Hi everyone,
I am trying to run pure Text-to-Video generation using the Wan2.1-14B model via the Lyra-2 repository. My environment and hardware are fully prepped and recognized, but I am entirely blocked by the lack of a standard generate.py or Text-to-Video entry point in the Lyra-2 codebase.
I’m hoping someone familiar with this specific fork/repo can point me to the correct launch script.
💻 System & Environment (What Works)
Hardware: NVIDIA RTX PRO 6000 (Blackwell, 96GB VRAM).
OS: WSL2 (Ubuntu) via Windows.
PyTorch:
2.12.0-nightly(Successfully detects the GPU and supports Compute Capabilitysm_120). -
Weights: Fully downloaded and verified. The
wan2.1-14Bcheckpoint directory contains all 6.safetensorsshards, theconfig.json, and the T5 encoder (models_t5_umt5-xxl-enc-bf16.pth).
🛑 The Blocker
We cannot find the actual Python entry point to trigger a simple prompt-to-video generation. The standard scripts found in the original Wan2.1 repository (like generate.py) do not exist in this Lyra-2 folder structure (lyra_2/_src/inference/).
🛠️ Troubleshooting Steps & Trials
We ran traces and executed several scripts in the inference folder, but all either silently failed or were designed for different pipelines:
Tried:
lyra_2/_src/inference/lyra2_ar_inference.py- Result: Silent exit. We ran a Python trace and confirmed this is just a library file of functions (missing the
if __name__ == "__main__":block).
Tried:
lyra_2/_src/inference/vipe_da3_gs_recon.py- Result: Fails demanding an
--input_video_path. This is strictly a 3D Gaussian Splatting video-to-3D reconstruction script, not T2V.
Tried:
lyra_2/_src/inference/lyra2_custom_traj_inference.py- Result: Fails demanding
--input_image_pathand--trajectory_path. This is an Image-to-Video camera trajectory pipeline, not pure Text-to-Video.
Searched for T2V Logic:
- We found
wan_t2v_model.pyunder_src/models/, proving the model class exists in the repo, but we cannot find the corresponding inference script that calls it for a basic text prompt.
- We found
The Ask: Has anyone successfully run a pure text prompt to video (no starting image, no input video) using the 14B model within this specific Lyra-2 file structure? If so, what is the exact execution command or script name?
Thanks in advance for the help!
