Hello. I’ve downloaded Matlab CUDA plug-in 1.1 and can’t get past the CUDA source compilation:
>> nvmex -f nvmexopts.bat Szeta.cu -IC:\cuda\include -LC:\cuda\lib -lcufft -lcudart
nvcc fatal : nvcc cannot find a supported cl version. Only MSVC 8.0 and MSVC 9.0 are supported
C:\PROGRA~1\MATLAB\R2009B\BIN\NVMEX.PL: Error: Compile of 'Szeta.cu' failed.
??? Error using ==> nvmex at 206
Unable to complete successfully.
When I run it in verbose mode:
>> nvmex -v -f nvmexopts.bat Szeta.cu -IC:\cuda\include -LC:\cuda\lib -lcufft -lcudart
This is mex, Copyright 1984-2005 The MathWorks, Inc.
-> Options file specified on command line
-> Options file = nvmexopts.bat
MATLAB = C:\PROGRA~1\MATLAB\R2009b
-> COMPILER = nvcc
-> Compiler flags:
COMPFLAGS = -c -D_WCHAR_T_DEFINED -Xcompiler "/c /Zp8 /GR /W3 /EHsc- /Zc:wchar_t- /DMATLAB_MEX_FILE /nologo"
OPTIMFLAGS = -D_WCHAR_T_DEFINED -Xcompiler "/MD /O2 /Oy- /DNDEBUG"
DEBUGFLAGS = -D_WCHAR_T_DEFINED -Xcompiler "/MD /Zi /Fd"Szeta.mexw32.pdb"
arguments = -IC:\cuda\include
Name switch = -o
-> Pre-linking commands =
-> LINKER = link
-> Link directives:
LINKFLAGS = /dll /export:mexFunction /MAP /LIBPATH:"C:\PROGRA~1\MATLAB\R2009b\extern\lib\win32\microsoft" libmx.lib libmex.lib libmat.lib /implib:templib.x /MACHINE:X86 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
LINKDEBUGFLAGS = /DEBUG /PDB:"Szeta.mexw32.pdb"
LINKFLAGSPOST =
Name directive = /out:"Szeta.mexw32"
File link directive =
Lib. link directive =
Rsp file indicator = @
-> Resource Compiler = rc /fo "mexversion.res"
-> Resource Linker =
--> nvcc -IC:\cuda\include -c -D_WCHAR_T_DEFINED -Xcompiler "/c /Zp8 /GR /W3 /EHsc- /Zc:wchar_t- /DMATLAB_MEX_FILE /nologo" -o Szeta.obj -IC:\PROGRA~1\MATLAB\R2009b\extern\include -IC:\PROGRA~1\MATLAB\R2009b\simulink\include -D_WCHAR_T_DEFINED -Xcompiler "/MD /O2 /Oy- /DNDEBUG" -DMX_COMPAT_32 Szeta.cu
I have alread modified “nvmexopts.bat”:
set VSINSTALLDIR=C:\Program Files\Microsoft Visual Studio 2008
to
set VSINSTALLDIR=C:\Program Files\Microsoft Visual Studio 9.0
It surely must be some incorrect path in nvcc, because I already got cl.exe, version 9.0.
Okay, now “nvmexopts.bat” got modified again:
set COMPFLAGS=-c -D_WCHAR_T_DEFINED -Xcompiler "/c /Zp8 /GR /W3 /EHsc- /Zc:wchar_t- /DMATLAB_MEX_FILE /nologo"
to
set COMPFLAGS=-c -ccbin "C:\Program Files\Microsoft Visual Studio 9.0\VC\bin" -D_WCHAR_T_DEFINED -Xcompiler "/c /Zp8 /GR /W3 /EHsc- /Zc:wchar_t- /DMATLAB_MEX_FILE /nologo"
But now a buttload of errors popped up:
Szeta.cu
tmpxft_000009a0_00000000-3_Szeta.cudafe1.gpu
tmpxft_000009a0_00000000-8_Szeta.cudafe2.gpu
tmpxft_000009a0_00000000-3_Szeta.cudafe1.cpp
cl : Command line warning D9025 : overriding '/EHc-' with '/EHc'
tmpxft_000009a0_00000000-12_Szeta.ii
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(235) : error C2065: '_Buffer' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(235) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(235) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(235) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(237) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(237) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(239) : error C2065: '_Buffer' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(239) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(239) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(239) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(241) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(241) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(245) : error C2065: '_Buffer' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(245) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(245) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(245) : error C2433: '_wstrdate_s' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(245) : error C2998: 'errno_t _wstrdate_s' : cannot be a template definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(249) : error C2065: '_Buffer' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(249) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(249) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(249) : error C2433: '_wstrtime_s' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(249) : error C2998: 'errno_t _wstrtime_s' : cannot be a template definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(254) : error C2065: '_Buffer' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(254) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(254) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\time.h(254) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\wtime.inl(46) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\wtime.inl(46) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\wtime.inl(56) : error C3861: '_wctime64_s': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(195) : error C2664: 'memchr' : cannot convert parameter 1 from 'const void *' to 'void *'
Conversion loses qualifiers
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(244) : error C2065: '_Dest' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(244) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(244) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(244) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(245) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(245) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(251) : error C2065: '_Dest' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(251) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(251) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(251) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(252) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(252) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(259) : error C3861: 'wcsnlen': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(265) : error C2065: '_Dest' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(265) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(265) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(265) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(268) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(268) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(274) : error C2065: '_Dest' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(274) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(274) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(274) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(275) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(275) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(286) : error C2065: '_Buffer' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(286) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(286) : error C2062: type 'int' unexpected
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(287) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(287) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(289) : error C2065: '_Buffer' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(289) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(289) : error C2988: unrecognizable template declaration/definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(289) : error C2059: syntax error : 'const'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(291) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(291) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(296) : error C2065: '_Dst' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(296) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(296) : error C2065: 'wchar_t' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(296) : error C2146: syntax error : missing ')' before identifier '_Val'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(296) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(296) : error C2433: '_wcsnset_s' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(296) : error C2059: syntax error : ')'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(297) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(297) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(300) : error C2065: '_Str' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(300) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(300) : error C2065: 'wchar_t' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(300) : error C2146: syntax error : missing ')' before identifier '_Val'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(300) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(300) : error C2433: '_wcsset_s' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(300) : error C2059: syntax error : ')'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(301) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(301) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(304) : error C2065: '_String' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(304) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(304) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(304) : error C2433: '_wcslwr_s' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(304) : error C2998: 'errno_t _wcslwr_s' : cannot be a template definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(307) : error C2065: '_String' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(307) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(307) : error C2275: '_locale_t' : illegal use of this type as an expression
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\crtdefs.h(2035) : see declaration of '_locale_t'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(307) : error C2146: syntax error : missing ')' before identifier '_Locale'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(307) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(307) : error C2433: '_wcslwr_s_l' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(307) : error C2059: syntax error : ')'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(308) : error C2143: syntax error : missing ';' before '{'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(308) : error C2447: '{' : missing function header (old-style formal list?)
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(310) : error C2065: '_String' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(310) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(310) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(310) : error C2433: '_wcsupr_s' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(310) : error C2998: 'errno_t _wcsupr_s' : cannot be a template definition
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(313) : error C2065: '_String' : undeclared identifier
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(313) : error C3861: 'wchar_t': identifier not found
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(313) : error C2275: '_locale_t' : illegal use of this type as an expression
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(313) : error C2146: syntax error : missing ')' before identifier '_Locale'
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(313) : warning C4229: anachronism used : modifiers on data are ignored
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(313) : error C2433: '_wcsupr_s_l' : 'inline' not permitted on data declarations
C:\Program Files\Microsoft Visual Studio 9.0\VC\INCLUDE\string.h(313) : fatal error C1003: error count exceeds 100; stopping compilation
I had a similar problem but I found it was because I had the old nvmexopts.bat in my working directory. Using the nvmexopts.bat in [url=“http://forums.nvidia.com/index.php?showtopic=66961”]http://forums.nvidia.com/index.php?showtopic=66961[/url] (renamed to nvmexopts.bat) fixed this error on my system.
