i ran this command to convert data to tfrecord : sudo docker run -it --rm --gpus all -v /home/mj/TAO/workspace:/workspace nvcr.io/nvidia/tao/tao-toolkit:4.0.1-tf1.15.5 mask_rcnn dataset_convert -i /home/mj/TAO/workspace/tao-experiments/data/raw-data/val2017 -a /home/mj/TAO/workspace/tao-experiments/data/raw-data/annotations/instances_val2017.json -o /home/mj/TAO/workspace/tao-experiments/data --include_masks -t val -s 32
but it returns :
=== TAO Toolkit TensorFlow ===
NVIDIA Release 4.0.1-TensorFlow (build )
TAO Toolkit Version 4.0.1
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the TAO Toolkit End User License Agreement.
By pulling and using the container, you accept the terms and conditions of this license:
NOTE: The SHMEM allocation limit is set to the default of 64MB. This may be
insufficient for TAO Toolkit. NVIDIA recommends the use of the following flags:
docker run --gpus all --ipc=host --ulimit memlock=-1 --ulimit stack=67108864 …
Using TensorFlow backend.
2023-05-24 09:01:12.396899: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/init.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn’t match a supported version!
RequestsDependencyWarning)
2023-05-24 09:01:15.556207: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
2023-05-24 09:01:15.984804: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libnvinfer.so.8
2023-05-24 09:01:15.998817: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcuda.so.1
File “</usr/local/lib/python3.6/dist-packages/iva/mask_rcnn/scripts/dataset_convert.py>”, line 3, in
File “”, line 415, in
File “”, line 403, in
File “”, line 292, in main
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/mj/TAO/workspace/tao-experiments/data’
Telemetry data couldn’t be sent, but the command ran successfully.
[WARNING]: <urlopen error [Errno -2] Name or service not known>
Execution status: FAIL
the path is correct i dont know why it returns " No such file or directory" how can i solve it ??
