Hi
I have got a Quadro FX 5600 with 1.5GB global memory.
I’m trying to create a volume renderer for a quite big volume, based on the “volume renderer” example included in CUDA SDK’s projects.
I have got 2 big memory allocations to do on the device, both made by cudaMalloc:
- A constant allocation of ~40MB
- A memory block describing the whole volume which can get up to 460MB. This memory is then bound to a uchar texture in the same way it’s done in CUDA’s “volume renderer” project.
No other significant memory is allocated on the device.
When I try to allocate quite small volumes (checked up to 110MB), it works just fine, but when I try to allocate bigger volumes, I get no error message on runtime but the software doesn’t work.
Does anybody have any idea what the problem is?
