• Hardware Platform (Jetson / GPU) GPU • DeepStream Version - 6.3 • JetPack Version (valid for Jetson only) - 5.1.1 • TensorRT Version - 8.5.2 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) Questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I have trained a custom PoseClassificationNet using Nivida tao toolkit for 3 classes and achieved an accuracy > 90% for each class.
When I integrate it with DeepStream Pose Classification, The results are totally wrong even for the videos that were used for training PoseClassification.
Q1. What are configurable parameters that we should tune to get the better results?
I Trained the Tao PoseClassificationNet on my data and got the accuracy of more than 90% for each class on the test dataset.
The problem arises when I integrated with DeepStream Pose Classification . After Integration when I test on training video which was used to train the Tao PoseClassificationNet , the results are totally wrong . I even tested for different frame-sequence-length .
The same video when tested on solely on Tao PoseClassificationNet gives the correct prediction and not when tested with the DeepStream Pose Classification Pipeline
You may need to customize your own preprocess according to your model.
Could you please elaborate it in more detail about what kind of preprocess is required to order to improve the accuracy of the pipeline and where does it needs to be added?
Frames before this value are sent with default data, so they may not be accurate.
Could you please let me know where is the code for this in the DeepStream Pose Classification scripts and how we can disable it?
Can you describe in detail how you tested on solely with Tao and send the source video to us?
