• Hardware (T4/V100/Xavier/Nano/etc) T4
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) Yolo_v4
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
im using above link , i can get the link of video inference , since the above link file tao_client.py
has only Image Inference, as i need Video inference as well .
Unfortunately, the triton app does not support video inference.
could you provide python3 Parser for yolov4 and TAO models ,
im referring deepstream_python_apps/apps/deepstream-ssd-parser at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
could you provide relavent to add on top it of instead of SSD parser , i need to replace with python3 yolov4 parser
im using below config , im not able to get the meta-data and im using deepstream
infer_config {
unique_id: 1
gpu_ids: [0]
max_batch_size: 4
backend {
inputs: [ {
outputs: [
{name: "BatchedNMS"},
{name: "BatchedNMS_1"},
{name: "BatchedNMS_2"},
{name: "BatchedNMS_3"} ]
triton {
model_name: "Helmet_model"
version: 1
grpc {
url: "localhost:8001"
#url: "3.141.193.122:8001"
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_LINEAR
maintain_aspect_ratio: 0
frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
frame_scaling_filter: 1
normalize {
scale_factor: 0.0078125
channel_offsets: [128, 128, 128]
postprocess {
labelfile_path: "labels.txt"
detection {
num_detected_classes: 2
custom_parse_bbox_func: "NvDsInferParseCustomYoloV4"
nms {
confidence_threshold: 0.3
iou_threshold: 0.6
topk : 100
extra {
copy_input_to_host_buffers: false
output_buffer_pool_size: 2
custom_lib {
path:"/deepstream_yolov4/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so"
input_control {
process_mode: PROCESS_MODE_FULL_FRAME
interval: 0
output_control {
output_tensor_meta: true
and i get below error
python3: nvdsparsebbox_Yolo.cpp:139: bool NvDsInferParseCustomYoloV4(const std::vector&, const NvDsInferNetworkInfo&, const NvDsInferParseDetectionParams&, std::vector&): Assertion `boxes.inferDims.numDims == 3’ failed.
Morganh:
Please directly use
we are able to run the TAO apps with normal deepstream app , since we have loaded MODELS IN TRITON SERVER , we need to use the above config and run . But im getting error for custom model.
For running TAO model in triton server, refer to GitHub - NVIDIA-AI-IOT/tao-toolkit-triton-apps: Sample app code for deploying TAO Toolkit trained models to Triton
Firstly, you can run the default github to get familiar with the process.
Then, you can replace your etlt model with default one. And then comment out
line72,73,74 of tao-toolkit-triton-apps/start_server.sh at main · NVIDIA-AI-IOT/tao-toolkit-triton-apps · GitHub to let it not download the default lpr model next time when you trigger server.
i have tried it . its working with our MODEL . But it doesnt have Video Inferece . Only Image inference exist
i need the way take out this parser and push it to deepstream -app
i tried with the parser of
GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream
but i got below errror now
ERROR: infer_postprocess.cpp:344 Detect-postprocessor failed to init resource because dlsym failed to get func NvDsInferParseCustomBatchedNMSTLT pointer
0:00:00.390680778 20514 0x448e2d0 ERROR nvinferserver gstnvinferserver.cpp:361:gst_nvinfer_server_logger: nvinferserver[UID 1]: Error in allocateResource() <infer_cuda_context.cpp:519> [UID = 1]: failed to allocate resource for postprocessor., nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
0:00:00.390708228 20514 0x448e2d0 ERROR nvinferserver gstnvinferserver.cpp:361:gst_nvinfer_server_logger: nvinferserver[UID 1]: Error in initialize() <infer_base_context.cpp:109> [UID = 1]: Failed to allocate buffers
0:00:00.390745052 20514 0x448e2d0 WARN nvinferserver gstnvinferserver_impl.cpp:510:start: error: Failed to initialize InferTrtIsContext
0:00:00.390759029 20514 0x448e2d0 WARN nvinferserver gstnvinferserver_impl.cpp:510:start: error: Config file path: config/TripleRiding/config_infer.txt_SoFile
0:00:00.392358949 20514 0x448e2d0 WARN nvinferserver gstnvinferserver.cpp:459:gst_nvinfer_server_start: error: gstnvinferserver_impl start failed
Warning: gst-library-error-quark: Configuration file batch-size reset to: 1 (5): gstnvinferserver_impl.cpp(287): validatePluginConfig (): /GstPipeline:pipeline0/GstNvInferServer:primary
below is the customlib i have used
custom_parse_bbox_func:“NvDsInferParseCustomNMSTLT”
custom_lib {
path:“deepstream_tao_apps/post_processor/libnvds_infercustomparser_tao.so”
and i see same error in the lnk
Hi !
I’m trying to run a Yolov4 model on my jetson nano (jetpack 4.5) but I have an error while running my model with python sample apps.
I followed the documentation to export the model (exported both in fp16, int8).
Here are the command I used :
!yolo_v4 export -m $USER_EXPERIMENT_DIR/data/kitti/final-test/yolo_v4/weights/yolov4_resnet18_epoch_012_pruned.tlt
-o $USER_EXPERIMENT_DIR/data/kitti/final-test/yolov4_resnet18_epoch_020_pruned_int8.etlt
-e $SPECS_DIR/yolo_v4_retrain_resnet18…
Is above error from running deepstream_python_apps?
Actually for tao model, as mentioned in the TAO user guide, the official app is GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream . Please use it instead.
i have loaded the Model in Triton Server , but the above AI-IOT app is in deepstream . How could i use TAO app where the Model is loaded through triton Server
Actually the deeptream tao apps is one of the inference way.
The triton-app is another inference way.
The deeptream tao apps can generate tensorrt engine. You can also deploy .etlt model in it.
i have deployed as trt engine model itself , but i need to TAO parser just like SSD parser since im
using below deepstream app as an reference
deepstream_python_apps/deepstream_ssd_parser.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
i need to modify
deepstream_python_apps/ssd_parser.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
to parse trt engine model , if u can provide supporting parser as above one that would be good
We need Video Inference as well , GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream
above link is only for Image Inference . From the above link im able to use my custom model and do the inference .
But we need for the VIDEO Inference as well .>!!
