Memory leak in split pipeline
• Hardware Platform (Jetson / GPU): Jetson
• DeepStream Version: DS7.1
• JetPack Version (valid for Jetson only): 6.1
• TensorRT Version: 10.3
• Issue Type( questions, new requirements, bugs): questions
When I ran this pipeline for about 3 hours , I was able to verify by using the ps -aux command that it kept raising the physical memory usage without staying at a constant value.
Please tell me how to prevent memory leaks.
The following is a log showing the physical memory usage of gst-launch-1.0 obtained using the ps -aux command.
psinfo.gst2.log (10.6 MB)
I run this command in the docker container.
commnad
export USE_NEW_NVSTREAMMUX=yes
gst-launch-1.0 \
    v4l2src device=/dev/video0 ! "video/x-raw, width=1280, height=720, framerate=5/1" ! tee name=t \
    t.src_0 ! nvvideoconvert src-crop="0:0:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_0 \
    t.src_1 ! nvvideoconvert src-crop="320:0:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_1 \
    t.src_2 ! nvvideoconvert src-crop="640:0:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_2 \
    t.src_3 ! nvvideoconvert src-crop="960:0:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_3 \
    t.src_4 ! nvvideoconvert src-crop="0:180:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_4 \
    t.src_5 ! nvvideoconvert src-crop="320:180:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_5 \
    t.src_6 ! nvvideoconvert src-crop="640:180:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_6 \
    t.src_7 ! nvvideoconvert src-crop="960:180:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_7 \
    t.src_8 ! nvvideoconvert src-crop="0:360:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_8 \
    t.src_9 ! nvvideoconvert src-crop="320:360:320:18" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_9 \
    t.src_10 ! nvvideoconvert src-crop="640:360:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_10 \
    t.src_11 ! nvvideoconvert src-crop="960:360:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_11 \
    t.src_12 ! nvvideoconvert src-crop="0:540:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_12 \
    t.src_13 ! nvvideoconvert src-crop="320:540:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_13 \
    t.src_14 ! nvvideoconvert src-crop="640:540:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_14 \
    t.src_15 ! nvvideoconvert src-crop="960:540:320:180" copy-hw=2 ! "video/x-raw(memory:NVMM), format=NV12, width=320, height=180" ! nvvideoconvert ! "video/x-raw(memory:NVMM), width=1920, height=1080" ! mux.sink_15 \
    nvstreammux name=mux batch-size=16 ! \
    queue ! nvvideoconvert ! nvinfer config-file-path="/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/config_infer_primary.txt" model-engine-file="/opt/nvidia/deepstream/deepstream-7.1/samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine" ! \
    nvtracker tracker-width=1280 tracker-height=720 ll-lib-file="/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so" ! \
    tee ! \
    nvstreamdemux name=demux \
    demux.src_0 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_1 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_2 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_3 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_4 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_5 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_6 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_7 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_8 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_9 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_10 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_11 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_12 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_13 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_14 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0 \
    demux.src_15 ! queue ! tee ! queue ! nv3dsink sync=0 async=0 enable-last-sample=0
1.glibc may exhibit some memory usage fluctuations.
2.new nvstreamux is open source, If you suspect a memory leak in new nvstreammux, you can add the following two makefiles to the compilation options and then recompile.
This will allow you to use valgrind to check the number of potentially leaking function lines.
/opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvmultistream2/Makefile and /opt/nvidia/deepstream/deepstream/sources/libs/nvstreammux/Makefile
CFLAGS+= ....
+	 -O0 \
+	 -g
3.As an alternative, you can use videotestsrc to run continuously for 3 hours and then exit.
valgrind videotestsrc num-buffers=54000 pattern=0 ! video/x-raw,width=1280,height=720,framerate=5/1,format=NV12 ! ...
Thank you for your reply.
Add options to the two Makefile, I ran Valgrind using videotestsrc.
The following is the Valgrind log.
Is there a memory leak in nvstreammux?
valgrind_nvstreammux.txt (638.5 KB)
Only very minor leaks usually do not require treatment.
LEAK SUMMARY:
   definitely lost: 394,426 bytes in 355 blocks
   indirectly lost: 51,067 bytes in 682 blocks
     possibly lost: 508,912 bytes in 90 blocks
   still reachable: 16,731,348 bytes in 16,119 blocks
Main Persistent Memory Leaks:
118 bytes in 16 blocks (records 2719-2725) - Occurs multiple times, from gst_object_get_name in gst_nvstreammux_sink_query
528 bytes in 16 blocks (records 3435-3436) - From gst_nvstreamdemux_sink_event and gst_nvstreammux_sink_event
9,248 bytes in 16 blocks (record 3896) - From nvvideosinks library
Large Single-Instance Leaks:
72,704 bytes - From dlopen in nvtracker library
If you are very concerned about these leaks, please try the following patch and recompile nvstreammux/nvtracker. The remaining definitely lost data is not caused by deepstream.
diff --git a/sources/gst-plugins/gst-nvmultistream2/gstnvstreamdemux.cpp b/sources/gst-plugins/gst-nvmultistream2/gstnvstreamdemux.cpp
index 3d8c18f..cd02fff 100644
--- a/sources/gst-plugins/gst-nvmultistream2/gstnvstreamdemux.cpp
+++ b/sources/gst-plugins/gst-nvmultistream2/gstnvstreamdemux.cpp
@@ -796,6 +796,7 @@ gst_nvstreamdemux_sink_event (GstPad * pad, GstObject * parent,
 	  g_mutex_unlock (&nvstreamdemux->ctx_lock);
 	  //GST_OBJECT_UNLOCK (nvstreamdemux);
+	  gst_event_unref (event);
 	  return ret;
@@ -816,6 +817,7 @@ gst_nvstreamdemux_sink_event (GstPad * pad, GstObject * parent,
     LOGD("sending eos event on pad %d\n", source_id);
     gboolean ret = gst_pad_push_event (src_pad, gst_event_new_eos ());
     LOGD("eos send ret=%d\n", ret);
     return ret;
@@ -835,6 +837,7 @@ gst_nvstreamdemux_sink_event (GstPad * pad, GstObject * parent,
             stream_id + (char *)NULL));
       if (!src_pad)
         return TRUE;
       ret = gst_pad_push_event (src_pad, event);
@@ -843,6 +846,7 @@ gst_nvstreamdemux_sink_event (GstPad * pad, GstObject * parent,
       return ret;
     gst_message_unref(msg);
   if (GST_EVENT_TYPE (event) == GST_NVEVENT_STREAM_SEGMENT) {
diff --git a/sources/gst-plugins/gst-nvmultistream2/gstnvstreammux.cpp b/sources/gst-plugins/gst-nvmultistream2/gstnvstreammux.cpp
index 5d403da..befe88c 100644
--- a/sources/gst-plugins/gst-nvmultistream2/gstnvstreammux.cpp
+++ b/sources/gst-plugins/gst-nvmultistream2/gstnvstreammux.cpp
@@ -606,7 +606,7 @@ static gboolean
 gst_nvstreammux_sink_query (GstPad * pad, GstObject * parent, GstQuery * query)
   GstNvStreamMux *mux = GST_NVSTREAMMUX (parent);
-  gchar * name = gst_pad_get_name(pad);
+  gchar * name = GST_PAD_NAME(pad);
   guint stream_index = 0;
   GstQuery *peer_query;
   GstCaps* sink_caps;
@@ -615,7 +615,7 @@ gst_nvstreammux_sink_query (GstPad * pad, GstObject * parent, GstQuery * query)
     return FALSE;
   else if (sscanf (name, "sink_%u", &stream_index) < 1){
-    g_free(name);
+    // g_free(name);
     return FALSE;
@@ -1120,11 +1120,13 @@ gst_nvstreammux_sink_event (GstPad * pad, GstObject * parent, GstEvent * event)
     if( name == NULL )
         GST_DEBUG_OBJECT(mux, "Streammux sink event name null\n");
+        return FALSE;
         GST_DEBUG_OBJECT(mux, "Streammux sink event name invalid\n");
         g_free(name);
+        return FALSE;
     else
diff --git a/sources/gst-plugins/gst-nvtracker/gstnvtracker.cpp b/sources/gst-plugins/gst-nvtracker/gstnvtracker.cpp
index 78c1ec0..a3b4ceb 100644
--- a/sources/gst-plugins/gst-nvtracker/gstnvtracker.cpp
+++ b/sources/gst-plugins/gst-nvtracker/gstnvtracker.cpp
@@ -317,13 +317,7 @@ static gboolean gst_nv_tracker_start (GstBaseTransform * btrans)
 static gboolean gst_nv_tracker_stop (GstBaseTransform * btrans)
-  return TRUE;
-static void gst_nv_tracker_finalize (GObject * object)
-  GstNvTracker *nvtracker = GST_NVTRACKER (object);
+  GstNvTracker *nvtracker = GST_NVTRACKER (btrans);
   /** De-init the low-level threads and plugin */
   if(nvtracker->trackerIface) {
     nvtracker->trackerIface->deInit();
@@ -339,6 +333,12 @@ static void gst_nv_tracker_finalize (GObject * object)
     g_thread_join(nvtracker->output_loop);
   nvtracker->output_loop = NULL;
+  return TRUE;
+static void gst_nv_tracker_finalize (GObject * object)
+  GstNvTracker *nvtracker = GST_NVTRACKER (object);
     delete nvtracker->trackerIface;
Please advise on the cause.
I applied the patch you provided and ran it again.
I performed three runs under identical conditions and monitored the RSS feed.
However, I observed different results between the three runs.
Below is the RSS log during runs.
First run on Jetson Orin Nano.
Nano_full-patch-1.zip (673.0 KB)
Sencond run on Jetson Orin Nano.
Nano_full-patch-2.zip (482.2 KB)
I also ran it on AGX Orin.
Orin_full-patch.zip (209.1 KB)
Although the command line are same, and the running times are similar, the difference in the number of objects detected/tracked will lead to different memory usages. and the memory tend to plateau at least, I think it is normal.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
