Memory Leak in CUDA 3.0
Hello, I was wondering if anyone can help me with the following…
Using CUDA 3.0 (nvcc Release 3.0 V0.2.1221) under Ubuntu 10.04 (64-bit) with gcc 4.3, valgrind is reporting memory leaks.
Example code:
[codebox]include <cuda_runtime_api.h>
int main()
int * host_array = new int [100];
for(int i=0; i<100; i++)
	host_array[i]=i;
int * dev_array = 0;
cudaMalloc((void**)&dev_array,100*sizeof(int));
cudaMemcpy(dev_array,host_array,100*sizeof(int),cudaMemcpyHo
stToDevice);
cudaFree(dev_array);
delete host_array;
return 0;
}[/codebox]
Compiling this with “nvcc memtest.cpp -o memtest.exe -g” and then running “valgrind ./memtest.exe --leak-check=full --track-origins=yes” I get:
Can anyone advise me as to whether I’m doing anything wrong or whether this is a bug in CUDA 3.0?
If the former, what am I doing wrong? If the latter, is there, or will there be, a fix?
Many thanks for your time,
Ralph
P.S. I get similar valgrind output when running the example program MonteCarloMultiGPU through valgrind.
