Maximum bandwith?
  1. I have a 8800GTX and I would like to know the maximum bandwidth I can achieve.
  2. Actually, I’d like to measure this bandwidth to see if I can speed-up my kernel.
    So, I have donne a simple kernel where each thread write 3 times in global memory and read 2 times in global memory.
    I know that the term “GB” is ambiguous. 1GB = 1000^3 btes or 1GB = 1024^3 byte?
Thanks,
Vince
maximum bandwidth is 86,4 GB/s I achived so far 75 GB/s, where GB is = 1000^3.
To measure performance, simply count the accesses to memory (no matter whether read or write) multiply by 4 (thats for the float) and divide by the seconds taken.
If your kernel ist too fast, then simply do the same kernel again and again and mulitply by the number of iterations.
Hope that answers your question for a start?
Johannes
I do this
cudaEventRecord(start,0);
for (int i=0;i<IT;i++){
	myKernel<<<grid,threads>>>(tab_dev);
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
cudaEventElapsedTime(&elapsedTime, start, stop);
and I have an elapsed time of -1.#QNAN0 ms…
Is anything wrong in my code?
My kernel is the following
__global__ void myKernel(float* tab){
unsigned int xIndex = blockIdx.x * NB + threadIdx.x;
unsigned int yIndex = blockIdx.y * NB + threadIdx.y;
tab[yIndex * NB + xIndex] = 1.0;
tab[yIndex * NB + xIndex] = tab[yIndex * NB + xIndex] + 1;
I’ve done a very small code and I have these results :
Nb bytes r&w : 92160000 Bytes
Elapsed time : 0.938219 ms
Bandwidth    : 98.228658 GB/s
My function (see bellow) do only 9 read and write. Is that possible to have this kind of bandwidth? Do I have made a msitake?
#include <stdio.h>
#include "cuda.h"
#define NB 1600  // WIDTH AND HEIGHT
#define BS 16  // BLOCK SIZE
#define IT 1000  // NB OF ITERATIONS
	unsigned int xIndex = blockIdx.x * BS + threadIdx.x;
	unsigned int yIndex = blockIdx.y * BS + threadIdx.y;
	unsigned int l      = yIndex * NB + xIndex;
	tab[l] = 1.0;
	tab[l] = tab[l] + 1;
int main(void){
	// My array
	float* tab_dev;
	cudaMalloc( (void **) &tab_dev, NB*NB*sizeof(float));
	// Bytes read and write
	int nbBytesReadAndWrite;
	// Grid and thread
	dim3 grid(NB/BS, NB/BS, 1);
	dim3 threads(BS, BS, 1);
	// Timer
	cudaEvent_t start, stop;
	float elapsedTimeInMs;
	cudaEventCreate(&start);
	cudaEventCreate(&stop);
	// Loop with timer
	cudaEventElapsedTime(&elapsedTimeInMs, start, stop);
	cudaEventDestroy(start);
	cudaEventDestroy(stop);
	// Bandwidth computation
	nbBytesReadAndWrite  = 9*sizeof(float)*NB*NB;
	elapsedTimeInMs     /= IT;
	printf("Nb bytes r&w : %d Bytes\n",nbBytesReadAndWrite);
	printf("Elapsed time : %f ms\n",elapsedTimeInMs);
	printf("Bandwidth    : %f GB/s\n",nbBytesReadAndWrite/(elapsedTimeInMs*1000000));
	// Free memory
	cudaFree(tab_dev);
The compiler may be optimizing out the multiple reads/writes to tab[1]. You can check by compiling with the -ptx option and examining the ptx code.
To obtain the bandwidth of ~70 GiB/s in a benchmark, you need fully coalesced reads and writes of a 4-byte or 8-byte type and you need to copy a large enough chunk of data so that the overhead of launching the kernel doesn’t affect the results.
For the whole 9 yards of bandwidth reads/writes/copies, see my bandwidth test code near the bottom of this thread: [url=“http://forums.nvidia.com/index.php?showtopic=52806”]http://forums.nvidia.com/index.php?showtopic=52806[/url]
