Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 8.4.1.5
GPU Type: NVIDIA GeForce GTX 1660
Nvidia Driver Version:
CUDA Version: 11.6
CUDNN Version: 8.4.0
I was deployed yolov8 to deepstream6.1 triton and run with 2 source(source0 and source1), each source using 3 num-sources. I have 6GB GPU memory but deepstream just use 2GB to run deepstream-app. How can I set up for using all memory of my machine. Thanks!!!
Here is my config:
[source0]
enable=1
enable_cuda_buffer_sharing=1
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=3
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=3
gpu-id=0
cudadec-memtype=0
[streammux]
gpu-id=0
live-source=0
batch-size=6
[primary-gie]
enable=1
#(0): nvinfer; (1): nvinferserver
plugin-type=1
#infer-raw-output-dir=triton-output
batch-size=1
interval=0
gie-unique-id=1
config-file=config_infer_plan_engine_primary.txt
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
