Hello, I know this probably has been asked before, but I really am unable to find it.
I can use a externally created kernel from inside a C++ Class with no problem, what I would like though, is to create a kernel inside a class. Is this even possible?
Thanks for the help.
By “creating a kernel inside a class” you perhaps actually mean defining a global function as a member function of a class, something like
class Foo_Class
private:
public:
__global__ void Kernel_Function() { //implementation ...}
With the above code, you will probably receive the following compilation error: invalid combination of memory qualifiers. The reason is that global functions are called by the host via the “CUDA syntax”
Kernel_Function<<<blocks,threads>>>(...);
and are executed on the device. So, the answer to your question is “no”.
Opposite to that, you could have kernel launches of the form above within a class member function definition.
I would say (with respect) that the title of your post is a bit misleading. Something like “defining a global function as a class member” would have been more explanatory.
JFSebastian, that was exactly what I was looking for (sorry for the misleading post).
And what about global accessing a class? Is it possible? Or even worth it?
Actually sBc-Random, JFSebastian answered my question, another question was if it’s possible (even worth it) to use a class inside a CUDA Kernel.
If by “use a class inside a CUDA Kernel” you mean to pass objects to kernels or using class data or class member functions, the answer is “yes”.
Have a look at the NVIDIA CUDA C Programming Guide, Appendix D, C/C++ Language Support.
When defining the class, constructors and function member definitions should use the device keyword. Obviously, data should reside on the device. Remember that, to pass a class object to a global function you should implement a copy constructor in the class definition.
