Sorry if this topic is redundant, but I have not found any information on the web.
I am new in GPU cuda programming and I am trying to copy a mex example on my pc, without success. I do not know if it is related to linux, matlab 2014 or something else.
I copied the following code, named AddVectorsCuda.cpp:
#include “mex.h”
#include “AddVectors.h”
void mexFunction(int nlhs,mxArray *plhs, int nrhs, mxArray *prhs)
if (nrhs!=2)
mexErrMsgTxt(“Invalid number of input arguments”);
if (nlhs!=1)
mexErrMsgTxt("Invalid number of outputs");
if (!mxIsSingle(prhs[0])&& !mxIsSingle(prhs[1]))
mexErrMsgTxt("input vector data type must be single");
int numRowsA=(int)mxGetM(prhs[0]);
int numColsA=(int)mxGetN(prhs[0]);
int numRowsB=(int)mxGetM(prhs[1]);
int numColsB=(int)mxGetN(prhs[1]);
if (numRowsA!=numRowsB || numColsA!=numColsB)
mexErrMsgTxt("Invalid size. The sizes of two vectors must be the same.");
int minSize=(numRowsA<numColsA) ? numRowsA:numColsA;
int maxSize=(numRowsA>numColsA) ? numRowsA:numColsA;
if (minSize!=1)
mexErrMsgTxt("Invalid size. The sizes of two vectors must be one dimentional.");
float* A=(float*)mxGetData(prhs[0]);
float* B=(float*)mxGetData(prhs[1]);
plhs[0]=mxCreateNumericMatrix(numRowsA,numColsB, mxSINGLE_CLASS, mxREAL);
float* C=(float*)mxGetData(plhs[0]);
addVectors(A,B,C,maxSize);
Where AddVectors.h
#ifndef ADDVECTORS_H
#define ADDVECTORS_H
extern void addVectors(float* A,float* B,float* C,int size);
#endif // ADDVECTORS_H
and AddVectors.cu:
#include “/usr/local/MATLAB/R2014a/extern/include/mex.h”
global void addVectorsMask(float* A, float* B, float* C,int size)
int i=blockIdx.x;
if (i>=size)
return;
C[i]=A[i]+B[i];
void addVectors(float* A,float* B, float* C, int size)
float *devPtrA=0, *devPtrB=0, *devPtrC=0;
cudaMalloc(&devPtrA, sizeof(float) * size);
cudaMalloc(&devPtrB, sizeof(float) * size);
cudaMalloc(&devPtrC, sizeof(float) * size);
cudaMemcpy(devPtrA, A, sizeof(float) * size, cudaMemcpyHostToDevice);
cudaMemcpy(devPtrB, B, sizeof(float) * size, cudaMemcpyHostToDevice);
addVectorsMask<<<size, 1>>>(devPtrA, devPtrB, devPtrC, size);
cudaMemcpy(C, devPtrC, sizeof(float) * size, cudaMemcpyDeviceToHost);
cudaFree(devPtrA);
cudaFree(devPtrB);
cudaFree(devPtrC);
I created the file object by using:
system(‘nvcc -c AddVectors.cu’)
Finally I compiled mex by using:
mex AddVectorsCuda.cpp AddVectors.o -lcudart -L"/usr/local/cuda/lib"
As result I got the following error message:
Building with ‘g++’.
Error using mex
/usr/bin/ld: AddVectors.o: relocation R_X86_64_32 against `.bss’ can not be used when making a shared
object; recompile with -fPIC
AddVectors.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
What’s the problem?
Thank you in advance for your help
