Switching SPI to slave mode
I’m using Jetson Orin Nano dev board, JetPack-6.2.
I switched spi0 into the slave mode by changing ‘compatible = “nvidia,tegra210-spi\0nvidia,tegra114-spi”;’ to ‘compatible = “nvidia,tegra210-spi-slave”;’ for the “spi@3210000” node in the /boot/dtb/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb file. I was following this post: Origin nano spi
I start seeing SPI slave in dmesg:
agostrer@ubuntu:~$ sudo dmesg|grep spi
[   10.678715] spi-tegra124-slave 3210000.spi: Adding to iommu group 1
[   10.682990] spi-tegra124-slave 3210000.spi: Dynamic bus number will be registered
[   10.698373] spi-tegra114 3230000.spi: Adding to iommu group 1
[  420.598462] spi-tegra124-slave 3210000.spi: Tx is not supported in mode 0
[  420.598503] spi-tegra124-slave 3210000.spi: spi can not start transfer, err -22
[  420.598559] spi_master spi0: failed to transfer one message from queue
[  949.159991] spidev spi0.0: setup: unsupported mode bits 20
I see the spi-slave module loaded:
agostrer@ubuntu:~$ lsmod | grep spi
spidev                 28672  0
spi_tegra114           28672  0
spi_tegra124_slave     36864  0
But I still don’t see the ‘/sys/class/spi_slave’ directory - spi0 is still under the spi_master:
agostrer@ubuntu:~$ ls -ltr /sys/class/spi_master/
total 0
lrwxrwxrwx 1 root root 0 Feb 24 15:06 spi1 -> ../../devices/platform/bus@0/3230000.spi/spi_master/spi1
lrwxrwxrwx 1 root root 0 Feb 24 15:06 spi0 -> ../../devices/platform/bus@0/3210000.spi/spi_master/spi0
spidev_test still is trying to send a message rather than receiving it:
agostrer@ubuntu:~/spi$ ./spidev_test -D /dev/spidev0.0 -o /tmp/file
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 kHz)
can't send spi message: Invalid argument
Aborted (core dumped)
What do I miss?
We have the reference setup in
Jetson/L4T/peripheral/ - eLinux.org
Please check if you can try the setup. And there is patch to SPI driver:
MCP2518FD not working with JetPack 6.0 GA - #22 by sevm89
Please apply it and rebuild kernel.
You mean that I need this patch even for JetPack-6.2?
Yes, it is required for Jetpack 6.2.
@DaneLLL, the reference setup looks clearly defined but I’m not sure about the patch to SPI driver. I see two different links under discussion you mentioned to spi-tegra114.txt files:
https://forums.developer.nvidia.com/uploads/short-url/eL0xVqmqNHTfLTmWisrzTuzCdZm.txt;
https://forums.developer.nvidia.com/uploads/short-url/v15FDCUVX3B7m1bNyWLuialp91u.txt;
Both are not patches, just source code. What should I do with it? Just replace the source/out/nvidia-linux-header/drivers/spi/spi-tegra114.c and rebuild the kernel? Why do I need it for the SPI-slave? The SPI-slave is using the spi-tegra124-slave driver, not spi-tegra114…
@DaneLLL , I found a spidev_test executable that it works with my SPI slave (even without the patch). The binary is attached to this thread: Jetson Nano trouble using SPI - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums. This is the binary itself: https://forums.developer.nvidia.com/uploads/short-url/orCHnP8AnFmCR2rxDDtmZOegMwi.txt
Where can I find the source code? It’s not a standard spidev_test binary, it has a lot of additions that I would like to use. The link that I posted above claims that spidev_test source is here: linux/tools/spi/spidev_test.c at master · torvalds/linux · GitHub. It’s not true. You can see it by comparing the GitHub print_usage() function
static void print_usage(const char *prog)
	printf("Usage: %s [-2348CDFHILMNORSZbdilopsvw]\n", prog);
	puts("general device settings:\n"
		 "  -D --device         device to use (default /dev/spidev1.1)\n"
		 "  -s --speed          max speed (Hz)\n"
		 "  -d --delay          delay (usec)\n"
		 "  -w --word-delay     word delay (usec)\n"
		 "  -l --loop           loopback\n"
		 "spi mode:\n"
		 "  -H --cpha           clock phase\n"
		 "  -O --cpol           clock polarity\n"
		 "  -F --rx-cpha-flip   flip CPHA on Rx only xfer\n"
		 "number of wires for transmission:\n"
		 "  -2 --dual           dual transfer\n"
		 "  -4 --quad           quad transfer\n"
		 "  -8 --octal          octal transfer\n"
		 "  -3 --3wire          SI/SO signals shared\n"
		 "  -Z --3wire-hiz      high impedance turnaround\n"
		 "data:\n"
		 "  -i --input          input data from a file (e.g. \"test.bin\")\n"
		 "  -o --output         output data to a file (e.g. \"results.bin\")\n"
		 "  -p                  Send data (e.g. \"1234\\xde\\xad\")\n"
		 "  -S --size           transfer size\n"
		 "  -I --iter           iterations\n"
		 "additional parameters:\n"
		 "  -b --bpw            bits per word\n"
		 "  -L --lsb            least significant bit first\n"
		 "  -C --cs-high        chip select active high\n"
		 "  -N --no-cs          no chip select\n"
		 "  -R --ready          slave pulls low to pause\n"
		 "  -M --mosi-idle-low  leave mosi line low when idle\n"
		 "misc:\n"
		 "  -v --verbose        Verbose (show tx buffer)\n");
	exit(1);
with the binary help:
agostrer@ubuntu:~/spi$ ./spidev_test_nvdia -h
Usage: ./spidev_test_nvdia [options]
 version 21
  -D --device   device to use (default /dev/spidev0.0)
  -g --length   transaction length in bytes. Multiple lengths can be comma separated.
  -z --debug    enable debug mode. Specifying more than once to increase the verboisty.
  -p --pattern  choose pattern type. Available patterns are:
                0: sequential bytes
                1: even bytes
                2: odd bytes
                3: reverse sequential bytes
                4: random bytes with crc
  -F prefix     Dump rx/tx buffer as raw to file. With no prefix specified, current pid will be used
  -f --file     Pattern file. User defined pattern. Not allowed with -p option.
                Pattern file must be in space seperated bytes in hex without
                "0x" prefix. Sample data: 01 AA 23 5F 3C 12
  -d --delay    delay (usec). For SPI master this will be the minimum delay
                the driver waits before initiating each transfer. For slave
                this indicates the max delay that the slave waits before it times out.
  -E --expect   Expected transaction length in bytes.
                To test variable length data transfer feature.
                Without this option, spidev_test will assume it as normal transfer
                and will validate the actual transferred length with requested transaction length.
                Value should be less than or equal to the transaction length.
  -n --nruns    Number of times to repeat the test. -1 is infinite.
  -u --udelay   delay b/w initiating each transfer (usec). Multiple delays can be comma separated
  -r --receive  only receive data
  -t --transmit only transmit data
  -v --minsize  variable length packet start
  -V --maxsize  variable length packet end
  -W --waitb4   wait for a keystroke before the first transfer
  -w --stoperr  stop on all errors
  -P --packet   packet mode
Examples:
To transfer 100 messages of 30 bytes each with random bytes,
  spidev_test -D/dev/spidev0.0 -s18000000 -n100 -g30 -p4
To transfer 100 messages of sizes 8 and 3986 with delay of 2ms and 8ms respectively,
  spidev_test -D/dev/spidev0.0 -s18000000 -n100 -g8,3968 -u2000,8000
To transfer all bytes from user defined pattern file,
  spidev_test -D/dev/spidev0.0 -s18000000 -f/path/to/patternfile
To test variable length feature,
  spidev_test -D/dev/spidev0.0 -s18000000 -g 30 -E 20
Return codes:
 0   successfull transfer. This would mean that what was
     transferred was actually received. Note that a success
     would make sense only when the spi is run in a loopback
     type configuration, i.e., a miso-mosi loopback or a
     master-slave loopback
 1   Invalid argument
 5   I/O error
 6   Data mismatch error. The transfer happened but there is
     mismatch in tx and rx pattern. Again this makes sense only
     for loopback as explained above
 22  Invalid argument
As you can see, there are a lot of differences. @ShaneCCC, maybe you have the answer?
Thank you,
Alex.
The binary is for testing purpose on Jetpack 4 and not eligible for later Jetpack release. Please use public spidev_test.
Please use the file to overwrite spi-tegra114.c for a try.
Hi @DaneLLL ,
I used the new spi-tegra114.c. I cannot say if I see any difference in the SPI slave behavior. It starts receiving then fails immediately. Without the source code I just don’t understand what is going on.
Thank you,
Alex.
Hi @DaneLLL ,
Any progress with the source code?
Thank you,
Alex.
Hi agostrer,
It is not the expected result to me if you’ve configured spi@3210000 to use as spi slave.
How do you configure the pinmux for those pins on SPI0 to use as spi slave?
Please run the following commands on your board and share both dmesg.log and extracted_proc.dts for further check.
$ sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
$ sudo dmesg > dmesg.log
Hi @KevinFFF ,
I set both spi@3210000 and spi@3230000 to be compatible with spi-slave (see attached device tree). Is there anything else I need to add to the device tree? It wasn’t clear from other posts.
dmesg.log (68.8 KB)
extracted_proc.txt (314.3 KB)
Uploaded requested files. Was needed to change .dts to .txt to get it uploaded.
Also:
agostrer@ubuntu:~/spi$ lsmod|grep spi
spidev 28672 0
Thank you,
Alex.
Do you want to use both SPI interfaces as SPI slave?
I would suggest you configure one as SPI master and another as SPI slave.
e.g. SPI1 as master and SPI3 as slave as following.
		spi@3210000 {
 			compatible = "nvidia,tegra114-spi";
		spi@3230000 {
 			compatible = "nvidia,tegra124-spi-slave";
And you can connect them like the following:
SPI1_MISO <— SPI3_MISO
SPI1_MOSI —> SPI3_MOSI
SPI1_SCK —> SPI3_SCK
SPI1_CS0 —> SPI3_CS0
I would also expect you’ve configured them in pinmux spreadsheet for SPI usage correctly before use.
Hi @KevinFFF
I used “sudo /opt/nvidia/jetson-io/jetson-io.py” to setup GPIOs. I guessed that it controls pinmux through the DTS, was I wrong?
We need to receive data from another device that works as the SPI master - one SPI slave on Jetson should be enough. I set two just to be sure. But you must be right and using Jetson SPI1 as master may help to make sure that SPI3 is setup correctly - I’ll try it.
I still want to see the source code of your spidev_test (NVIDIA spidev_test is different from the torvalds. Somehow your spidev_test puts the slave SPI into the mode, when it waits indefinitely for the data. I don’t see this option in the off-the-shelf spidev_test. What command do you send from spidev_test to wait for the data indefinitely?
Thank you,
Alex.
@KevinFFF , @DaneLLL , the test from Jetson/L4T/peripheral/ - eLinux.org is working on my setup.
Any progress with the source codes? Did Neel talk to you about them?
I found that the NVIDIA spidev_test sends an additional ioctl command 0x40206b00 that I don’t find in the off-the-shelf spidev_test. Trying to find how it waits for data when in the slave mode. It’s really reverse engineering without the source code. Can you escalate it please?
Thank you,
Alex.
Jetson-IO can be used to configure the pins’ pinmux for SPI usages.
Good to hear that workflow works at your side. It also means that you’ve configured them correctly. (both SPI master and SPI slave)
Yes, we have our spidev_test written for tegra SPI.
I’m not sure if I can share the source here. Please let me check this with internal.
Do you mean the -r option for spedev_test tool?
Hi @KevinFFF ,
Yes, I need to know how to put the slave into the receiving mode, how to specify the amount of data to be received, and when to read data. Can you respond to me (or your Santa Clara team) in the email? We have an NDA with NVIDIA.
Thank you,
Alex.
I figured out how to put the slave into waiting mode and receive a specified number of bytes (took me several iterations of the kernel rebuild with debug messages in spidev.c and spi.c files). The problem that the SPI slave fails if (the expected number of bytes by the slave) != (transmitted number of bytes from the master). How to solve it? We don’t know how much data we get to the SPI slave interface - it’s just a constant stream.
Do you mean that you’ve customized the spidev_test tool to configure SPI slave stay in receiving mode and you can receive the expected data from SPI master?
May I know what’s the exact data from your SPI master?
and what do you want the SPI slave to handle with?
Yes, I just changed “#if 0” to “#if 1” in spidev_test.c:151 and changed spidev_test.c:533 line to “transfer(fd, NULL/default_tx/, default_rx, 8/sizeof(default_tx)/);”. Now it waits for the master transmit and receives 8 bytes. But fails if master sends any other number of bytes. BTW, I experimented with the NVIDIA spidev_test utility. It fails for me if the number of bytes on receive and transmit sides do not match.
It’s just a stream of binary data at ~8Mbps. Different binary protocols that we need to parse on-the-fly.
Could you also share the original spidev_test.c file you were using?
And yes, you can just configure default_TX as NULL when you just want to receive data.
It seems you should configure the max transfer size rather than the exact data size for SPI slave since data transaction should be controlled by CS pin from SPI master.
May I also know where did you get our spidev_test utility?
