Hello,i use lt6911uxe in JetsonOrinNX16GB,and bsp is 35.5.0.
I configured the device tree and the driver, and the system generated /dev/video0 as normal, but I ran into problems when I tried to use the device.
cat /dev/video0
[ 1564.887992] bwmgr API not supported
[ 1567.623475] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1.636248] ra-rtc-care-vi tegra-cape-vi: errc: attempting to rt tcaphannel
[ 1567.66130(NULL device *): vi_cure_contrmessage: NULL Vhannel received
[ 1.679970] t19vcs3e40.h1x:15a00000: csstreamose: Er in closingread=0, cpor
[ 1.70490(NUdevice *): vi_capt_contrmessage: NULL VI chan received
[ 1.72tegra-camrtc-capture-vi tegra-capturi: _rec: cessfully re the capture channel
[ 1.774921] tegcam-captuvi ra-capture-vi: uncorrr: requesimed out er 2500 ms
[ 1925.797383] tegra-rtc-care-vi tegcapturi: errc: attting tesehe ture c[ 19250510] LL ice: vi_capture_cool_message: NULL VI channel received
[ 1925.84t19vcsi 10000.h1x:nvcsi@15a000 csi5_streamose: Error in cing stread=0, csi_t=0[ 1.86745(NULL device *)apt_control_e: NULI channel reved
[ 1.18tegra-cam-captuvi tegcape-vi: _rec: successfullyset the cureannel
I refer to the article here for testing,also a failure.
Bwmgr API not supported error on Orin AGX - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
[ 2974.153174] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[ 2974.161581] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
[ 2975.180973] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[ 2975.189320] tegra194-vi5 13e40000.host1x:vi0@15c00000: csi_stream_release: failed to disable nvcsi tpg on stream 0 virtual channel 0
please help me,thank you
