How to configure SPI2 as a slave?
Hi teams
I use the agx xavier device, and L4T is R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t186ref, EABI: aarch64
I want to configure SPI2 as a slave mode device in Xavier. I want to know the configuration in the dt and pinmux settings.
And which addree is SPI 's address, is 0xc260000? Which document can i find the answer?
Thank you very much.
Can someone help me?
Xavier or Xavier NX?
You can use jetson-io to enable it for Xavier NX.
Hi it is AGX Xavier
Have reference to below topic for Xavier.
Hi ShaneCCC
Please answer me some questions
1: which address is SPI2 address, is 0xc260000?
2: set the SPI2 as slave mode - ( SPI2 = spi1, if SPI1 = spi0(the address is 3210000)) , the pinmux settings is what?
3: i will change the dt as below , is there any problems?
spi@c260000 {
		status = "okay";	//zp add
		spidev@0 {
			status = "okay";
	        compatible = "nvidia,tegra186-spi-slave";
	        spi@0 {
	            compatible = "spidev";
	            reg = <0>;
	            spi-max-frequency = <33000000>;
	            controller-data {
	                nvidia,enable-hw-based-cs;
Thanks so much for your answer and help.
                spi0 = "/spi@3210000";
                spi1 = "/spi@c260000";
                spi2 = "/spi@3230000";
  1. The pinmux configure are the same with master mode.
  2. No
and the pinmux setting is set as below, if you say the master mode and the slave mode is same, so the below setting is useful, right?
pinmux.0x0c302048 = 0x00000400; # spi2_sck_pcc0: spi2, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302050 = 0x00000450; # spi2_miso_pcc1: spi2, tristate-enable, input-enable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302028 = 0x00000400; # spi2_mosi_pcc2: spi2, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
pinmux.0x0c302038 = 0x00000400; # spi2_cs0_pcc3: spi2, tristate-disable, input-disable, io_high_voltage-disable, lpdr-disable
Have program them as below.
pinmux.0x0243d040 = 0x00000450; # spi1_sck_pz3: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d020 = 0x00000450; # spi1_miso_pz4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d058 = 0x00000450; # spi1_miso_pz4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d010 = 0x00000448; # spi1_cs0_pz6: rsvd1, pull-up, tristate-disable, input-enable, lpdr-disable
What is the command to get the receive date from spi2?
I use the command as below to get the date, but it does not work correctly.
root@dev-desktop:~/lab# ./spidev_test -D /dev/spidev1.0 -p dummy-8B
spi mode: 0x0
bits per word: 8
max speed: 12500000 Hz (12500 KHz)
can't send spi message: Invalid argument
Aborted (core dumped)
Could you enable SPI1 as mast and connect the SPI1 to SPI2 as loopback to run the test.
Does the SPI1 and SPI2 have internal connect channel for loopback test?
No, you have connect them from external.
Hi ShaneCCC
my spidev_test app does not have the ‘-g’ ‘-n’ options.
root@dev-desktop:~/lab# ./spidev_test_fpga -D /dev/spidev1.0 -s 12500000 -N 0  -g30 -p4 -z
./spidev_test_fpga: invalid option -- 'g'
Usage: ./spidev_test_fpga [-DsbdlHOLC3vpNR24SI]
Get the binary from below.
Hi i use your executable file,and dmesg as below
root@dev-desktop:~/lab# ./spidev_test -D /dev/spidev0.0 -s 150000 -n100 -g30 -p4 -z &
[1] 10769
root@dev-desktop:~/lab# using device: /dev/spidev0.0
spi mode: 0
bits per word: 8 bytes per word: 1
max speed: 150000 Hz (150 KHz)
no. runs: 100
/dev/spidev0.0: TEST FAILED !!!!! (status:-1)
[1]+  Exit 1                  ./spidev_test -D /dev/spidev0.0 -s 150000 -n100 -g30 -p4 -z
root@dev-desktop:~/lab# ./spidev_test -D /dev/spidev1.0 -s 150000 -n100 -g30 -p4 -z
using device: /dev/spidev1.0
spi mode: 0
no. runs: 100
transfer ioctl error: -1
spidev0.0 as spi master
spidev1.0 as spi slave, what command can let spidev1.0 used as slave mode to receive data
Make a script like below to run it.
sudo ./spidev_test -D /dev/spidev0.0 -s8000000 -g512 -b32 -H -p0 -n1 -r &
sleep 5
sudo ./spidev_test -D /dev/spidev1.0 -s8000000 -g512 -b32 -H -p0 -n1 -zzz -t
spidev0.0 still TEST error
root@dev-desktop:~/lab# ./spi.sh
Disabling receive
setting spi mode for read,write
setting spi bpw
setting max speed for rd/wr
spi mode: 1
bits per word: 32 bytes per word: 4
max speed: 8000000 Hz (8000 KHz)
no. runs: 1
Using seed:0x61078f1a
loop count = 0
using sequential pattern ....
transfer bytes [512]
0000: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
0010: 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F
0020: 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F
0030: 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F
0040: 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F
0050: 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F
0060: 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F
0070: 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F
0080: 80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F
0090: 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F
00A0: A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF
00B0: B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF
00C0: C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF
00D0: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
00E0: E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF
00F0: F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE 00
0100: 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10
0110: 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20
0120: 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30
0130: 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40
0140: 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50
0150: 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60
0160: 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70
0170: 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F 80
0180: 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F 90
0190: 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0
01A0: A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0
01B0: B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0
01C0: C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF D0
01D0: D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF E0
01E0: E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF F0
01F0: F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE 00 01
Now spi0.0 's pinmux is below
should i change it to the below version?
Below is NX setting. On Xavier NX spi1(spidev0.0) is master mode and spi3(spidev2.0) is slave mode.
Bank: 0 Reg: 0x0243d010 Val: 0x00000448 -> spi1_cs0_pz6
Bank: 0 Reg: 0x0243d020 Val: 0x00000444 -> spi1_miso_pz4
Bank: 0 Reg: 0x0243d040 Val: 0x00000444 -> spi1_sck_pz3
Bank: 0 Reg: 0x0243d050 Val: 0x00000448 -> spi1_cs1_pz7
Bank: 0 Reg: 0x0243d058 Val: 0x00000444 -> spi1_mosi_pz5
nvidia@nvidia-desktop:~$ sudo cat /sys/kernel/debug/tegra_pinctrl_reg | grep -i spi3
Bank: 0 Reg: 0x0243d008 Val: 0x00000444 -> spi3_miso_py1
Bank: 0 Reg: 0x0243d018 Val: 0x00000448 -> spi3_cs0_py3
Bank: 0 Reg: 0x0243d028 Val: 0x00000448 -> spi3_cs1_py4
Bank: 0 Reg: 0x0243d048 Val: 0x00000444 -> spi3_sck_py0
Bank: 0 Reg: 0x0243d060 Val: 0x00000444 -> spi3_mosi_py2
Hi ShaneCCC
My board is AGX Xavier. So please give me your advice about AGX Xavier pinmux setting.
