I want to run spi test by connecting spi1 and spi3 of jetson xavier nx board.
Before connecting spi1-spi3, I connected spi1’s MOSI-MISO (spi3’s MOSI-MISO) and tested with the spidev_test.c example to confirm that tx rx works well for both spi1 and spi3.
(Currently jetson xavier nx board has jetpack4.4 version installed.)
Here I have some questions.
How to do rx in spi slave?
Does an interrupt appear when data comes in?
Looking at the spi example (spidev_test.c), ioctl(fd, SPI_IOC_MESSAGE(1), &tr) is used to check tx and rx. Is this the only way to check rx?
If you check rx with ioctl(fd, SPI_IOC_MESSAGE(1), &tr), how do you know if the data has come in?
Are there any c++ examples of spi slaves?
For 1 and 2.
Configure as below. Add tegra124-spi-slave to the device tree.
Should be 1
open ssh terminal and start the spi slave first with following command
"./spidev_test -D /dev/spidev0.0 -s 150000 -n100 -g30 -p4 -z
In another terminal start the spi master with following command
“./spidev_test -D /dev/spidev3.1 -s 150000 -n100 -g30 -p4 -z”
(The photo shows’./spidev_test -D /dev/spidev0.0 -s 150000 -n10000 -g30 -p4 -z -r’, but When I used ‘./spidev_test -D /dev/spidev0.0 -s 150000 -n10000- g30 -p4 -z’ , the result was the same.)
[ 280.340212] spi-tegra124-slave 3230000.spi: Tx is not supported in mode 0
[ 280.340215] spi-tegra124-slave 3230000.spi: spi can not start transfer, err -22
[ 280.340301] spi_master spi2: failed to transfer one message from queue
There are a few things I’d like to ask in your answer.
Do you connect SPI1_MOSI<–>SPI3_MISO?
Why connect MOSI and MISO?
SPI1_MISO<–> Why doesn’t SPI3_MOSI connect?
Do I need to update the pinmux setting by changing from dt to slave means I have to flash again?
Can’t I do it in the following way?
(1) Activate spi1, spi3 in /opt/nvidia/jetson-io/jetson-io.py
(2) dtb decompile
—> sudo dtc -I dtb -O dts -o ~/ user-custom.dts / boot / tegra194-p3668-all- p3509-0000-user-custom.dtb
(3) Open the ~/ user-custom.dts file and change spi3(spi@3230000) to slave
(compatible = “nvidia, tegra186-spi” → compatible = “nvidia, tegra186-spi-slave”)
(4) dts compilation
—> sudo dtc -I dts -O dtb -o /boot/tegra194-p3668-all- p3509-0000-user-custom.dtb ~/user-custom.dts
(5) reboot jetson
(6) Change reg value using devmem2 (temporary)
(7) Connection: SPI1_MOSI<–>SPI3_MISO, SPI1_CLK<–>SPI3_CLK, SP1_CS0 ↔ SPI3_CS0 and SPI1_CS1<–>SPI3_CS1
(8) test
Where is the dt file? (Where should I change the spi3 slave?)
Where do I change the reg? Do I change it in my cfg (galen.cfg)?
Is the pinmux update method correct?
&&pinmux update method&&
(1) Jetson_Xavier_NX_Pinmux_Configuration_Template_v1.06 Set pinmux with .xlsm and create DT
(tegra19x-jetson_xavier_nx_module-gpio-default.dtsi, tegra19x-jetson_xavier_nx_module-padvoltage-default.dtsi, tegra19x-jetson_xavier_nx_module-pinmux.dtsi)
(2) Install Linux_for_Tegra with SDK Manager on Linux host PC
(3) Go to /Linux_for_Tegra/kernel/pinmux/t19x
(4) Import the dtsi( tegra19x-jetson_xavier_nx_module-gpio-default.dtsi, tegra19x-jetson_xavier_nx_module-padvoltage-default.dtsi, tegra19x-jetson_xavier_nx_module-pinmux.dtsi) file to the Linux host PC and create a cfg file.
----> python pinmux-dts2cfg.py --pinmux addr_info.txt gpio_addr_info.txt por_val.txt tegra19x-jetson_xavier_nx_module-pinmux.dtsi tegra19x-jetson_xavier_nx_module-gpio-default.dtsi 1.0>galen.cfg <------------
(5) Change galen.cfg to /Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01
(6) Flash with sdk manager (or sudo ./flash.sh jetson-xavier-nx-devkit mmcblk0p1
Can you give me the source file of spi_test.txt that you gave me?
I want to know how to slave (functions used, interrupts, etc.)
When testing by connecting spi1(master)-spi3(slave), should I connect both SP1_CS0 <–> SPI3_CS0 and SPI1_CS1->SPI3_CS1?
Do you connect only one of cs0 or cs1?
Here you are told to run the command
./spidev_test -D /dev/spidev0.0 -s 150000 -n100 -g30 -p4 -z,
but the source code you gave me does not have the -g, -p, -z, -n options.
Also, how do I test master(spi1) -slave(spi3) with this code?
I need to run the slave first and then the master, but when I run the slave (/dev/spidev2.0) I get an error.
can’t send spi message: Invalid argument
Aborted (core dumped)
<<<<< dmesg >>>>>>
I want to test by connecting spi1(master)-spi3(slave)!
Master doesn’t want to know
An error occurs when executing the slave mode program.
I modified dt and reg value as you tell me to do, but when I run the program an error occurs.
<<<<< dmesg >>>>>>
Please tell me how to run the program in slave mode.
If you look at the error that occurs when you run the program, it seems that there is a problem with tx in slave mode.
So I want to see the source code.
<<<<< dmesg >>>>>>
And I have another question.
In the source code, ioctl(fd, SPI_IOC_MESSAGE(1), &tr) sends and receives data to tx,rx included in the tr structure.
Do you use ioctl(fd, SPI_IOC_MESSAGE(1), &tr) to send and receive data even in slave mode?
Why!!! Can’t I!!!
What else do I need to fix?
Or do I need to create a new driver for the slave?
Should I create a new test program?
