MiMo-V2.5 + DFlash speculative decoding on a 2× DGX Spark pair: 22 → 67 tok/s depending on workload
Xiaomi released MiMo-V2.5-DFlash last week — not a new model, but their 310B MoE backbone bundled with a 2.9 GB block-diffusion draft model (DFlash: fills a block of 8 masked tokens in one forward pass instead of drafting serially like EAGLE). I got it running on my GB10 pair this weekend. Numbers, gotchas, and full reproduction below.
TL;DR: you only need the dflash/ folder from the repo (2.9 GB) — pair it with the NVFP4 community quant you’re probably already running. On 2× Spark, TP=2 eager: 22.3 tok/s with no speculation → 27.6 prose / 45.4 code / 55.1 math / 66.9 JSON with DFlash. Acceptance scales with output structure, which also explains the “low acceptance anomaly” reported elsewhere.
Why the drafter is worth it on Spark specifically
Cross-node TP=2 on the QSFP link means every decode token pays ~48 cross-node all-reduces in eager mode. That latency is fixed per engine step, not per token — so a drafter that gets 3–6 tokens accepted per step amortizes exactly the thing that makes dual-Spark decode slow. This is the same bet as EAGLE3 setups people run here, but DFlash drafts the whole block in one forward instead of token-by-token.
What’s in the repo
  • The FP8 backbone (~328 GB, Xiaomi’s pp/ep-sharded format). Ignore it — it doesn’t fit on a pair (2× ~120 GB usable), and requantizing it buys you nothing over the existing community quant.
  • dflash/ — the drafter: 5-layer qwen3-arch, hidden 4096, SWA-1024, block size 8, cross-attends to backbone hidden states from layers [0, 11, 23, 35, 47], plus a mask_embedding.pt sidecar (the <|MASK|> vocab row is near-zero; without the sidecar your drafts are garbage — vLLM loads it automatically).
Target backbone: lukealonso/MiMo-V2.5-NVFP4 (~170 GB, fits TP=2 with room for 131K bf16 KV).
Software requirements
vLLM ≥ 0.23.1 nightly with three PRs: #45200 (merged a while back), #45181 (mixed KV page sizes — in nightlies since ~June 21), and #46104 (SWA + DFlash for MiMo — merged July 1, so anything older needs it applied by hand; it applies clean on late-June builds).
On top of the PRs, four things a stock build won’t do (details in the pitfalls section): register the mimo_v2 config type, fix the fused-qkv loader for this NVFP4 export, add SupportsEagle3 to the omni class, and port the PR’s non-causal window fix to the Triton backend.
The serve command
vllm serve lukealonso/MiMo-V2.5-NVFP4 \
  --trust-remote-code --dtype auto --kv-cache-dtype bfloat16 \
  --hf-overrides '{"architectures":["MiMoV2OmniForCausalLM"]}' \
  --speculative-config '{"method":"dflash",
      "model":"/path/to/dflash-mimo-v2.5/dflash",
      "num_speculative_tokens":7,
      "attention_backend":"TRITON_ATTN"}' \
  --enforce-eager \
  -tp 2 --gpu-memory-utilization 0.83 \
  --max-model-len 131072 --max-num-seqs 4 --max-num-batched-tokens 4096 \
  --enable-prefix-caching --enable-chunked-prefill \
  --enable-auto-tool-choice --tool-call-parser mimo --reasoning-parser mimo
num_speculative_tokens: 7 = the drafter’s block size (8) minus the bonus token. Download just the drafter with:
hf download XiaomiMiMo/MiMo-V2.5-DFlash --include "dflash/*" --local-dir <dir>
(both nodes need it). Env: the usual GB10 NVFP4 set (VLLM_NVFP4_GEMM_BACKEND=flashinfer-cutlass, VLLM_USE_FLASHINFER_MOE_FP4=1), NCCL_NET_GDR_LEVEL=LOC + NCCL_PROTO=LL for eager decode latency, NCCL_MAX_NCHANNELS=2.
Results (2× GB10, TP=2 cross-node, eager, single stream)
Config accept/draft tok/s
No speculation (baseline, same stack) — 22.3
DFlash — prose, temp 0 2.4 27.6
DFlash — code, temp 0 3.6 45.4
DFlash — math (step-by-step), temp 0 4.5 55.1
DFlash — JSON generation, temp 0 6.1 66.9
DFlash — prose, temp 0.7 1.45 24.4
DFlash — code, temp 0.7 3.4 44.1
Vision (omni class) and tool calling both work through the spec-decode path. 2K-token generations stay coherent.
On the “acceptance anomaly”
There’s an SGLang issue reporting accept_length 1.42 vs Xiaomi’s advertised 6.30 for the Pro variant, concluding the released drafter might not match training config. I initially reproduced the same scare — 1.85 on my first benchmark — but per-workload probing shows the drafter is fine: acceptance is just extremely workload-dependent. Free-form prose at nonzero temperature is the worst case (~1.5); structured output hits 6+. Xiaomi’s headline numbers are evidently from structured/reasoning workloads. If your traffic is agents doing tool calls (JSON-heavy), you’ll live in the 3.5–6 band, which is where this thing shines. Benchmark on your workload mix before concluding anything is broken.
Also honesty about attribution: don’t compare against your old stack and credit the drafter for everything. My previous deployment (older vLLM, 1M-context NVFP4-KV pool, MTP1) did 10.6 tok/s; moving to a current build with a lean 131K bf16-KV config got to 22.3 before any speculation. DFlash is the multiplier on top: +24% prose, +2–3× on structured output.
Pitfalls (each one cost me a failed launch)
  1. model_type: mimo_v2 unknown. Transformers 5.12 doesn’t know MiMo and the NVFP4 export has no remote code. Register a minimal PretrainedConfig subclass in vLLM’s _CONFIG_REGISTRY (a bare class carrying the checkpoint attrs is enough — vLLM’s model code does the rest).
  2. Upstream fp8 fused-qkv loader crashes on this checkpoint (size of tensor a (4096) must match ... (16384) in _shard_fp8_qkv_proj). The NVFP4 export stores qkv_proj.weight_scale_inv as MXFP8 E8M0 — U8, shape [rows, cols/32], row-aligned — not the fp8 128×128 block scales upstream assumes, and the fused QKV is laid out canonically [Q|K|V], not Pro-interleaved. Fix: split into q/k/v and delegate to QKVParallelLinear’s own weight_loader instead of hand-sharding.
  3. Garbage output that loads cleanly. MiMoV2OmniForCausalLM is missing packed_modules_mapping, so the ModelOpt mixed-precision config can’t unfuse gate_up_proj and the dense MLP layers (0–3) silently load MXFP8 packed weights as bf16. Output degenerates after a while and it looks like a sampling problem. Add the mapping to the omni class (and bias=True on the vision merger MLP while you’re in there).
  4. SupportsEagle3 on the wrong class. PR #46104 adds the aux-hidden-state interface to the text class. If you serve the omni class via --hf-overrides (you want vision), add SupportsEagle3 there too — the protocol’s default methods delegate through language_model.model and just work.
  5. FLASH_ATTN is not valid ... ['attention sinks not supported']. Both the MiMo backbone and the DFlash drafter use attention sinks, and the FA build for SM121 doesn’t support them — everything runs on TRITON_ATTN. But PR #46104’s non-causal sliding-window fix (bidirectional queries need a symmetric window (w,w), not causal-shaped (w,0)) only patched flash_attn.py. Port the same symmetrization to triton_attn.py’s unified_attention call, or your drafter’s block attention is silently wrong.
  6. Memory headroom is tighter than you think. 170 GB weights + 3 GB drafter + profiling peak at 0.80 GMU left me 0.19 GiB for KV. 0.83 works on a box that also runs other services; do the arithmetic for yours before burning a 10-minute load cycle.
  7. First-launch timeout. If you wrap this in systemd, TimeoutStartSec=3600. Cold loads of 170 GB take a while and the default will kill it mid-load.
Verdict
For a dual-Spark pair serving agent traffic, this is the best MiMo-V2.5 deployment I’ve found: 2–3× decode on exactly the workloads agents generate, vision and tools intact, and the drafter costs 3 GB. The published drafter is healthier than the early reports suggested — measure acceptance on structured output before writing it off.
Happy to share the full recipe/mod scripts if there’s interest.
Please share, also dockerfile. Thank you for.your work!
GitHub - DoctorMasterNewb/vLLM-Mimo-V2.5-Dflash-2x-DGX-Spark · GitHub @ciprianveg here you go
What is tps/acceptance at 100k/200k depth?
@tonyd615 @0rand how is this comparing to your experiments?
Does it have a speed advantage over mtp in longer ctx? like above 64k?
I fixed it with MTP but now working to make it work with dflash
These are similar numbers I’m getting on my Repo i also did nfvp and got 1M context
With Dflash NVFP4 KV Cache is not working for me, I will do 1M with most stable speed on FP8… got it running with 500K already
I’m wrapping up some more Minimax-M3 experiments right now then I’ll work on dflash+nvfp4kv, should get 1m, and I’ll do some deep context speed, acceptance and quality tests. the fix is staged and ready to test just waiting for VRAM…
Did you try my repo ?
@tonyd615 I did, I added your 1M token KV in, that worked well with MTP, was getting 22tok/s, the baseline numbers for this are with that build. Still cranking on M3, will add in the NVFP4 Kv and re-benchmark
Turning off video head gets you up to 1.5M Kv Cache I will update my repo
any updates?
Yes, repo completely updated and fable 5 says we hit the physical wall of performance, only a better drafter would help
i see , this one right? trying now , sorry didnt saw the link.
Yes, this one :)
Several problems here
  • run-recipes.sh is not included. can you add , looks like forget to stage and commit?
  • the models are downloaded to MiMo-oproj-mxfp8 but recipe is mounting them from model: /root/.cache/huggingface/MiMo-oproj-mxfp8 So it cannot find at all
  • I modified the recipe to lookinside my user directory and still dosen’t work.
Can you check?
It uses spark-vllm-docker to run it - just copy over stuff from the repo to your spark-vlllm-docker (mods, recipe).
Mounting point - inside the container, not real path. But I agree it needs hacking a bit, however, it’s hard to do otherwise without publishing the recipe, mods and supporting scripts building an custom checkpoint otherwise.
Don’t forget - it does not take a checkpoint tensors as they are, they need several operations applied to them plus DFLASH need to be downloaded and inserted, as lukealonso checkpoint does not have it - should be taken from the official repo on hf. Best advice is to send your agent. Otherwise you spend whole day.
PS performance is quite good now, [1], comparing to early stacks from Tony, that were painfully slow on medium context - almost unsusable, but quality was high (90+)
  1. PPS: see reports below on tool quality - you need to run implementation/tool calling as non-thinking at 0 temperature, then quality is really good. ↩︎
Did you bench or see it in real work that it got worse ?
