Maxine audio2face-2d docker connect error
Often I can’t connect to or use the docker server on my AWS instance until I restart the instance nvcr.io/nim/nvidia/maxine-audio2face-2d:latest Are there any logs on the AMI that can provide a hint as to what is going on?
Hi @paul377,
Support for A2F has moved to better help you get the support you need.
Thanks,
Sophie
