN] INFO    : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_3/
[MaskRCNN] INFO    : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_4/
[MaskRCNN] INFO    : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_5/
[MaskRCNN] INFO    : [ROI OPs] Using Batched NMS... Scope: MLP/multilevel_propose_rois/level_6/
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f83df32a7f0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f83df32a7f0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df32ac88>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df32ac88>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df3339e8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df3339e8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df333b00>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df333b00>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method GPUDetections.call of <iva.mask_rcnn.layers.gpu_detection_layer.GPUDetections object at 0x7f83df333c18>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method GPUDetections.call of <iva.mask_rcnn.layers.gpu_detection_layer.GPUDetections object at 0x7f83df333c18>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f83df333f28>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MultilevelCropResize.call of <iva.mask_rcnn.layers.multilevel_crop_resize_layer.MultilevelCropResize object at 0x7f83df333f28>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df33d080>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method ReshapeLayer.call of <iva.mask_rcnn.layers.reshape_layer.ReshapeLayer object at 0x7f83df33d080>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f83df344d30>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method MaskPostprocess.call of <iva.mask_rcnn.layers.mask_postprocess_layer.MaskPostprocess object at 0x7f83df344d30>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
Model: "model"
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
image_input (ImageInput)        [(2, 3, 640, 640)]   0
conv1 (Conv2D)                  (2, 64, 320, 320)    9408        image_input[0][0]
bn_conv1 (BatchNormalization)   (2, 64, 320, 320)    256         conv1[0][0]
activation (Activation)         (2, 64, 320, 320)    0           bn_conv1[0][0]
max_pooling2d (MaxPooling2D)    (2, 64, 160, 160)    0           activation[0][0]
block_1a_conv_1 (Conv2D)        (2, 64, 160, 160)    4096        max_pooling2d[0][0]
block_1a_bn_1 (BatchNormalizati (2, 64, 160, 160)    256         block_1a_conv_1[0][0]
block_1a_relu_1 (Activation)    (2, 64, 160, 160)    0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (2, 64, 160, 160)    36864       block_1a_relu_1[0][0]
block_1a_bn_2 (BatchNormalizati (2, 64, 160, 160)    256         block_1a_conv_2[0][0]
block_1a_relu_2 (Activation)    (2, 64, 160, 160)    0           block_1a_bn_2[0][0]
block_1a_conv_3 (Conv2D)        (2, 256, 160, 160)   16384       block_1a_relu_2[0][0]
block_1a_conv_shortcut (Conv2D) (2, 256, 160, 160)   16384       max_pooling2d[0][0]
block_1a_bn_3 (BatchNormalizati (2, 256, 160, 160)   1024        block_1a_conv_3[0][0]
block_1a_bn_shortcut (BatchNorm (2, 256, 160, 160)   1024        block_1a_conv_shortcut[0][0]
add (Add)                       (2, 256, 160, 160)   0           block_1a_bn_3[0][0]
        block_1a_bn_shortcut[0][0]
block_1a_relu (Activation)      (2, 256, 160, 160)   0           add[0][0]
block_1b_conv_1 (Conv2D)        (2, 64, 160, 160)    16384       block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (2, 64, 160, 160)    256         block_1b_conv_1[0][0]
block_1b_relu_1 (Activation)    (2, 64, 160, 160)    0           block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D)        (2, 64, 160, 160)    36864       block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (2, 64, 160, 160)    256         block_1b_conv_2[0][0]
block_1b_relu_2 (Activation)    (2, 64, 160, 160)    0           block_1b_bn_2[0][0]
block_1b_conv_3 (Conv2D)        (2, 256, 160, 160)   16384       block_1b_relu_2[0][0]
block_1b_bn_3 (BatchNormalizati (2, 256, 160, 160)   1024        block_1b_conv_3[0][0]
add_1 (Add)                     (2, 256, 160, 160)   0           block_1b_bn_3[0][0]
        block_1a_relu[0][0]
block_1b_relu (Activation)      (2, 256, 160, 160)   0           add_1[0][0]
block_1c_conv_1 (Conv2D)        (2, 64, 160, 160)    16384       block_1b_relu[0][0]
block_1c_bn_1 (BatchNormalizati (2, 64, 160, 160)    256         block_1c_conv_1[0][0]
block_1c_relu_1 (Activation)    (2, 64, 160, 160)    0           block_1c_bn_1[0][0]
block_1c_conv_2 (Conv2D)        (2, 64, 160, 160)    36864       block_1c_relu_1[0][0]
block_1c_bn_2 (BatchNormalizati (2, 64, 160, 160)    256         block_1c_conv_2[0][0]
block_1c_relu_2 (Activation)    (2, 64, 160, 160)    0           block_1c_bn_2[0][0]
block_1c_conv_3 (Conv2D)        (2, 256, 160, 160)   16384       block_1c_relu_2[0][0]
block_1c_bn_3 (BatchNormalizati (2, 256, 160, 160)   1024        block_1c_conv_3[0][0]
add_2 (Add)                     (2, 256, 160, 160)   0           block_1c_bn_3[0][0]
        block_1b_relu[0][0]
block_1c_relu (Activation)      (2, 256, 160, 160)   0           add_2[0][0]
block_2a_conv_1 (Conv2D)        (2, 128, 80, 80)     32768       block_1c_relu[0][0]
block_2a_bn_1 (BatchNormalizati (2, 128, 80, 80)     512         block_2a_conv_1[0][0]
block_2a_relu_1 (Activation)    (2, 128, 80, 80)     0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (2, 128, 80, 80)     147456      block_2a_relu_1[0][0]
block_2a_bn_2 (BatchNormalizati (2, 128, 80, 80)     512         block_2a_conv_2[0][0]
block_2a_relu_2 (Activation)    (2, 128, 80, 80)     0           block_2a_bn_2[0][0]
block_2a_conv_3 (Conv2D)        (2, 512, 80, 80)     65536       block_2a_relu_2[0][0]
block_2a_conv_shortcut (Conv2D) (2, 512, 80, 80)     131072      block_1c_relu[0][0]
block_2a_bn_3 (BatchNormalizati (2, 512, 80, 80)     2048        block_2a_conv_3[0][0]
block_2a_bn_shortcut (BatchNorm (2, 512, 80, 80)     2048        block_2a_conv_shortcut[0][0]
add_3 (Add)                     (2, 512, 80, 80)     0           block_2a_bn_3[0][0]
        block_2a_bn_shortcut[0][0]
block_2a_relu (Activation)      (2, 512, 80, 80)     0           add_3[0][0]
block_2b_conv_1 (Conv2D)        (2, 128, 80, 80)     65536       block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (2, 128, 80, 80)     512         block_2b_conv_1[0][0]
block_2b_relu_1 (Activation)    (2, 128, 80, 80)     0           block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D)        (2, 128, 80, 80)     147456      block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (2, 128, 80, 80)     512         block_2b_conv_2[0][0]
block_2b_relu_2 (Activation)    (2, 128, 80, 80)     0           block_2b_bn_2[0][0]
block_2b_conv_3 (Conv2D)        (2, 512, 80, 80)     65536       block_2b_relu_2[0][0]
block_2b_bn_3 (BatchNormalizati (2, 512, 80, 80)     2048        block_2b_conv_3[0][0]
add_4 (Add)                     (2, 512, 80, 80)     0           block_2b_bn_3[0][0]
        block_2a_relu[0][0]
block_2b_relu (Activation)      (2, 512, 80, 80)     0           add_4[0][0]
block_2c_conv_1 (Conv2D)        (2, 128, 80, 80)     65536       block_2b_relu[0][0]
block_2c_bn_1 (BatchNormalizati (2, 128, 80, 80)     512         block_2c_conv_1[0][0]
block_2c_relu_1 (Activation)    (2, 128, 80, 80)     0           block_2c_bn_1[0][0]
block_2c_conv_2 (Conv2D)        (2, 128, 80, 80)     147456      block_2c_relu_1[0][0]
block_2c_bn_2 (BatchNormalizati (2, 128, 80, 80)     512         block_2c_conv_2[0][0]
block_2c_relu_2 (Activation)    (2, 128, 80, 80)     0           block_2c_bn_2[0][0]
block_2c_conv_3 (Conv2D)        (2, 512, 80, 80)     65536       block_2c_relu_2[0][0]
block_2c_bn_3 (BatchNormalizati (2, 512, 80, 80)     2048        block_2c_conv_3[0][0]
add_5 (Add)                     (2, 512, 80, 80)     0           block_2c_bn_3[0][0]
        block_2b_relu[0][0]
block_2c_relu (Activation)      (2, 512, 80, 80)     0           add_5[0][0]
block_2d_conv_1 (Conv2D)        (2, 128, 80, 80)     65536       block_2c_relu[0][0]
block_2d_bn_1 (BatchNormalizati (2, 128, 80, 80)     512         block_2d_conv_1[0][0]
block_2d_relu_1 (Activation)    (2, 128, 80, 80)     0           block_2d_bn_1[0][0]
block_2d_conv_2 (Conv2D)        (2, 128, 80, 80)     147456      block_2d_relu_1[0][0]
block_2d_bn_2 (BatchNormalizati (2, 128, 80, 80)     512         block_2d_conv_2[0][0]
block_2d_relu_2 (Activation)    (2, 128, 80, 80)     0           block_2d_bn_2[0][0]
block_2d_conv_3 (Conv2D)        (2, 512, 80, 80)     65536       block_2d_relu_2[0][0]
block_2d_bn_3 (BatchNormalizati (2, 512, 80, 80)     2048        block_2d_conv_3[0][0]
add_6 (Add)                     (2, 512, 80, 80)     0           block_2d_bn_3[0][0]
        block_2c_relu[0][0]
block_2d_relu (Activation)      (2, 512, 80, 80)     0           add_6[0][0]
block_3a_conv_1 (Conv2D)        (2, 256, 40, 40)     131072      block_2d_relu[0][0]
block_3a_bn_1 (BatchNormalizati (2, 256, 40, 40)     1024        block_3a_conv_1[0][0]
block_3a_relu_1 (Activation)    (2, 256, 40, 40)     0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (2, 256, 40, 40)     589824      block_3a_relu_1[0][0]
block_3a_bn_2 (BatchNormalizati (2, 256, 40, 40)     1024        block_3a_conv_2[0][0]
block_3a_relu_2 (Activation)    (2, 256, 40, 40)     0           block_3a_bn_2[0][0]
block_3a_conv_3 (Conv2D)        (2, 1024, 40, 40)    262144      block_3a_relu_2[0][0]
block_3a_conv_shortcut (Conv2D) (2, 1024, 40, 40)    524288      block_2d_relu[0][0]
block_3a_bn_3 (BatchNormalizati (2, 1024, 40, 40)    4096        block_3a_conv_3[0][0]
block_3a_bn_shortcut (BatchNorm (2, 1024, 40, 40)    4096        block_3a_conv_shortcut[0][0]
add_7 (Add)                     (2, 1024, 40, 40)    0           block_3a_bn_3[0][0]
        block_3a_bn_shortcut[0][0]
block_3a_relu (Activation)      (2, 1024, 40, 40)    0           add_7[0][0]
block_3b_conv_1 (Conv2D)        (2, 256, 40, 40)     262144      block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (2, 256, 40, 40)     1024        block_3b_conv_1[0][0]
block_3b_relu_1 (Activation)    (2, 256, 40, 40)     0           block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D)        (2, 256, 40, 40)     589824      block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (2, 256, 40, 40)     1024        block_3b_conv_2[0][0]
block_3b_relu_2 (Activation)    (2, 256, 40, 40)     0           block_3b_bn_2[0][0]
block_3b_conv_3 (Conv2D)        (2, 1024, 40, 40)    262144      block_3b_relu_2[0][0]
block_3b_bn_3 (BatchNormalizati (2, 1024, 40, 40)    4096        block_3b_conv_3[0][0]
add_8 (Add)                     (2, 1024, 40, 40)    0           block_3b_bn_3[0][0]
        block_3a_relu[0][0]
block_3b_relu (Activation)      (2, 1024, 40, 40)    0           add_8[0][0]
block_3c_conv_1 (Conv2D)        (2, 256, 40, 40)     262144      block_3b_relu[0][0]
block_3c_bn_1 (BatchNormalizati (2, 256, 40, 40)     1024        block_3c_conv_1[0][0]
block_3c_relu_1 (Activation)    (2, 256, 40, 40)     0           block_3c_bn_1[0][0]
block_3c_conv_2 (Conv2D)        (2, 256, 40, 40)     589824      block_3c_relu_1[0][0]
block_3c_bn_2 (BatchNormalizati (2, 256, 40, 40)     1024        block_3c_conv_2[0][0]
block_3c_relu_2 (Activation)    (2, 256, 40, 40)     0           block_3c_bn_2[0][0]
block_3c_conv_3 (Conv2D)        (2, 1024, 40, 40)    262144      block_3c_relu_2[0][0]
block_3c_bn_3 (BatchNormalizati (2, 1024, 40, 40)    4096        block_3c_conv_3[0][0]
add_9 (Add)                     (2, 1024, 40, 40)    0           block_3c_bn_3[0][0]
        block_3b_relu[0][0]
block_3c_relu (Activation)      (2, 1024, 40, 40)    0           add_9[0][0]
block_3d_conv_1 (Conv2D)        (2, 256, 40, 40)     262144      block_3c_relu[0][0]
block_3d_bn_1 (BatchNormalizati (2, 256, 40, 40)     1024        block_3d_conv_1[0][0]
block_3d_relu_1 (Activation)    (2, 256, 40, 40)     0           block_3d_bn_1[0][0]
block_3d_conv_2 (Conv2D)        (2, 256, 40, 40)     589824      block_3d_relu_1[0][0]
block_3d_bn_2 (BatchNormalizati (2, 256, 40, 40)     1024        block_3d_conv_2[0][0]
block_3d_relu_2 (Activation)    (2, 256, 40, 40)     0           block_3d_bn_2[0][0]
block_3d_conv_3 (Conv2D)        (2, 1024, 40, 40)    262144      block_3d_relu_2[0][0]
block_3d_bn_3 (BatchNormalizati (2, 1024, 40, 40)    4096        block_3d_conv_3[0][0]
add_10 (Add)                    (2, 1024, 40, 40)    0           block_3d_bn_3[0][0]
        block_3c_relu[0][0]
block_3d_relu (Activation)      (2, 1024, 40, 40)    0           add_10[0][0]
block_3e_conv_1 (Conv2D)        (2, 256, 40, 40)     262144      block_3d_relu[0][0]
block_3e_bn_1 (BatchNormalizati (2, 256, 40, 40)     1024        block_3e_conv_1[0][0]
block_3e_relu_1 (Activation)    (2, 256, 40, 40)     0           block_3e_bn_1[0][0]
block_3e_conv_2 (Conv2D)        (2, 256, 40, 40)     589824      block_3e_relu_1[0][0]
block_3e_bn_2 (BatchNormalizati (2, 256, 40, 40)     1024        block_3e_conv_2[0][0]
block_3e_relu_2 (Activation)    (2, 256, 40, 40)     0           block_3e_bn_2[0][0]
block_3e_conv_3 (Conv2D)        (2, 1024, 40, 40)    262144      block_3e_relu_2[0][0]
block_3e_bn_3 (BatchNormalizati (2, 1024, 40, 40)    4096        block_3e_conv_3[0][0]
add_11 (Add)                    (2, 1024, 40, 40)    0           block_3e_bn_3[0][0]
        block_3d_relu[0][0]
block_3e_relu (Activation)      (2, 1024, 40, 40)    0           add_11[0][0]
block_3f_conv_1 (Conv2D)        (2, 256, 40, 40)     262144      block_3e_relu[0][0]
block_3f_bn_1 (BatchNormalizati (2, 256, 40, 40)     1024        block_3f_conv_1[0][0]
block_3f_relu_1 (Activation)    (2, 256, 40, 40)     0           block_3f_bn_1[0][0]
block_3f_conv_2 (Conv2D)        (2, 256, 40, 40)     589824      block_3f_relu_1[0][0]
block_3f_bn_2 (BatchNormalizati (2, 256, 40, 40)     1024        block_3f_conv_2[0][0]
block_3f_relu_2 (Activation)    (2, 256, 40, 40)     0           block_3f_bn_2[0][0]
block_3f_conv_3 (Conv2D)        (2, 1024, 40, 40)    262144      block_3f_relu_2[0][0]
block_3f_bn_3 (BatchNormalizati (2, 1024, 40, 40)    4096        block_3f_conv_3[0][0]
add_12 (Add)                    (2, 1024, 40, 40)    0           block_3f_bn_3[0][0]
        block_3e_relu[0][0]
block_3f_relu (Activation)      (2, 1024, 40, 40)    0           add_12[0][0]
block_4a_conv_1 (Conv2D)        (2, 512, 20, 20)     524288      block_3f_relu[0][0]
block_4a_bn_1 (BatchNormalizati (2, 512, 20, 20)     2048        block_4a_conv_1[0][0]
block_4a_relu_1 (Activation)    (2, 512, 20, 20)     0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (2, 512, 20, 20)     2359296     block_4a_relu_1[0][0]
block_4a_bn_2 (BatchNormalizati (2, 512, 20, 20)     2048        block_4a_conv_2[0][0]
block_4a_relu_2 (Activation)    (2, 512, 20, 20)     0           block_4a_bn_2[0][0]
block_4a_conv_3 (Conv2D)        (2, 2048, 20, 20)    1048576     block_4a_relu_2[0][0]
block_4a_conv_shortcut (Conv2D) (2, 2048, 20, 20)    2097152     block_3f_relu[0][0]
block_4a_bn_3 (BatchNormalizati (2, 2048, 20, 20)    8192        block_4a_conv_3[0][0]
block_4a_bn_shortcut (BatchNorm (2, 2048, 20, 20)    8192        block_4a_conv_shortcut[0][0]
add_13 (Add)                    (2, 2048, 20, 20)    0           block_4a_bn_3[0][0]
        block_4a_bn_shortcut[0][0]
block_4a_relu (Activation)      (2, 2048, 20, 20)    0           add_13[0][0]
block_4b_conv_1 (Conv2D)        (2, 512, 20, 20)     1048576     block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (2, 512, 20, 20)     2048        block_4b_conv_1[0][0]
block_4b_relu_1 (Activation)    (2, 512, 20, 20)     0           block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D)        (2, 512, 20, 20)     2359296     block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (2, 512, 20, 20)     2048        block_4b_conv_2[0][0]
block_4b_relu_2 (Activation)    (2, 512, 20, 20)     0           block_4b_bn_2[0][0]
block_4b_conv_3 (Conv2D)        (2, 2048, 20, 20)    1048576     block_4b_relu_2[0][0]
block_4b_bn_3 (BatchNormalizati (2, 2048, 20, 20)    8192        block_4b_conv_3[0][0]
add_14 (Add)                    (2, 2048, 20, 20)    0           block_4b_bn_3[0][0]
        block_4a_relu[0][0]
block_4b_relu (Activation)      (2, 2048, 20, 20)    0           add_14[0][0]
block_4c_conv_1 (Conv2D)        (2, 512, 20, 20)     1048576     block_4b_relu[0][0]
block_4c_bn_1 (BatchNormalizati (2, 512, 20, 20)     2048        block_4c_conv_1[0][0]
block_4c_relu_1 (Activation)    (2, 512, 20, 20)     0           block_4c_bn_1[0][0]
block_4c_conv_2 (Conv2D)        (2, 512, 20, 20)     2359296     block_4c_relu_1[0][0]
block_4c_bn_2 (BatchNormalizati (2, 512, 20, 20)     2048        block_4c_conv_2[0][0]
block_4c_relu_2 (Activation)    (2, 512, 20, 20)     0           block_4c_bn_2[0][0]
block_4c_conv_3 (Conv2D)        (2, 2048, 20, 20)    1048576     block_4c_relu_2[0][0]
block_4c_bn_3 (BatchNormalizati (2, 2048, 20, 20)    8192        block_4c_conv_3[0][0]
add_15 (Add)                    (2, 2048, 20, 20)    0           block_4c_bn_3[0][0]
        block_4b_relu[0][0]
block_4c_relu (Activation)      (2, 2048, 20, 20)    0           add_15[0][0]
l5 (Conv2D)                     (2, 256, 20, 20)     524544      block_4c_relu[0][0]
l4 (Conv2D)                     (2, 256, 40, 40)     262400      block_3f_relu[0][0]
FPN_up_4 (UpSampling2D)         (2, 256, 40, 40)     0           l5[0][0]
FPN_add_4 (Add)                 (2, 256, 40, 40)     0           l4[0][0]
        FPN_up_4[0][0]
l3 (Conv2D)                     (2, 256, 80, 80)     131328      block_2d_relu[0][0]
FPN_up_3 (UpSampling2D)         (2, 256, 80, 80)     0           FPN_add_4[0][0]
FPN_add_3 (Add)                 (2, 256, 80, 80)     0           l3[0][0]
        FPN_up_3[0][0]
l2 (Conv2D)                     (2, 256, 160, 160)   65792       block_1c_relu[0][0]
FPN_up_2 (UpSampling2D)         (2, 256, 160, 160)   0           FPN_add_3[0][0]
FPN_add_2 (Add)                 (2, 256, 160, 160)   0           l2[0][0]
        FPN_up_2[0][0]
post_hoc_d5 (Conv2D)            (2, 256, 20, 20)     590080      l5[0][0]
post_hoc_d2 (Conv2D)            (2, 256, 160, 160)   590080      FPN_add_2[0][0]
post_hoc_d3 (Conv2D)            (2, 256, 80, 80)     590080      FPN_add_3[0][0]
post_hoc_d4 (Conv2D)            (2, 256, 40, 40)     590080      FPN_add_4[0][0]
p6 (MaxPooling2D)               (2, 256, 10, 10)     0           post_hoc_d5[0][0]
rpn (Conv2D)                    multiple             590080      post_hoc_d2[0][0]
        post_hoc_d3[0][0]
        post_hoc_d4[0][0]
        post_hoc_d5[0][0]
        p6[0][0]
rpn-class (Conv2D)              multiple             771         rpn[0][0]
        rpn[1][0]
        rpn[2][0]
        rpn[3][0]
        rpn[4][0]
rpn-box (Conv2D)                multiple             3084        rpn[0][0]
        rpn[1][0]
        rpn[2][0]
        rpn[3][0]
        rpn[4][0]
permute (Permute)               (2, 160, 160, 3)     0           rpn-class[0][0]
permute_2 (Permute)             (2, 80, 80, 3)       0           rpn-class[1][0]
permute_4 (Permute)             (2, 40, 40, 3)       0           rpn-class[2][0]
permute_6 (Permute)             (2, 20, 20, 3)       0           rpn-class[3][0]
permute_8 (Permute)             (2, 10, 10, 3)       0           rpn-class[4][0]
permute_1 (Permute)             (2, 160, 160, 12)    0           rpn-box[0][0]
permute_3 (Permute)             (2, 80, 80, 12)      0           rpn-box[1][0]
permute_5 (Permute)             (2, 40, 40, 12)      0           rpn-box[2][0]
permute_7 (Permute)             (2, 20, 20, 12)      0           rpn-box[3][0]
permute_9 (Permute)             (2, 10, 10, 12)      0           rpn-box[4][0]
anchor_layer (AnchorLayer)      OrderedDict([(2, (16 0           image_input[0][0]
info_input (InfoInput)          [(2, 5)]             0
MLP (MultilevelProposal)        ((2, 1000), (2, 1000 0           permute[0][0]
        permute_2[0][0]
        permute_4[0][0]
        permute_6[0][0]
        permute_8[0][0]
        permute_1[0][0]
        permute_3[0][0]
        permute_5[0][0]
        permute_7[0][0]
        permute_9[0][0]
        anchor_layer[0][0]
        anchor_layer[0][1]
        anchor_layer[0][2]
        anchor_layer[0][3]
        anchor_layer[0][4]
        info_input[0][0]
multilevel_crop_resize (Multile (2, 1000, 256, 7, 7) 0           post_hoc_d2[0][0]
        post_hoc_d3[0][0]
        post_hoc_d4[0][0]
        post_hoc_d5[0][0]
        p6[0][0]
        MLP[0][1]
box_head_reshape1 (ReshapeLayer (2000, 12544)        0           multilevel_crop_resize[0][0]
fc6 (Dense)                     (2000, 1024)         12846080    box_head_reshape1[0][0]
fc7 (Dense)                     (2000, 1024)         1049600     fc6[0][0]
class-predict (Dense)           (2000, 2)            2050        fc7[0][0]
box-predict (Dense)             (2000, 8)            8200        fc7[0][0]
box_head_reshape2 (ReshapeLayer (2, 1000, 2)         0           class-predict[0][0]
box_head_reshape3 (ReshapeLayer (2, 1000, 8)         0           box-predict[0][0]
gpu_detections (GPUDetections)  ((2,), (2, 100, 4),  0           box_head_reshape2[0][0]
        box_head_reshape3[0][0]
        MLP[0][1]
        info_input[0][0]
multilevel_crop_resize_1 (Multi (2, 100, 256, 14, 14 0           post_hoc_d2[0][0]
        post_hoc_d3[0][0]
        post_hoc_d4[0][0]
        post_hoc_d5[0][0]
        p6[0][0]
        gpu_detections[0][1]
mask_head_reshape_1 (ReshapeLay (200, 256, 14, 14)   0           multilevel_crop_resize_1[0][0]
mask-conv-l0 (Conv2D)           (200, 256, 14, 14)   590080      mask_head_reshape_1[0][0]
mask-conv-l1 (Conv2D)           (200, 256, 14, 14)   590080      mask-conv-l0[0][0]
mask-conv-l2 (Conv2D)           (200, 256, 14, 14)   590080      mask-conv-l1[0][0]
mask-conv-l3 (Conv2D)           (200, 256, 14, 14)   590080      mask-conv-l2[0][0]
conv5-mask (Conv2DTranspose)    (200, 256, 28, 28)   262400      mask-conv-l3[0][0]
mask_fcn_logits (Conv2D)        (200, 2, 28, 28)     514         conv5-mask[0][0]
mask_postprocess (MaskPostproce (2, 100, 28, 28)     0           mask_fcn_logits[0][0]
        gpu_detections[0][2]
mask_sigmoid (Activation)       (2, 100, 28, 28)     0           mask_postprocess[0][0]
Total params: 44,028,635
Trainable params: 23,508,032
Non-trainable params: 20,520,603
    config=config)
    checkpoint_prefix)
ValueError: The passed save_path is not a valid checkpoint: /tmp/tmpc0iiwecg/model.ckpt-90000
After pruning, did you run retraining?
More, after retraining, did you rename the model’s name? If yes, please do not change it and rerun inference.
No, I did not retrain the model after pruning. Is it necessary?
Yes, it is needed. Refer to Mask Rcnn Inference Error
