Missing t194-p2822-0000-a00.dtsi?
Dear Tegra Device Tree Experts,
From the online documentation NVIDIA Jetson Linux Driver Package Software Features in both 32.2 and 32.3 releases, in Sensor Software Driver Programming GuideDevice Registration Using the Main Platform Device Tree File :
In step #3 :
3. Locate and edit the .dtsi file:
<top>/hardware/nvidia/platform/t19x/galen/kernel-dts/common/t194-p2822-0000-a00.dtsi
I cannot really find the above file but “tegra194-p2822-0000-a00.dtsi”. Are they the same? Could anyone confirm me if the documentation is correct?
Beside, in step #4 :
4. Replace the following line:
#include "tegra194-p2822-camera-modules.dtsi"
With an #include statement specifying the DTSI file for your new device.
I can find that “tegra194-p2822-camera-modules.dtsi” is only included in the following files :
kernel_src/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0006-p2822-0000.dts
17:#include "common/tegra194-p2822-camera-modules.dtsi"
kernel_src/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-as-0006-p2822-0000.dts
kernel_src/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000.dts
16:#include "common/tegra194-p2822-camera-modules.dtsi"
So, for adding my custom sensor’s devicetree, which of above files should I modify the inclusion, please? I guess that it also relates to the Jetpack/L4T version as well, am I right?
Moreover, the “tegra194-cvb-p2822-0000-a00.dtsi” is included in “tegra194-p2822-0000-a00.dtsi”
kernel_src/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2822-0000-a00.dtsi
14:#include <t19x-common-modules/tegra194-cvb-p2822-0000-a00.dtsi>
Should I modify it as well?
Also, could someone be kind to explain me the signification/convention of different numbers within following filenames if possible, please ?
$ ls kernel_src/hardware/nvidia/platform/t19x/galen/kernel-dts/
tegra194-p2888-0001-e3366-1199.dts              tegra194-p2888-0001-p2822-0000-maxn.dts
tegra194-p2888-0001-p2822-0000.dts              tegra194-p2888-0006-p2822-0000.dts
tegra194-p2888-0001-p2822-0000-imx185_v1.dts    tegra194-p2888-as-0006-p2822-0000.dts
tegra194-p2888-0001-p2822-0000-imx274-hdmi.dts
Thanks in advance,
First, Thanks for your finding.
The dts should be the tegra194-p2888-0001-p2822-0000.dts,
PLease reference to below link to check the patch for Using the Main Platform Device Tree File
https://devtalk.nvidia.com/default/topic/1071818/jetson-agx-xavier/dev-node-not-populated-for-imx274/post/5430630/#5430630
Hi ShaneCCC,
Thanks for your confirmation and the link. Now I have a clear vision of how to add custom sensor’s devicetree using both Plugin Manager or Main Platform Device Tree. I could also find the board naming convention as well.
Possibly I will solicitatiate your support for the different parameters within the DTS(I).
Many thanks,
Khang
