Mimo V2.5 Flash on 2 Nodes
I wanted to make a new post on this topic because I want to actually try to optimize this model. With all the models dropping I think Mimo will probably drop a updated version soon but Mimo V2.5 if multimodal and has 1Million Ctx and it can fit on 2 sparks it’s near the edge but it works but it has a few issues. I want to get together and find out what we need to do to get this thing optimized I think I clocked on 25toks but it stopped working. MiMo-V2.5-NVFP4 on 2x Spark Cluster - Recipe, findings, fixes, benchmarks - #31 by renek The original post. If we can get this smoother it will be best than Deepseek v4 flash.
They said they’re going to release the DFlash integrated version for the non pro model soon, so you might want to hold off for that.
Who is they ? Can you link me 🙏🏽
Xiaomi. They’ve already done it for their big model: https://mimo.xiaomi.com/blog/mimo-tilert-1000tps
Near the bottom they say: UltraSpeed support for MiMo-V2.5 is on the way — stay tuned
Has anyone tested its vision capabilities? I cant find a model yet that can accurately caption videos I have tried every combo of the smaller models with no luck.
But when haha
I have now 31 tk/s and it’s my daily driver with Hermes
recipe ?
say what? share details pls
prepped by Claude 4.8 Max
Running MiMo-V2.5 (310B NVFP4 Omni) at ~30–33 tok/s on 2× DGX Spark (GB10, SM 12.1, TP=2)
After a lot of iteration, MiMo-V2.5-NVFP4 serves stably on a two-node DGX Spark cluster (2× GB10) over vLLM, TP=2. ~30–33 tok/s single-stream decode, ~57–63 tok/s aggregate at 3 concurrent streams. It does not run out of the box on SM 12.1 — here’s the full recipe.
Hardware / software
  • 2× NVIDIA DGX Spark (GB10), SM 12.1, 128 GB unified each; RoCE/QSFP for the TP all-reduce
  • Model: lukealonso/MiMo-V2.5-NVFP4 — 310B MoE, NVFP4 experts + MXFP8 dense + Omni tower (~86 GB/rank resident)
  • vLLM dev114 line built with PR #41797, CUDA 13.2, TORCH_CUDA_ARCH_LIST=12.1a
  • Driver note: 595.71.05 gives a smaller KV pool (~233K tok) than 595.58.03 (~368K); no throughput difference
The core blocker on SM 12.1
Stock MiMo-V2 forces the FlashAttention-DiffKV backend, which asserts FA3 for attention sinks — GB10 only has FA2 → first inference crashes. Fix: run the Triton DiffKV backend from vLLM PR #41797:
--attention-backend triton_attn_diffkv
The 3 fixes that were all required
  1. Triton DiffKV (PR #41797) instead of FlashAttention DiffKV.
  2. MXFP8 dense dispatch: MiMo is a mixed quant (NVFP4 experts + MXFP8 dense). The modelopt_mixed path didn’t route the dense layers through MXFP8 kernels → garbage logits. Patch the modelopt-mixed handling.
  3. Quantized KV on DiffKV: TRITON_ATTN_DIFFKV raises NotImplementedError on any quantized kv_cache_dtype, but the underlying store kernel already accepts dtype + scales. The guard is defensive — disable it to run --kv-cache-dtype fp8_e4m3, which roughly doubles the KV pool.
Plus, for the Omni multimodal path: serve the absolute snapshot path (not the HF repo id), or the audio_tokenizer loader breaks; and don’t skip the audio_tokenizer. weights.
Working configuration
tensor_parallel_size      2
gpu_memory_utilization 0.89 # hard ceiling — 0.90 fails the GB10 startup guard
max_model_len 163840 # 160K
max_num_batched_tokens 8192
max_num_seqs 6
block_size 32
kv_cache_dtype fp8_e4m3
attention_backend triton_attn_diffkv
speculative-config {"method":"mtp","num_speculative_tokens":2}
--enforce-eager # CUDA graphs blow the KV budget at 160K
--enable-prefix-caching --enable-chunked-prefill
--load-format instanttensor
--enable-auto-tool-choice --tool-call-parser mimo --reasoning-parser mimo
--distributed-executor-backend ray
Relevant env:
PYTORCH_CUDA_ALLOC_CONF=expandable_segments:True
VLLM_NVFP4_GEMM_BACKEND=flashinfer-cutlass
VLLM_USE_FLASHINFER_MOE_FP4=1
VLLM_FLASHINFER_MOE_BACKEND=throughput
NCCL_CUMEM_ENABLE=0
NCCL_NVLS_ENABLE=0
NCCL_NTHREADS=8 NCCL_NSOCKS_PERTHREAD=2 NCCL_BUFFSIZE=8388608
VLLM_USE_RAY_V2_EXECUTOR_BACKEND=0 # each "1" costs ~12 GiB on node 2 → freeze
VLLM_USE_RAY_COMPILED_DAG_OVERLAP_COMM=0
Notes:
  • MTP = 2 — model is trained for 2 speculative tokens; MTP=3 is ~6% slower. Acceptance: pos-0 ≈ 86%, pos-1 ≈ 45%, overall ≈ 65%. This is what gets single-stream to ~30 (vs ~14 without).
  • --enforce-eager — CUDA graphs don’t fit the KV budget at 160K.
  • NCCL on GB10: newer NCCL (v2.30u1) reserves a ~7.5 GiB CGA buffer that pushes the startup check over; use a GB10-targeted NCCL build + NCCL_CUMEM_ENABLE=0.
Performance
  • Single-stream decode: ~30–33 tok/s
  • 3 concurrent streams: ~57–63 tok/s aggregate
  • KV pool ~233K tokens (fp8 KV); theoretical roofline on 2× GB10 ≈ 52 tok/s, so single-stream is ~60% of roofline — MTP is the lever that gets it there.
All Omni modalities work (image/video/audio); tool-calling works with --tool-call-parser mimo.
Going to tinker with this now
how is it going ? any optimizations i missed ? :)
going to run this today I passed out also what was you max context you tried ?
you can go to max single stream from above info but i need concurrency… with older Nvider firmware you could go up to 300K
GitHub - tonyd2wild/MiMo-V2.5-NVFP4-2x-DGX-Sparks-TP-2: Tuned recipe: Xiaomi MiMo V2.5 (NVFP4) on 2x DGX Spark, vLLM TP=2 over RoCE. ~32-33 tok/s, Quality 89.9, 160K context, omnimodal + tool-calling. Non-eager + MTP=2. · GitHub we got it going.a little faster up to 38 tok/s
Also tinkered myself a bit and got 39tk/s with synthetic tests but real world only around 33tk/s, I guess thats the cap till we get dflash
Might of got a breakthrough might need to make a new post on this one will find out in the next few moments
found something ?
i have now NVFP4 KV Cache enabled, with 2 Nodes over 500K KV Cache, further optimizing, later i will post the image for easy replication
