• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version7.1.3.0-1+cuda10.2
**• Issue Type( questions, new requirements, bugs)**questions
Hi, I am trying to run inference with a custom unet model on my Jetson Nano. I trained it with tlt, then exported and created an engine file on the device. The engine file is around 37 MB. I use the deepstream-segmentation example from deepstream-python-apps to run a deepstream pipeline with this model. When loading the engine, the memory usage goes from 1.5 GB idle to 3.8 GB, so the system is almost freezing. This is happening before the actual inference takes place, during the model loading stage. Now when I try the dstest_segmentation_config_industrial.txt, the memory consumption only goes up to 2.7 GB from the 1.5 GB idle. I checked the .engine file for this config and it is 25 MB. so there are 2 questions from me
- Why would a model which weights 38 MB almost cause OOM while a 25 MB one does not?
- Why is the memory consumed in the range of GBs while the model size is around 20-30 MB?
