I am trying to locate MIP CSI Drivers for the Jetson AGX. Are they available? If so, where can I find them? I have installed JetPack 4.3 on my Jetson AGX.
Esterina
Esterina
Follow below link to download the source. The driver should be …/kernel/nvidia/drivers/media/i2c/
Thanks; I have used the SDK manager to flash JetPack 4.3.
Please confirm that this would also give me the CSI MIPI sensor drivers.
Since I am new to Unix, can you please specify the exact path rather than … in the line below.
I am unable to find it. Also this is referring to i2c rather than MIPI CSI.
Thank You.
Have a check this document for the sensor programing guide first.
Thanks for the link to the Sensor Software Driver Programming Guide.
I am at “Camera Modules and the Device Tree”.
Step 1. Locate or create a tegra-camera-platform device tree node in the kernel source tree at:
/hardware/nvidia/platforms …
WHere is the directory where you installed the board support package.
Using the SDK Manager, I installed JetPack 4.3 Does that include the Board support package.
I am still trying to find
Also there is reference to imx185.c etc. Where did you get that from?
I cannot find it.
Esterina
Please read through the l4t document and you should be able get the much detail information.
