SPI_IOC_MESSAGE ioctl for SPI extremely slow
I’m trying to command a stepper motor controller through SPI, and I found that I could not send commands as quickly as I was expecting. After some profiling, I narrowed it down to this call:
clock_gettime(CLOCK_MONOTONIC, &ts0); // Check time before
ioctl(fd, SPI_IOC_MESSAGE(1), xfer); // spi_ioc_transfer structure
clock_gettime(CLOCK_MONOTONIC, &ts1); // Check time after
The message I’m trying to send is 6 bytes, and the SPI clock rate is 5MHz. So this should take about 10 microseconds plus a little system call overhead.
Instead, I’m finding that this call usually takes a 8 to 22 milliseconds, usually on the higher end.
For reference, here’s how I do initialization:
static int configure_spi(int fd)
    char mode = SPI_MODE_3;
    char bits = 8;
    int speed = 5000000;
    char lsbfirst = 0;
    check_ioctl(fd, SPI_IOC_WR_MODE, &mode);
    check_ioctl(fd, SPI_IOC_WR_BITS_PER_WORD, &bits);
    check_ioctl(fd, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
    check_ioctl(fd, SPI_IOC_WR_LSB_FIRST, &lsbfirst);
    return 0;
And here’s the setup for a transaction:
    struct spi_ioc_transfer xfer[1];
    memset(xfer, 0, sizeof(xfer));
    xfer[0].tx_buf = (unsigned long) tbuf;
    xfer[0].rx_buf = (unsigned long) rbuf;
    xfer[0].len           = len;
    xfer[0].speed_hz      = 5000000;
    xfer[0].bits_per_word = 8;
Can anyone tell me how I might go about figuring out what’s wrong and how to fix it? Take 22 milliseconds for a single SPI transaction is completely intolerable for my application, so I have to fix this.
Hi theosib,
Are you using the devkit or custom board for Orin Nano?
Is your issue about the delay issue in SPI driver?
Please share the full dmesg for further check.
I’m using the devkit. The jetpack version is 5.1.1-b56. The delay does seem to be related to the SPI driver since it’s just the ioctl for doing the SPI transaction that takes excessive time. The dmesg is attached.
The way you word this makes it sound like a known issue. Is it?
dmesg.txt (84.5 KB)
I thought you are using JP6 and we know there should be known issue in the spi-tegra114 driver.
Could you update to the latest Jetpack 5.1.3 (L4T R35.5.0) to check if there still the issue?
I installed Jetpack 5.1.3, and this seems to have broken SPI entirely, so I really need some help with this since this is a show-stopper for me.
The ioctls are still happening, and the performance is still terrible.
But now no SPI communication seems to be happening anymore. The stepper motor driver chips I’m trying to talk to are no longer doing anything, and they’re not drawing any current.
PLEASE HELP!
I just realized that I might have to run jetson-io.py to configure the I/O pins. However, when I try to run that, the curses screen flashes for only a moment, and then I’m returned to the shell. It seems that 5.1.3 broke this utility.
I captured stdout from jetson-io.py, and this is what I get:
FATAL ERROR! No APP_b partition found
I’ve tried googling this, but I’m not finding any answers.
So, I figured that the problem might be that I had corrupted the boot flash, so I made a fresh one. When I went to run jetson-io.py, I got the exact same error:
FATAL ERROR!
No APP_b partition found!
I finally found a discussion about the problem with running jetson-io.py: X264 and TensorRT sudden reboot (MJPG encoder not affected, but not fast enough) on Jetson Orin Nano - #54 by timf34
But it doesn’t seem like this has ever been resolved. It looks like I have no choice but to downgrade back to 5.1.1.
I found the bug in jetson-io.py and implemented a workaround.
In the Jetson subdirectory, there’s another python source called board.py.
This bit of code here incorrectly computes the partition name to look for:
        #Finding the active partition in case of redundant rootfs flash.
        activepart = syscall.call_out('nvbootctrl get-current-slot')
        if activepart[0] == '0':
            mountpart = "APP"
        else:
            mountpart = "APP_b"
I hacked it to set mountpart to “APP”. That worked, and everything’s going again.
This QA snafu cost me a lot of time. You might want to write an app note somewhere to spare others this frustration.
I can get jetson-io working on my Orin Nano devkit with JP5.1.3(R35.5.0).
Do you mean that nvbootctrl get-current-slot return unexpected result(0 for APP, 1 for APP_b) in your case?
If so, please also share the result of sudo nvbootctrl dump-slots-info on your board.
Current version: 35.5.0
Capsule update status: 1
Current bootloader slot: B
Active bootloader slot: B
num_slots: 2
slot: 0,             status: normal
slot: 1,             status: normal
It seems that you’ve run capsule update successfully and it is booting from chain B now.
Yes. It’s fine. It’s just that the name of the partition doesn’t match. That’s the bug.
Do you enable redundant rootfs in your case?
$ sudo nvbootctrl -t rootfs dump-slots-info
I’m also experiencing the slow SPI issue and wondered if the problem was ever resolved. We’re currently using JetPack 6. Any updates or additional insights would be greatly appreciated!
What’s the requirement of the frequency you want to use for SPI?
Is there any issue if you use lower SPI frequency?
I am having exactly the same problem! Any other methods to fix this problem? I tried JP6, JP5.1.3, JP5.1.2, but only JP5.1.2 seems to work fine about the SPI communication with large packets. My spi communication works fine with the spi frequency with 0.5MHz, but the communication is too slow(about 5ms communication time) for my application(I need 500us at least). But when I increase the spi frequency higher than 0.5MHz, the spi communication becomes weird(the packets received seems to be broken). What is the problem? and how can I fix this problem? I also tried the same code in my upboard, but it works fine with 5MHz spi frequency, so it seems to be a hw problem or kernel driver problem of the orin agx dev kit I use.
The frequencies I have tried at 1MHz and 5MHz. Each of those was selected based on the specs of the devices I was communicating with. Both of them have highly erratic ioctl system call times. All of them are much longer than should be the case for the number of bits I’m sending, which is always small. The same packets (40 to 48 bits) will require times ranging from 8 milliseconds to 22 milliseconds, which is an eternity compared to the time required to send those at 1MHz.
At this point, we’ve decided to ditch SPI and try CAN. If CAN is also slow, we’re going to have to consider other platforms.
