Hello, I’m tryng to run Mask-RCNN on a Jetson NANO: GitHub - matterport/Mask_RCNN: Mask R-CNN for object detection and instance segmentation on Keras and TensorFlow and one of the dependencies is opencv-python, but I’m getting this error:
Could not find a version that satisfies the requirement opencv-python (from versions: )
No matching distribution found for opencv-python
I’m installing it from pip3.
Could you help me?
Thank You.
hello,
can you try these lines;
$ sudo apt-get update
$ sudo apt-get install -y python-opencv python3-opencv
Thanks, in fact opencv python installation worked that way, but still I get this error:
Python 3.7.1 | packaged by conda-forge | (default, Feb 26 2019, 04:21:53)
[GCC 7.3.0] :: Anaconda, Inc. on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'cv2'
Hello again,
Could you check the opencv libraries with this command ?
$ pkg-config --libs opencv
$ pkg-config --cflags opencv
After that, maybe you should try these lines;
$ conda install -c conda-forge opencv
$ conda install -c conda-forge/label/broken opencv
