Missing kernels in a .cubin file? Not all of my kernels are showing up in a .cubin file
Hello-
I have a main.cu file with two marginally different kernels (and nothing else). When I run nvcc -cubin main.cu and inspect the resulting .cubin file, only one of the kernels is present. nvcc does not throw any errors or warnings. I made sure the .cubin file was getting recompiled. This is on mac os x 10.5, using version 2.0 of the cuda toolchain.
I tried asking my cuda-using friend. He says that due to the cubin embargo, kernels in the cubin army need special passports. Anyone have a better explanation?
Cheers,
Drew
Could you post the function headers for the kernels?
Also, the compiler inlines all device kernels. So if one of them has a device prefix only, it probably won’t get a separate entry in the cubin.
these are prototypes for the two functions I have in my .cu file:
global void MatrixMultiplierKernel1( float* C, float* A, float* B, int hA, int wB, int wA);
global void MatrixMultiplierKernel2( float* C, float* A, float* D, float* B, int wA, int wB);
[codebox]// nvcc -cubin main.cu
/* Matrix multiplication: C = A * B.
  • Host code.
  • This sample implements matrix multiplication and is exactly the same as
  • Chapter 7 of the programming guide.
  • It has been written for clarity of exposition to illustrate various CUDA
  • programming principles, not with the goal of providing the most
  • performant generic kernel for matrix multiplication.
  • CUBLAS provides high-performance matrix multiplication.
// includes, system
//include <stdlib.h>
//include <stdio.h>
//include <string.h>
//include <math.h>
//include <cutil.h>
define KERNEL1_BLOCK_SIZE 16
define KERNEL2_BLOCK_SIZE 16
global void trivial_kernel(int* a) {
// (*a)++;
__shared__ int a_shared;
a_shared = a[0];
a_shared++;
a[0] = a_shared;
//! Matrix multiplication on the device: C = A * B
//! wA is A’s width and wB is B’s width
// Block index
int bx = blockIdx.x;
int by = blockIdx.y;
// Thread index
int tx = threadIdx.x;
int ty = threadIdx.y;
// Index of the first sub-matrix of A processed by the block
int aBegin = wA * KERNEL1_BLOCK_SIZE * by;
// Index of the last sub-matrix of A processed by the block
int aEnd   = aBegin + wA - 1;
// Step size used to iterate through the sub-matrices of A
int aStep  = KERNEL1_BLOCK_SIZE;
// Index of the first sub-matrix of B processed by the block
int bBegin = KERNEL1_BLOCK_SIZE * bx;
// Step size used to iterate through the sub-matrices of B
int bStep  = KERNEL1_BLOCK_SIZE * wB;
// Csub is used to store the element of the block sub-matrix
// that is computed by the thread
float Csub = 0;
// Loop over all the sub-matrices of A and B
// required to compute the block sub-matrix
for (int a = aBegin, b = bBegin;
         a <= aEnd;
         a += aStep, b += bStep) {
// Declaration of the shared memory array As used to
    // store the sub-matrix of A
    __shared__ float As[KERNEL1_BLOCK_SIZE][KERNEL1_BLOCK_SIZE];
// Declaration of the shared memory array Bs used to
    // store the sub-matrix of B
    __shared__ float Bs[KERNEL1_BLOCK_SIZE][KERNEL1_BLOCK_SIZE];
// Load the matrices from device memory
    // to shared memory; each thread loads
    // one element of each matrix
    As[ty][tx] = A[a + wA * ty + tx];
    Bs[ty][tx] = B[b + wB * ty + tx];
// Synchronize to make sure the matrices are loaded
    __syncthreads();
// Multiply the two matrices together;
    // each thread computes one element
    // of the block sub-matrix
    for (int k = 0; k < KERNEL1_BLOCK_SIZE; ++k)
        Csub += As[ty][k] * Bs[k][tx];
// Synchronize to make sure that the preceding
    // computation is done before loading two new
    // sub-matrices of A and B in the next iteration
    __syncthreads();
// Write the block sub-matrix to device memory;
// each thread writes one element
int c = wB * KERNEL1_BLOCK_SIZE * by + KERNEL1_BLOCK_SIZE * bx;
C[c + wB * ty + tx] = Csub;
#if 0
//! Matrix multiplication on the device: C = A * D * B
// wD = hD = wA
// Block index
int bx = blockIdx.x; // blocks
int by = blockIdx.y; // blocks
// Thread index
int tx = threadIdx.x; // bytes
int ty = threadIdx.y; // bytes
int aBegin = wA * KERNEL2_BLOCK_SIZE * by; // (KERNEL2_BLOCK_SIZE*by) is the number of rows down, wA is the pitch.
int aEnd   = aBegin + wA - 1; //
int aStep  = KERNEL2_BLOCK_SIZE;
int bBegin = KERNEL2_BLOCK_SIZE * bx;
int bStep  = KERNEL2_BLOCK_SIZE * wB;
// Index of the first sub-Matrix of D processed by the block.
// int dBegin = KERNEL2_BLOCK_SIZE *
float Csub = 0;
__shared__ float As[KERNEL2_BLOCK_SIZE][KERNEL2_BLOCK_SIZE];
__shared__ float Bs[KERNEL2_BLOCK_SIZE][KERNEL2_BLOCK_SIZE];
// Hold a subvector of the diagonal of D in shared memory.
__shared__ float Ds[KERNEL2_BLOCK_SIZE][KERNEL2_BLOCK_SIZE];
for (int a = aBegin, b = bBegin, d = 0;
         a <= aEnd;
         a += aStep, b += bStep, d+=KERNEL2_BLOCK_SIZE) {
    AS[ty][tx] = A[a + wA * ty + tx];
    BS[ty][tx] = B[b + wB * ty + tx];
	DS[ty][tx] = D[d + ty];
	// Note: Should we multiply the rows of B by the values in the appropriate block of D in a separate kernel?  Another Kernel call vs. More multiplications...
	// Note: This implementation results in duplication of data (Each row is the same).  Is this cheaper than branching using an if statement?
				// The reads from global memory are cached
	// Note: There is thread read overlap reading from device memory, but no overlap writing into shared memory.  -> Could save some shared memory at the cost of overlapping writes.
    __syncthreads();
    for (int k = 0; k < KERNEL2_BLOCK_SIZE; ++k) {
        //Csub += AS(ty, k) * BS(k, tx);  // Debugging Version: Check if everything ~but d is working...
		//Csub = DS(ty, tx);  // Debugging: Check if D is getting filled in...
        Csub += AS[ty][k] * DS[k][tx] * BS[k][tx];
	// Note: Does this result in a bank conflict?  Or is the same value broadcast to the 16 thread half-warp?
    __syncthreads();
int c = wB * KERNEL2_BLOCK_SIZE * by + KERNEL2_BLOCK_SIZE * bx;
endif
[/codebox]
I decided to work around this by using the runtime API instead of trying to load .cubin modules with the driver API.
nvcc defaults to C++ now, thus the names are probably getting mangled.
All kernels you want to be exported in a cubin must be prefixed with ‘extern “C” global’ for C++, and just __global for C. (basic C++)
Unless the compiler is spitting out any other errors/warnings, they are being exported properly.
thanks Smokey!
