having a little bit of trouble with my C# implementations I need to ask a few questions.
Assume I have following code
__device__ float *ResultImageMatrix=NULL;
extern "C" void __global__ backprojectorCUDA()
ResultImageMatrix[0]=0;
ResultImageMatrix[1]=0;
ResultImageMatrix[2]=0;
From my C# environment I need to allocate the ResultImageMatrix since I don’t now in advance the size of the matrix.
Through the driver API I obtain the symbol by using cuModuleGetGlobal and there I get a CUdeviceptr which is OK.
I now need to allocate the data on the device, which I do with cuMemAlloc. But with this method I get a new CUdeviceptr which I cannot assign to the ResultImageMatrix.
How can I achieve to allocate memory for the ResultImageMatrix? I somehow need a way to set the new CUdeviceptr to the symbol.
Another question is if I had a ResultImageMatrix defined like this:
float ResultImageMatrix[1000];
is it possible to reallocate such a matrix?
I hope everything is clear for the reader, otherwise just write to me so that I can make things clearer.
Martin
