I attempted to connect an AD board supporting up to 4 MSPS to the Jetson AGX Orin Developer Kit via SPI and tested the communication. However, even under an RT kernel, I was only able to achieve a speed of approximately 3 KSPS.
If there is any information available regarding the maximum performance achievable with SPI communication on Jetson devices, I would greatly appreciate it if you could share it.
Is your issue specific to RT-Kernel? Or have you’ve also verified with default BSP package?
What do you mean about KSPS? sampling rate?
How do you configure the SPI frequency?
I am using the Developer Kit for testing.
I also conducted verification with the default BSP, and the behavior was exactly the same.
Incidentally, I tested with the Orin Nano under the default BSP as well, and there was no significant difference compared to the AGX Orin.
KSPS stands for kilosamples per second. The meaning is the same as sampling rate
For the SPI settings, I used Python’s spidev, set to mode 2 and a frequency of 23,999,999 Hz.
When the frequency exceeds 24 MHz, the values could no longer be obtained correctly.
By the way, the AD board being used is the AD7386, which supports 4 MSPS and a maximum clock speed of 80 MHz.
I would like to know the design’s maximum speed(samples per second) specification to determine whether further investigation is necessary.
Even with a loopback test, it seems the maximum achievable frequency is only 40,799,999 Hz.
I prioritize sampling rate over the clock. If there is a way to achieve 4 MSPS, please let me know.
Based on various tests, I found that while the SPI pins on the Jetson Orin are theoretically designed for 81,600,000 Hz, due to noise and other factors, the actual upper limit of achievable speed is around 40 MHz (in loopback mode).
To achieve a high sampling rate such as 4 MSPS, it is necessary to consider noise countermeasures and the use of DMA simultaneously.
In particular, the AD7386 used in this test requires issuing a communication command every time a value is acquired, so the speed ended up being only around 3 KSPS at best. If I had used an AD board that can continuously acquire values with a single communication command, I might have been able to set a higher sampling rate, even if there was a slight deviation.
If you happen to know of any partners who specialize in speeding up interfaces like SPI, I would greatly appreciate an introduction.
It seems the issue is specific to how your ADC works so that I would suggest you asking the help from your vendor for the details about the usage for this ADC module.
