In our cuda application I experience a memory leak in nvcuda.dll that I have spotted with the tool ‘Memory Validator’ from Software Verify Ltd. This is the stack trace I got from Memory Validator:
id:1,595,284 <<33,286 objects>> void * : 8,521,216 bytes, largest allocation 256 bytes at 0x000000002e298cd0 : [NoFileName Line 0]
Allocation location 1 of 33,286 allocations, Largest: 256 bytes, Total: 8,521,216 bytes
Heap ID: 0x0000000000980000
nvcuda.dll Ordinal39 : [NoFileName Line 0]
Unfortunately I am not able to reproduce the problem in a simple program. We have a complex application, that under certain circumstances enters a ‘leak mode’ in which each call of cudaDeviceSynchronize() loses a memory block of 256 bytes.
Once this ‘leak mode’ has been entered, I can deactivate most parts of the running application, so that a loop with only two cuda commands is left:
loop
cudaMemset(…);
cudaDeviceSynchronize();
The ‘leak mode’ persists in this case.
The circumstances under which this ‘leak mode’ is entered are very unclear, not always reproducible and kind of random. But once it is entered, it persists (memory consumption is growing indefinitely, then).
Windows 7, 64bit
nVidia Driver Version 376.33
Cuda Runtime Version 6.5
GeForce GTX 960
Visual Studio 2010
