[b]Key words:
Error C2088
Matlab
VC2005 sp1
CUDA
Windows XP sp2[/b]
[b]Title:
Matlab plug-in for CUDA , OS XP-sp2, VC2005 Error C2088 during compilation of the demo examples [/b]External Media
Error Origin:
Changes in VC2005 sp1 :
please see this link for details: External Media
http://connect.microsoft.com/VisualStudio/…edbackID=229419
Status: no fix External Media
Possible solutions:
a) recompilation of provided CUDA libraries with different names!
B) Switch to 64bit Vista to make mexw64 and run with 64-bit matlab External Media
Steps to reproduce:
Install VC2005 sp1, run examples from the matlab CUDA 1.1 kit.
OS XP(pro) sp2
tested with matlab 7.1 , 2007b, 2008a
The compilation of examples with VC 2005 sp1 compiler …
>> mex fft2_cuda.c -IC:\CUDA\include -LC:\CUDA\lib -lcudart -lcufft
mex fft2_cuda_sp_dp.c -IC:\CUDA\include -LC:\CUDA\lib -lcudart -lcufft
mex ifft2_cuda.c -IC:\CUDA\include -LC:\CUDA\lib -lcudart -lcufft
and
nvmex -f nvmexopts.bat Szeta.cu -IC:\cuda\include -LC:\cuda\lib -lcufft -lcudart
…results with an error code: C2088.
Here is the printout:
mex fft2_cuda.c -IE:\CUDA\include -LE:\CUDA\lib -lcudart -lcufft -v
This is mex, Copyright 1984-2007 The MathWorks, Inc.
→ Default options filename found in E:\Documents and Settings\revera\Application Data\MathWorks\MATLAB\R2008a
→ Options file = E:\Documents and Settings\revera\Application Data\MathWorks\MATLAB\R2008a\mexopts.bat
MATLAB = E:\PROGRA~1\MATLAB\R2008a
→ COMPILER = cl
→ Compiler flags:
COMPFLAGS = /c /Zp8 /GR /W3 /EHs /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE /nologo /MD
OPTIMFLAGS = /O2 /Oy- /DNDEBUG
DEBUGFLAGS = /Zi /Fd"fft2_cuda.mexw32.pdb"
arguments = -IE:\CUDA\include
Name switch = /Fo
→ Pre-linking commands =
→ LINKER = link
→ Link directives:
LINKFLAGS = /dll /export:mexFunction /MAP /LIBPATH:"E:\PROGRA~1\MATLAB\R2008a\extern\lib\win32\microsoft" libmx.lib libmex.lib libmat.lib /implib:E:\DOCUME~1\revera\LOCALS~1\Temp\mex_wthYtP\templib.x /MACHINE:X86 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
LINKDEBUGFLAGS = /DEBUG /PDB:"fft2_cuda.mexw32.pdb"
LINKFLAGSPOST =
Name directive = /out:"fft2_cuda.mexw32"
File link directive =
Lib. link directive =
Rsp file indicator = @
→ Resource Compiler = rc /fo “mexversion.res”
→ Resource Linker =
→ cl -IE:\CUDA\include /c /Zp8 /GR /W3 /EHs /D_CRT_SECURE_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /D_SECURE_SCL=0 /DMATLAB_MEX_FILE /nologo /MD /FoE:\DOCUME~1\revera\LOCALS~1\Temp\mex_wthYtP\fft2_cuda.obj -IE:\PROGRA~1\MATLAB\R2008a\extern\include /O2 /Oy- /DNDEBUG -DMX_COMPAT_32 “E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c”
fft2_cuda.c
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(49) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(50) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(62) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(63) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(79) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(80) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(97) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(98) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(110) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(111) : error C2088: ‘[’ : illegal for struct
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(154) : warning C4244: ‘=’ : conversion from ‘double’ to ‘int’, possible loss of data
E:\Program Files\MATLAB\R2008a\toolbox\CUDA\fft2_cuda.c(155) : warning C4244: ‘=’ : conversion from ‘double’ to ‘int’, possible loss of data
E:\PROGRA~1\MATLAB\R2008A\BIN\MEX.PL: Error: Compile of ‘fft2_cuda.c’ failed.
??? Error using ==> mex at 207
Unable to complete successfully. External Media
