in the old OptiX versions (until 4.0) in file glm.h the structure GLMMaterial includes field alpha - transparency. It is value of ‘d’ in MTL-file.
But in new versions (4.0) in file Mesh.h structure MaterialParams not includes this parameter. Tiny_obj_loader get transparency as ‘d’ value, and i see this value in m_materials[i].dissolve field by debugging in loadMeshOBJ(), but this value will be not set into MaterialParams structure, so will be lost. Is this an error?
PS: in old OptiX versions (until 4.0) i have found a small error: in glm.cpp in _glmReadMTL() at the end of function the MTL-file will not be closed: no string “fclose(file);”
