TLT training error : Key cost_sums/cyclist-bbox not found in checkpoint
I am trying to train a Resnet18 model with 5 classes with TLT 2.0 . Here’s my detectnet_v2_train_resnet18_kitti.txt
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: “/workspace/tlt-experiments/data/tfrecords/kitti_trainval/*”
image_directory_path: “/workspace/tlt-experiments/data/training”
image_extension: “png”
target_class_mapping {
key: “car”
value: “car”
key: “cyclist”
value: “cyclist”
key: “tram”
value: “tram”
key: “van”
value: “van”
key: “truck”
value: “truck”
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 1248
output_image_height: 384
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: “car”
value {
clustering_config {
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 20
key: “cyclist”
value {
clustering_config {
dbscan_eps: 0.15000000596
key: “truck”
value {
clustering_config {
coverage_threshold: 0.00749999983236
dbscan_eps: 0.230000004172
key: “van”
value {
clustering_config {
key: “tram”
value {
clustering_config {
model_config {
pretrained_model_file: “/workspace/tlt-experiments/detectnet_v2/pretrained_resnet18/tlt_pretrained_detectnet_v2_vresnet18/resnet18.hdf5”
num_layers: 18
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: “resnet”
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 30
minimum_detection_ground_truth_overlap {
key: “car”
value: 0.699999988079
key: “cyclist”
value: 0.5
key: “truck”
value: 0.5
key: “van”
value: 0.5
key: “tram”
value: 0.5
evaluation_box_config {
key: “car”
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
key: “cyclist”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: “truck”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: “van”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: “tram”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 8.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 120
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: “car”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.40000000596
cov_radius_y: 0.40000000596
bbox_min_radius: 1.0
key: “truck”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: “van”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: “tram”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: “cyclist”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
But I am receiving the following error during training step:
Using TensorFlow backend.
2020-09-02 02:21:01.275355: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
[[44670,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
  Host: 28a74eaf1a18
Another transport will be used instead, although this may result in
lower performance.
NOTE: You can disable this warning by setting the MCA parameter
btl_base_warn_component_unused to 0.
2020-09-02 02:21:04.022657: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-09-02 02:21:04.025557: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:04.025875: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: GeForce RTX 2070 major: 7 minor: 5 memoryClockRate(GHz): 1.86
pciBusID: 0000:01:00.0
2020-09-02 02:21:04.025893: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-02 02:21:04.025960: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-02 02:21:04.026911: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-02 02:21:04.027191: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-02 02:21:04.028565: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-02 02:21:04.029569: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-02 02:21:04.029643: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-02 02:21:04.029763: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:04.030125: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:04.030421: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-02 02:21:04.030446: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-02 02:21:04.663087: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-02 02:21:04.663123: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165]      0
2020-09-02 02:21:04.663132: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0:   N
2020-09-02 02:21:04.663328: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:04.663773: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:04.664101: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:04.664401: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5750 MB memory) -> physical GPU (device: 0, name: GeForce RTX 2070, pci bus id: 0000:01:00.0, compute capability: 7.5)
2020-09-02 02:21:04,665 [INFO] iva.detectnet_v2.scripts.train: Loading experiment spec at /workspace/examples/detectnet_v2/specs/detectnet_v2_train_resnet18_kitti.txt.
2020-09-02 02:21:04,666 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/examples/detectnet_v2/specs/detectnet_v2_train_resnet18_kitti.txt
2020-09-02 02:21:05,235 [INFO] iva.detectnet_v2.scripts.train: Cannot iterate over exactly 6434 samples with a batch size of 16; each epoch will therefore take one extra step.
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
input_1 (InputLayer)            (None, 3, 128, 512)  0
conv1 (Conv2D)                  (None, 64, 64, 256)  9472        input_1[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 64, 256)  256         conv1[0][0]
activation_1 (Activation)       (None, 64, 64, 256)  0           bn_conv1[0][0]
block_1a_conv_1 (Conv2D)        (None, 64, 32, 128)  36928       activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 32, 128)  256         block_1a_conv_1[0][0]
block_1a_relu_1 (Activation)    (None, 64, 32, 128)  0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (None, 64, 32, 128)  36928       block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 32, 128)  4160        activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 32, 128)  256         block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 32, 128)  256         block_1a_conv_shortcut[0][0]
add_1 (Add)                     (None, 64, 32, 128)  0           block_1a_bn_2[0][0]
                                                             block_1a_bn_shortcut[0][0]
block_1a_relu (Activation)      (None, 64, 32, 128)  0           add_1[0][0]
block_1b_conv_1 (Conv2D)        (None, 64, 32, 128)  36928       block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 32, 128)  256         block_1b_conv_1[0][0]
block_1b_relu_1 (Activation)    (None, 64, 32, 128)  0           block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D)        (None, 64, 32, 128)  36928       block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 32, 128)  256         block_1b_conv_2[0][0]
add_2 (Add)                     (None, 64, 32, 128)  0           block_1b_bn_2[0][0]
                                                             block_1a_relu[0][0]
block_1b_relu (Activation)      (None, 64, 32, 128)  0           add_2[0][0]
block_2a_conv_1 (Conv2D)        (None, 128, 16, 64)  73856       block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 16, 64)  512         block_2a_conv_1[0][0]
block_2a_relu_1 (Activation)    (None, 128, 16, 64)  0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (None, 128, 16, 64)  147584      block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 16, 64)  8320        block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 16, 64)  512         block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 16, 64)  512         block_2a_conv_shortcut[0][0]
add_3 (Add)                     (None, 128, 16, 64)  0           block_2a_bn_2[0][0]
                                                             block_2a_bn_shortcut[0][0]
block_2a_relu (Activation)      (None, 128, 16, 64)  0           add_3[0][0]
block_2b_conv_1 (Conv2D)        (None, 128, 16, 64)  147584      block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 16, 64)  512         block_2b_conv_1[0][0]
block_2b_relu_1 (Activation)    (None, 128, 16, 64)  0           block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D)        (None, 128, 16, 64)  147584      block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 16, 64)  512         block_2b_conv_2[0][0]
add_4 (Add)                     (None, 128, 16, 64)  0           block_2b_bn_2[0][0]
                                                             block_2a_relu[0][0]
block_2b_relu (Activation)      (None, 128, 16, 64)  0           add_4[0][0]
block_3a_conv_1 (Conv2D)        (None, 256, 8, 32)   295168      block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 8, 32)   1024        block_3a_conv_1[0][0]
block_3a_relu_1 (Activation)    (None, 256, 8, 32)   0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (None, 256, 8, 32)   590080      block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 8, 32)   33024       block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 8, 32)   1024        block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 8, 32)   1024        block_3a_conv_shortcut[0][0]
add_5 (Add)                     (None, 256, 8, 32)   0           block_3a_bn_2[0][0]
                                                             block_3a_bn_shortcut[0][0]
block_3a_relu (Activation)      (None, 256, 8, 32)   0           add_5[0][0]
block_3b_conv_1 (Conv2D)        (None, 256, 8, 32)   590080      block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 8, 32)   1024        block_3b_conv_1[0][0]
block_3b_relu_1 (Activation)    (None, 256, 8, 32)   0           block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D)        (None, 256, 8, 32)   590080      block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 8, 32)   1024        block_3b_conv_2[0][0]
add_6 (Add)                     (None, 256, 8, 32)   0           block_3b_bn_2[0][0]
                                                             block_3a_relu[0][0]
block_3b_relu (Activation)      (None, 256, 8, 32)   0           add_6[0][0]
block_4a_conv_1 (Conv2D)        (None, 512, 8, 32)   1180160     block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 8, 32)   2048        block_4a_conv_1[0][0]
block_4a_relu_1 (Activation)    (None, 512, 8, 32)   0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (None, 512, 8, 32)   2359808     block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 8, 32)   131584      block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 8, 32)   2048        block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 8, 32)   2048        block_4a_conv_shortcut[0][0]
add_7 (Add)                     (None, 512, 8, 32)   0           block_4a_bn_2[0][0]
                                                             block_4a_bn_shortcut[0][0]
block_4a_relu (Activation)      (None, 512, 8, 32)   0           add_7[0][0]
block_4b_conv_1 (Conv2D)        (None, 512, 8, 32)   2359808     block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 8, 32)   2048        block_4b_conv_1[0][0]
block_4b_relu_1 (Activation)    (None, 512, 8, 32)   0           block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D)        (None, 512, 8, 32)   2359808     block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 8, 32)   2048        block_4b_conv_2[0][0]
add_8 (Add)                     (None, 512, 8, 32)   0           block_4b_bn_2[0][0]
                                                             block_4a_relu[0][0]
block_4b_relu (Activation)      (None, 512, 8, 32)   0           add_8[0][0]
output_bbox (Conv2D)            (None, 12, 8, 32)    6156        block_4b_relu[0][0]
output_cov (Conv2D)             (None, 3, 8, 32)     1539        block_4b_relu[0][0]
Total params: 11,203,023
Trainable params: 11,183,823
Non-trainable params: 19,200
2020-09-02 02:21:14,391 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2020-09-02 02:21:14,391 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2020-09-02 02:21:14,391 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2020-09-02 02:21:14,391 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 8, io threads: 16, compute threads: 8, buffered batches: 4
2020-09-02 02:21:14,391 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 6434, number of sources: 1, batch size per gpu: 16, steps: 403
2020-09-02 02:21:14,520 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2020-09-02 02:21:14.557716: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:14.558334: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-09-02 02:21:14.558397: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-02 02:21:14.558441: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-02 02:21:14.558470: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-02 02:21:14.558491: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-02 02:21:14.558513: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-02 02:21:14.558533: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-02 02:21:14.558551: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-02 02:21:14.558626: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:14.558945: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:14.559228: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-02 02:21:14,810 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: True - shard 0 of 1
2020-09-02 02:21:14,817 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2020-09-02 02:21:14,817 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
2020-09-02 02:21:15,348 [INFO] iva.detectnet_v2.scripts.train: Found 6434 samples in training set
2020-09-02 02:21:17,864 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2020-09-02 02:21:17,864 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2020-09-02 02:21:17,864 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2020-09-02 02:21:17,864 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 8, io threads: 16, compute threads: 8, buffered batches: 4
2020-09-02 02:21:17,864 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 1047, number of sources: 1, batch size per gpu: 16, steps: 66
2020-09-02 02:21:17,893 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2020-09-02 02:21:18,142 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: False - shard 0 of 1
2020-09-02 02:21:18,148 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2020-09-02 02:21:18,148 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
2020-09-02 02:21:18,503 [INFO] iva.detectnet_v2.scripts.train: Found 1047 samples in validation set
2020-09-02 02:21:24.279957: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:24.280279: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-09-02 02:21:24.280325: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-02 02:21:24.280371: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-02 02:21:24.280404: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-02 02:21:24.280429: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-02 02:21:24.280481: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-02 02:21:24.280551: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-02 02:21:24.280581: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-02 02:21:24.280681: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:24.280994: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:24.281300: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-02 02:21:24.282484: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-02 02:21:24.282515: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165]      0
2020-09-02 02:21:24.282524: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0:   N
2020-09-02 02:21:24.282671: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:24.283107: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-02 02:21:24.283484: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5750 MB memory) -> physical GPU (device: 0, name: GeForce RTX 2070, pci bus id: 0000:01:00.0, compute capability: 7.5)
2020-09-02 02:21:24.948619: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at save_restore_v2_ops.cc:184 : Not found: Key cost_sums/cyclist-bbox not found in checkpoint
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1365, in _do_call
return fn(*args)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1350, in _run_fn
target_list, run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.NotFoundError: 2 root error(s) found.
  (0) Not found: Key cost_sums/cyclist-bbox not found in checkpoint
	 [[{{node save/RestoreV2}}]]
  (1) Not found: Key cost_sums/cyclist-bbox not found in checkpoint
	 [[save/RestoreV2/_877]]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1290, in restore
{self.saver_def.filename_tensor_name: save_path})
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
run_metadata_ptr)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
feed_dict_tensor, options, run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
run_metadata)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
raise type(e)(node_def, op, message)
	 [[node save/RestoreV2 (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'save/RestoreV2':
  File "/usr/local/bin/tlt-train-g1", line 8, in <module>
sys.exit(main())
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/magnet_train.py", line 55, in main
  File "<decorator-gen-2>", line 2, in main
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 773, in main
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 691, in run_experiment
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 624, in train_gridbox
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 147, in run_training_loop
  File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py", line 143, in get_singular_monitored_session
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1104, in __init__
stop_grace_period_secs=stop_grace_period_secs)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 727, in __init__
self._sess = self._coordinated_creator.create_session()
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 878, in create_session
self.tf_sess = self._session_creator.create_session()
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 638, in create_session
self._scaffold.finalize()
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 229, in finalize
self._saver = training_saver._get_saver_or_default()  # pylint: disable=protected-access
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 599, in _get_saver_or_default
saver = Saver(sharded=True, allow_empty=True)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 828, in __init__
self.build()
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 840, in build
self._build(self._filename, build_save=True, build_restore=True)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 878, in _build
build_restore=build_restore)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 502, in _build_internal
restore_sequentially, reshape)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 381, in _AddShardedRestoreOps
name="restore_shard"))
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 328, in _AddRestoreOps
restore_sequentially)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 575, in bulk_restore
return io_ops.restore_v2(filename_tensor, names, slices, dtypes)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/gen_io_ops.py", line 1696, in restore_v2
name=name)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
op_def=op_def)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
attrs, op_def, compute_device)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
op_def=op_def)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1748, in __init__
self._traceback = tf_stack.extract_stack()
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1300, in restore
names_to_keys = object_graph_key_mapping(save_path)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1618, in object_graph_key_mapping
object_graph_string = reader.get_tensor(trackable.OBJECT_GRAPH_PROTO_KEY)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/pywrap_tensorflow_internal.py", line 915, in get_tensor
return CheckpointReader_GetTensor(self, compat.as_bytes(tensor_str))
tensorflow.python.framework.errors_impl.NotFoundError: Key _CHECKPOINTABLE_OBJECT_GRAPH not found in checkpoint
sys.exit(main())
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 647, in create_session
init_fn=self._scaffold.init_fn)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/session_manager.py", line 290, in prepare_session
config=config)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/session_manager.py", line 204, in _restore_checkpoint
saver.restore(sess, checkpoint_filename_with_path)
  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1306, in restore
err, "a Variable name or other graph key that is missing")
tensorflow.python.framework.errors_impl.NotFoundError: Restoring from checkpoint failed. This is most likely due to a Variable name or other graph key that is missing from the checkpoint. Please ensure that you have not altered the graph expected based on the checkpoint. Original error:
sys.exit(main())
self.build()
name=name)
op_def=op_def)
op_def=op_def)
In your log, the input size is 512x128. But your spec is setting 1248x384.
Can you double check ? Is it the correct spec or log?
Please create a new result folder and retry.
In the running command,
tlt-train detectnet_v2 -r new_result_folder -e spec.txt -k key -n resnet18
Thanks @Morganh, after creating new directory, the problem is solved. Maybe there was previous checkpoints on that directory which was causing the error. Also the input size in spec is 1248x384 which seems okey.
I had this same issue, renaming the output directory solved it. In my case, I was attempting to use the weights from a previous experiment’s .tlt file rather than the NGC .hdf5 file.
Is this a bug or is this the expected behavior? Can these instructions be added to the TLT documentation? The errors shown in the console do not give any indication that the issue is related to the output directory.
I will sync with internal team for this training error resulted from old output directory.
