I am getting File not found error when I am using the nvidia tao toolkit. But,I am using the same path to get the detail. It is working. Thank you in advance.
Please note that the path should be a path inside the docker.
So, please double check the ~/.tao_mounts.json to check if the mapping is correct.
See more in TAO Toolkit Launcher - NVIDIA Docs
Thanks for the suggestion and,I have changed the path of the directory as Env Specs directory. Then It is working.
While I am running the code It throws the another error.
Please double check the training dataset exists.
Also, please delete the folder expriment_dir_unpruned and generate again.
Train data is already exists and I have deleted the expriment_dir_unpruned.
Still getting the same issue.
Could you please the training spec file?
maskrcnn_train_resnet50.txt (2.0 KB)
In spec file I have changed the classes from 91 to 2
Please run below and share the results.
! tao model mask_rcnn run ls -rlt /workspace/tao-experiments/data/maskrcnn/train*.tfrecord
So, the dataset is not available. Please double check the ~/.tao_mounts.json to check if the mapping is correct.
The files are all 0 size. It is not expected.
Still getting the No Such file or directory using this code ! tao model mask_rcnn run ls -rlt /workspace/tao-experiments/data/maskrcnn/train*.tfrecord
Can you share the latest command and its full log?
My data set size is 13 images.
Do I need to change any thing in spec file
Can you share your ~/.tao_mounts.json file as well?
Suggest you to open a terminal to narrow down.
$ tao model mask_rcnn
Inside the docker, run the commands such as:
mask_rcnn dataset_convert xxx
mask_rcnn train xxx
